| Software Tuning Discuss all software tuning topics. |
#15 | |
Drives: FT86
#16 | |
Drives: SUBARU BRZ
#17 |
Drives: 2014 Subaru BRZ Limited MT - White
Will there be any (planned) new updates for the ESC tunes @Shiv@Openflash?
#18 |
Drives: Ap2
Is ffs already enabled in default file of this new update ?
#19 |
Drives: FR-S Whiteout
@Shiv@Openflash After the recent OFM auto update, my OFT has been saving 2 copied of my logs.
![]() Also, a error message pops up when I try to delete the log files. "error deleting file"
Intent > Content
cowardice is the mother of cruelty. |
#20 | |
Drives: FT86
Connect oft to pc connected to internet and see if their are any more updates Make sure your on latest Temlate File Try deleting the second of the two files not the first one Try the Delete All Files button Still no go Try saving a short log file with same name as the file that wont delete, this should overwrite the offending file with a non corrupt log of same name allowing you to delete it. If all else fails then last resort write back stock tune to car do a full OFT erase, remarry and reload tunes, hopefully that resets it. |
| The Following User Says Thank You to steve99 For This Useful Post: | solidONE (02-05-2016) |
#21 | |
Intent > Content
| The Following User Says Thank You to solidONE For This Useful Post: | steve99 (02-05-2016) |
#22 |
Drives: WRB BRZ Sport Tech
Hello,
I'm not sure if this has been posted somewhere else....but here goes nothing. So I am a complete noob to tuning and recently just bought the OFT and downloaded the new maps for stg 1 91 and 93 octane as I have 93/94 available locally. What differences will I notice over stock, I assume; - better throttle response? - more torque through the "dip zone"? - softer redline cutoff? - what is redline with the 91/93 tunes? can this be changed to a bit higher - i.e 7500-7600 - what is the cold start like? and anything else I may have missed..... and I've been told to start with the 91 map vs the 93, any particular reason for this as the engine was designed from factory to run 93.....I'm just trying to figure it out. Thanks, |
#23 |
Drives: 13 frs red
It'll be much more linear and enjoyable to drive. It may not feel stronger up top but that's because it won't be climbing out of a hole.
| Off the shelf OFT Tune Tomei EL Header | speeddemon | Software Tuning | 3 | 01-19-2015 09:56 AM |
| Which off-the-shelf Supercharger would you like to see CSG test? | CSG Mike | Forced Induction | 91 | 12-20-2013 05:16 PM |
| Brake Fluid shelf life? | VoiD | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 08-02-2013 07:17 PM |
| HKS SUPERCHARGERS ON THE SHELF! 3 AVAILABLE SCIONPRO | D2BD Motorwerks | Forced Induction | 7 | 07-01-2013 02:45 PM |
| Greddy Intakes and EVo 3 Exhausts on the shelf! | D2BD Motorwerks | Engine, Exhaust, Bolt-Ons | 1 | 01-31-2013 10:27 AM |
