steve99
Old 01-14-2016, 05:37 PM   #463
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Sorry to bring up an older thread. I saw some recommendations that TRD intake doesn't need to be scaled, but looking through some logs I have from today, I see about 8-10% on LTFT in some cruising data. The interesting part is that my WOT 3rd gear pull is 0% LTFT.
Is this something that needs to be corrected via MAF scaling, or is that to be expected from TRD intake + full UEL header-back exhaust?
Jyn is offline   Reply With Quote
Old 01-14-2016, 07:08 PM   #464
steve99
Drives: FT86
The TRD intake wont cause the maf scaling to change but its not unusual for stock maf scaling to be out by 8% or so in places even with stock intake.
So maf scaling is usually beneficial even with stock intake.
Some aftermarket intakes will see ltft of 15 to 20% thats when your rearly must rescale.
Jyn (01-15-2016)
Old 02-06-2016, 04:25 PM   #465
eddieflyinv
eddieflyinv's Avatar
http://datazap.me/u/eddieflyinv/perr...=0&data=3-4-10
this is the 5th log after installing perrin 3inch intake, with their supplied maf scale... worst anyone has ever seen??
i figured id give it some time to learn after watching the first logs numbers creep up, but it just got worse and worse,
mods on car are crawford bpb, tanabe catless fp (possible its leaking ? did some reading and this crazy of ltft can be caused by that ?) and a catback,
any pros out there care to share if they think its a tune issue or hardware problem? hadnt noticed any leaks in the exhaust, and i was pretty thorough with the intake install, everything was tight and secure, so yeah, is the perrin scaling really this bad ???
eddieflyinv is offline   Reply With Quote
Old 02-06-2016, 06:39 PM   #466
steve99
Drives: FT86
1. The perrin supplied scaling is not very good in car I tried it on
2. you rearly do need to make sure you have no intake or exhaust leaks else this will cause high LTFT, exhaust leaks usually give you high positive trims at lower, which you dont have.
you either need to rescale maf yourself see links at bottom or
I suggest you try @Wayno s3" maf scaling, knowing wayno it will be pretty good.
Make sure you use the 3" perrin if you have that , the spreadsheet below has both 2.75 and 3
whole thread here http://www.ft86club.com/forums/showthread.php?t=94822
direct link to maf scalings
https://docs.google.com/spreadsheets...-UL7XLR3Y/edit
eddieflyinv (02-06-2016)
Old 02-14-2016, 10:48 AM   #467
eddieflyinv
@steve99 thanks for the advice and the links.
I have been using Waynos 3" Perrin MAF scale for a week now and my numbers aren't looking that much better for LTFT
I want to start scaling the MAF myself but it's like -18°C outside right now and I have seen multiple recommendations of doing scaling when its 20-25°C..
What I'm thinking is if I flatten the IAT Compensation tables can I effectively do the scaling now? Or am I wasting my efforts considering how cold it is. I would rather not reinstall the OEM intake. And really hope I don't have to wait till it warms up to do this as I am still seeing up to -20% at times and it bothers me a lot.
Thanks in advance,
Sent from my LG-H812 using Tapatalk
Old 02-22-2016, 10:47 PM   #468
jprice130
AutoX Nut
Drives: 2020 Toyota Supra
Been trying to dial in my MAF scale and the last two tunes I flashed are producing 0 LTFT in both closed loop and open loop. This has remained for 50+ miles after flashing. I am seeing various STFT values in my logs but LTFT is pegged at zero no matter what. I'm fairly certain my MAF scale is not that perfect (ha, ha), so is there something I'm missing that would cause this?
jprice130 is offline   Reply With Quote
Old 02-22-2016, 11:54 PM   #469
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Thanks in advance,
I've never worked on any 3" perrin.
Old 02-23-2016, 12:05 AM   #470
phrosty
...can I effectively do the scaling now?
If you scale your MAF now, the values will be valid for your current temps. You'll just have to redo it later on when it warms up. If you're seeing -20%, I'd definitely do it now assuming you've checked for leaks already.
phrosty is offline   Reply With Quote
Old 02-23-2016, 10:23 AM   #471
jvincent
jvincent's Avatar
Unfortunately the way the IAT temperature compensation table is defined makes it pretty much useless for any kind of fine grained control.
I don't have it in front of me fright now but IIRC the table supports an adjustment range of +/- 50% in 4% increments from the baseline of 68* F.
The problem is that for the temperature ranges we actually see you need a much smaller adjustment range but the table won't let you do it properly.
Old 02-23-2016, 12:01 PM   #472
eddieflyinv
Huh.. There was a 3" perrin scale in whatever link @steve99 directed me too, that was different from the Perrin supplied MAF. No big deal though, i went ahead and did my own scaling, I was worried about the temps throwing things off but im within about 3% +/- and as the temps have been rising its getting better, so it all worked out anyways
Old 02-23-2016, 12:22 PM   #473
jprice130
AutoX Nut
I'm now 100+ miles since my last flash and I'm still getting 0 LTFT. I ran a log with mostly closed loop driving for 20 minutes and LTFT was zero the entire time. Has anyone else ever experienced this? I've been logging with the Tactrix OP2 and I haven't changed my logcfg.txt file in over a year. All other parameters log as expected.
Old 04-21-2016, 10:23 AM   #474
cawith
Drives: Toyota GT86 6M/T
Hi,
So I decided to try scale my closed loop as well now, but I'm not sure about all the settings when loading logs.
Do the ones shown in the screenshot look alright? I don't know why the MAF Voltage Maximum is 32, it was supposed to be 3.2V.
Also, at idle the engine load is below the minimum of 0.2. Should I lower that minimum, so that it counts the idle cells in as well, or is it better to leave that out?
Thanks!
cawith is offline   Reply With Quote
Old 04-21-2016, 05:54 PM   #475
steve99
Drives: FT86
Originally Posted by cawith View Post
Hi,
Thanks!
yes change the ol/cl voltage to 3.2 not 32
the min load is probably ok at 0.2 but you could try 0.1
cawith (04-22-2016)
Old 04-21-2016, 09:03 PM   #476
freerunner
freerunner's Avatar
Drives: GT86
Yeah, it's a bug in vgitool for everyone whose system locale is not English.
If you want to keep your currently used system locale settings, you can use per-app locale setting as a workaround:
Edit your run.bat. After javaw.exe add two variables:
Code:
-Duser.language=en -Duser.country=us
If you're using Romraider, you'll want to run it like that, too. Else you might not be able to copy&paste table values.
freerunner is offline   Reply With Quote
The Following User Says Thank You to freerunner For This Useful Post:
cawith (04-22-2016)
AFR in Closed Loop Toyota John Software Tuning 39 07-07-2019 09:26 AM
BRZedit Fuel Trims, Closed to Open loop transiton mad_sb Engine, Exhaust, Transmission 32 08-06-2015 04:14 AM
Notes on injector / maf scalining using full time open loop mad_sb Software Tuning 40 03-03-2014 06:49 PM
Screencast: closed loop boost control with RaceRom jamesm Software Tuning 2 02-10-2014 03:23 PM
Screencast: experimenting with full-time closed loop fueling jamesm Software Tuning 2 12-27-2013 11:19 AM
