Old 02-14-2016, 01:52 PM   #1
TruckTruck
Drives: 2013 frs, 2014 frontier
bad battery?
I have been storing my car for the winter in a heated garage. I wanted to just start it every weekend to make sure fluids moved around and battery would get charged. However I forgot about it for a month or 2 and the battery was dead, no problem just jumped it and ran it for a while no issues. Week later its completely dead again. Is this just cause its sitting for a week or bad battery. This is the first car I have ever stored so I wouldn't be surprised if I am missing something.
TruckTruck is offline   Reply With Quote
Old 02-14-2016, 02:19 PM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
I'm not using my car much and find the battery dead most times however it has recovered its charge after a couple of hours of driving. Short drives don't help as a dead battery is reluctant to take a full charge immediately .
I have been thinking about getting a battery disconnection widget but been too lazy. So I use snooper jump starter to get it running. Long term I'm sure it's not great to completely drain the battery but I am resigned to the fact that I'll probably get a new battery in the Spring.
Old 02-14-2016, 02:39 PM   #3
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Drive it for like 30min to recharge.
Yes these batteries blow! Is yours a Panasonic as well? Mine dies in cold weather quicker than hot as well.
Old 02-14-2016, 02:46 PM   #4
JD001
JD001's Avatar
Drives: Subaru BRZ
I find 30minutes drive is enough to operate remotes, door locks but never enough to turn over the engine. Come Spring I will invest in better quality battery.
Old 02-14-2016, 02:53 PM   #5
Lelantas
Lelantas's Avatar
Drives: '15 BRZ ISM
As with all other car batteries, charging is very slow if you're just idling your engine. After jumping it, be sure to drive it around for at least half an hour, preferably at higher speeds. If it's still not turning over, it's probably time to replace the battery.
Also, if you're just starting it every weekend without actually driving it, you're actually doing your battery a disservice--it's being used to start the engine, but it's not getting charged significantly.
Lelantas is offline   Reply With Quote
Old 02-14-2016, 03:05 PM   #6
jarnojvv
jarnojvv's Avatar
Drives: 86|Fortuner|FJ|Mustang|SwiftSport
bad battery?
Your vehicles charging system was not designed to bring a flat dead battery back to life. No amount of driving will fully recharge a dead battery. Idling the engine for periods of time will not help either.
Surface charging or continuous undercharging will lower the capacity of the battery over time and deep discharges can damage batteries and will shorten their lives. When a dead battery needs to be recharged, the only way to reliably restore it is to use an appropriate multi-stage battery charger. The charger voltage needs to be high enough to mix the battery acid evenly in the electrolyte to prevent ‘stratification’.
Discharge damage is permanent though.
I top mine up once a fortnight with a intelligent charger and batteries last 6 yrs plus.
-JvV-
jarnojvv is offline   Reply With Quote
The Following User Says Thank You to jarnojvv For This Useful Post:
stevesnj (02-14-2016)
Old 02-14-2016, 03:13 PM   #7
JD001
JD001's Avatar
Drives: Subaru BRZ
Originally Posted by jarnojvv View Post
Your vehicles charging system was not designed to bring a flat dead battery back to life. No amount of driving will fully recharge a dead battery. Idling the engine for periods of time will not help either. Surface charging or continuous undercharging will lower the capacity of the battery over time and deep discharges can damage batteries and will shorten their lives. When a dead battery needs to be recharged, the only way to reliably restore it is to use an appropriate multi-stage battery charger. The charger voltage needs to be high enough to mix the battery acid evenly in the electrolyte to prevent ‘stratification’. You will also save wear and tear, and fuel by using a charger to restore the battery to its maximum charge.
I used to own a decent battery charger / conditioner however moved house recently and it was thrown out by someone who knows better and must be obeyed.
The Following User Says Thank You to JD001 For This Useful Post:
Ultramaroon (02-14-2016)
Old 02-14-2016, 03:34 PM   #8
Your vehicles charging system was not designed to bring a flat dead battery back to life. No amount of driving will fully recharge a dead battery. Idling the engine for periods of time will not help either.........
This is important!
It's best to put a weak/dead battery on a charger ......the alternator is designed just to replace the charge used by the electrical system during normal usage.
stevesnj (02-14-2016), Ultramaroon (02-14-2016)
Old 02-14-2016, 03:37 PM   #9
Well, yes ....... "you hadn't used in the last year and don't plan on using it the next year" sooooo..........out it goes!
Old 02-14-2016, 03:40 PM   #10
Uggh. Just reading this raises my BP. Fuuuuuuu...
Old 02-14-2016, 03:52 PM   #11
JD001
JD001's Avatar
Drives: Subaru BRZ
Exactly!!! LOL!
Old 02-14-2016, 03:56 PM   #12
Well, yes ....... when was the last time you used that timing light, dwell meter, feeler gauge, carburetors synchronizer, vacuum gauge or points file ……….. ?? ...... out they go!
But don’t you dare touch the pressure cooker, canning cooker, pickle crock, colander, butter churn, wok pot, cottage cheese sack or flour sifter ………
JD001 (02-14-2016), Ultramaroon (02-14-2016)
Old 02-14-2016, 04:00 PM   #13
JD001
JD001's Avatar
Drives: Subaru BRZ
I hope your BP has dropped.. Just imagine how I felt, I was quietly going through boxes looking for it and didn't think once that I should ask she who must be obeyed. When I did ask if she had seen it (I had to describe it) I got silence that said it all.
The Following 2 Users Say Thank You to JD001 For This Useful Post:
aegisdrgn (02-14-2016), Ultramaroon (02-14-2016)
Old 02-14-2016, 04:01 PM   #14
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
I drive everyday, but very short distances. i connect my battery to a battery tender charger every couple of weeks or so. been doing this for the past couple of years. had the car 3 years now and the battery's still good.
shiumai is offline   Reply With Quote
Best two way dash cam that uses car battery and it's own battery? azynneo Electronics | Audio | NAV | Infotainment 14 01-22-2016 11:23 PM
Help! Battery died, charged battery now getting all sorts of error codes! jermyzy Issues | Warranty | Recalls / TSB 12 11-25-2015 01:35 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 09:26 AM
Battery tray for Braille 21lb battery? lordtakuban Engine, Exhaust, Transmission 4 09-10-2013 09:55 AM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 04:59 PM
