MisterSheep
Old 02-13-2016, 09:54 PM   #15
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Let me see...
I had a new tranny installed under warranty...the new installation is defective...and I have 1000 mi left on my warranty.
I wonder if I should return to the dealership...?
Boy, that's a tough one!
Oh wait, I'll just see what the guys on the internet say!
billwot is offline   Reply With Quote
Old 02-13-2016, 10:20 PM   #16
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I'd have to say this is not normal
I had mine replaced and my 5th gear does not vibrate more or less than any other gear
What I did notice is that my 5th gear is shorter than my original .. not sure why Hahaha
Oh, please don't say "glass" ....... too many people already think our transmissions are made of glass .......
But it is o.o
Lol
Old 02-13-2016, 10:21 PM   #17
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I also loose my warranty in about 1k miles.
Parts replaced under warranty with new, OE Subaru/Toyota parts will not be limited by your warranty expiration date/mileage.
It usually is an additional 12 months or 12000 miles, or your vehicle warranty. Whichever is greater.
-alex
humfrz (02-13-2016)
Old 02-14-2016, 12:46 AM   #18
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Anyone mind telling me How do you know you have a bad syncho??
I had problem with my 2nd & 5th O.o so i change fluid to mutol then it's a lot better... but once in the bluemoon my 5th gear acts up...so........ help?
Old 02-14-2016, 01:43 AM   #19
Well, usually, when a synchronizer is bad (or going bad) the transmission will "grind" going into gear. After a synchronizer has been eaten up, about the only way to shift gears, without grinding, is by double clutching and/or rev matching or jake shifting.
It's been my experience that when I "grind" going into 5th or 6th, it's because I've "lazy legged" the clutch (didn't push it all the way down).
Yep, slow, firm and steady ......that's what she likes ......
Old 02-15-2016, 01:45 AM   #20
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
I have set up a tech to drive the car after work on monday. I will update with what they say after.
Instagram: trevor.parque
Ultramaroon (02-15-2016)
Old 04-06-2016, 01:51 PM   #21
MisterSheep
Killed Scion
updating this thread with this thread here..
http://www.ft86club.com/forums/showthread.php?t=104065
Took it back to a different dealer and they said it wasn't normal and to have the bushings replaced. I wanted to call the dealer again today because they seem to be giving me the go around and don't exactly want to work on it. What should I ask them to check while the car is there?
Old 04-06-2016, 01:52 PM   #22
ZionsWrath
Thanks
ZionsWrath's Avatar
Originally Posted by billwot View Post
Let me see...
A dealership repair should have a 1 year/12,000 mile warranty independent of you new car warranty
The Following User Says Thank You to ZionsWrath For This Useful Post:
MisterSheep (04-06-2016)
6th Gear Grind & Replaced Transmission Bonburner Issues | Warranty | Recalls / TSB 45 07-31-2016 12:08 AM
Transmission - (4th) gear grind JJJMan75 Issues | Warranty | Recalls / TSB 3 03-21-2015 03:36 PM
Trouble getting into 1st gear with Manual Transmission when hot MINOCIN Engine, Exhaust, Transmission 3 09-30-2014 01:18 AM
transmission grind in 5th gear Rocket.BRZ Issues | Warranty | Recalls / TSB 7 06-30-2014 11:38 PM
