Old 02-06-2016, 10:15 PM   #1
JetSpeed
Drives: 06' Forester, 15 '3.6 OBW, 16' BRZ
Rear License Plate FRAME
Two Questions:
1. The two black foam adhesive strips glued to the trunk lid under where the license plate attaches. I'm thinking the foam is a good (bad) sponge for water, however I understand it's purpose not to scratch the paint.
Keep the foam on, or remove it?
2. I bought a Weathertech stainless steel license plate frame that has FOUR holes to attach the plate to the trunk. Trouble is, the trunk only has TWO screw holes (top) to attach the plate.
WHAT have you all done to make the two lower holes look like the two upper holes? My Weathertech frame came with four silver plastic caps to cover the screw heads, but since I can't use screws and caps for the two bottom holes, it's going to look a bit goofy for my OCD.
See frame here ------->http://www.weathertech.com/stainlessframe/
Thanks!!
JetSpeed is offline   Reply With Quote
Old 02-06-2016, 10:22 PM   #2
ryoma
ryoma's Avatar
superglue the plastic caps to the frame?
Old 02-06-2016, 10:28 PM   #3
swarb
The foam isn't absorbent like a sponge.
Foam also stops rattles.
I still got scratches with the foam, so I used the dealer advertisement plate under the licence plate.
Lower holes just glue the caps on OR cut the heads of the screws off, glue them on, and then put the caps over them.
Old 02-07-2016, 12:57 AM   #4
carma143
carma143's Avatar
Drives: Toyota Highlander; Subaru BRZ (SWP)
I do frameless. I added some foam between the frame and the paint. I also am using a black backplate that goes between the foam and the license plate.
"Wubalubadubdub! You're a wizard, Harry!"
-Captain Picard(4th incarnation of Dr. Who), Star Wars: Return of the Jar Jar
carma143 is offline   Reply With Quote
Old 02-07-2016, 01:03 AM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I scrapped the foam off. Then put real 3M foam on. It's thicker. I had rusty screws, so I swapped them out for stainless.
Old 02-07-2016, 02:13 AM   #6
acetothermus
Drives: Flying in a Blue Dream
I put foam weather stripping on the back of the plate on all my vehicles. Doesn't hold water, stops rattles and prevents scratches.
acetothermus is offline   Reply With Quote
FR-S rear license plate frame suggestions? tzhu07 Scion FR-S / Toyota 86 GT86 General Forum 58 03-12-2014 03:36 PM
New license plate frame Optimus Prime FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 07-19-2013 05:58 PM
FS: First 86 License plate frame... NorCal_Guy Miscellaneous 9 07-11-2013 06:50 PM
Rear License Plate Frame ashtray Cosmetic Modification (Interior/Exterior/Lighting) 19 07-23-2012 02:47 AM
rear license plate frame meekhotglass Cosmetic Modification (Interior/Exterior/Lighting) 1 06-20-2012 11:08 PM
