Old 02-02-2016, 12:05 PM   #15
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Too fast!!!!
MS, CSCS, TSAC-F, CPT
Old 02-02-2016, 12:14 PM   #16
ajc209
Drives: GT86 Cosworth
Dont chuck all FI kits in the same pot. Some overheat more than others.....some dont at all
As for track times N/A vs FI well I suspect it is a matter of driver ability. Faster requires more skill to go 10/10ths.
ajc209 is offline   Reply With Quote
The Following User Says Thank You to ajc209 For This Useful Post:
go_a_way1 (02-02-2016)
Old 02-02-2016, 12:21 PM   #17
Ashikabi
Ashikabi's Avatar
If your fi is too hot... You just haven't spent enough money yet. Better radiator, vented hood, etcetc
The Following 9 Users Say Thank You to Ashikabi For This Useful Post:
ajc209 (02-02-2016), Bykov (02-02-2016), CSG Mike (02-02-2016), Dream20b (02-02-2016), FRS Justin (02-02-2016), go_a_way1 (02-02-2016), Sleepless (02-02-2016), soulreapersteve (02-02-2016), Summerwolf (02-02-2016)
Old 02-02-2016, 01:10 PM   #18
itsibarra
itsibarra's Avatar
Drives: Supercharged Car
I'm at 240/200 at the rear and need to upgrade wheels & tires. Like mentioned above, very slippery on stocks. I can step on the throttle in 1st-3rd and spin no problem especially in any wet weather.
itsibarra is offline   Reply With Quote
The Following User Says Thank You to itsibarra For This Useful Post:
Old 02-02-2016, 01:15 PM   #19
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
Originally Posted by RichardsFRS View Post
How fast is your 86 under boost? I'm sure it improved your strait line performance but how bad did it wreck the driving performance. I saw a video where the guy would just blip the throttle and go sideways. I can't imagine my car having 300hp or 300ftlbs being so so lite in the rear but it would be fun to test it. Guess I'd have to lite foot it in twisties
It's fine... unless you're driving in semi-cold weather, in the rain and that when you decide to give throttle the rear jumps in the air (tires spin in the air) and continue spinning once they regain traction.... that's gonna be a bad time.
Aside from that, I can make it go sideways if I want to but stay composed if I need to. I have a KW C38 kit btw (so top end power is where it's the riskiest). Keep in mind I also have a lot of suspension/handling components that were also modded.
fumanchu1 is offline   Reply With Quote
Old 02-02-2016, 01:48 PM   #20
CSG Mike
CSG Mike's Avatar
Means you get to have more fun
itsibarra (02-02-2016)
Old 02-02-2016, 04:03 PM   #21
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
I'm currently on stock-size winter tires and make about 265whp with my supercharger. With traction control off, I have to be very careful accelerating from a stop. If I apply any more pressure than 'bare minimum' to the gas pedal, it'll spin the tires until third gear.
2013 Asphalt Scion FR-S | Jackson Racing Supercharger | KW V3 | Enkei RS05RR 18x9.5
campy is offline   Reply With Quote
The Following User Says Thank You to campy For This Useful Post:
Old 02-02-2016, 05:12 PM   #22
mrk1
Drives: Sterling BRZ Ltd
Find someone local to take you for a ride.
I'm 335/276 and with 255 rear tires and smooth driving I don't worry to much about spinning when the weather is nice. Sure if you hammer it they'll spin but come on now.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 02-02-2016, 05:38 PM   #23
weederr33
weederr33's Avatar
The secret to the primacy's is that they are slippery at anything under 400whp, that's when they come alive!
Old 02-02-2016, 05:40 PM   #24
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
I had 260/210 with 255/40 Continential ExtremeContact DWS06s and broke 1/2/3 as well with the Sprintex kit.
Then again, I also had -2.5degree camber in the rear, so that could explain 3rd with such a large tire.
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
Old 02-02-2016, 05:54 PM   #25
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Ya I'm entirely stock wheels and tires and blimping the gas in a turn does result in a sideways car. Going strait I just spin the tires. It's all fun for a afternoon, weekend car. I'll never track it.
I rather have no traction and not eat factory transmission gears at the moment.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 02-02-2016, 06:46 PM   #26
FRS Justin
Drives: 2013 Asphalt FRS
Man I spin all the time must be something wrong with my car, even on just wastegate springs only rolling on it they break loose......
But I like it
I'm only 640/521
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
mrk1 (02-02-2016)
Old 02-02-2016, 08:02 PM   #27
Dream20b
Y u do dis?
Damn Justin I thought you were higher than that...
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 02-02-2016, 08:16 PM   #28
FRS Justin
I am now lol Video and more new build info after TX2K
710whp
Mercedes E55 AMG...Fast..but not fast enough. gdrider77 FR-S / BRZ vs.... 18 08-28-2014 04:56 PM
BC Coilover settings you guys guys ride on g0lden Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 04-06-2014 07:56 PM
Is your car fast? doggieboy09 BRZ First-Gen (2012+) — General Topics 100 10-28-2013 12:13 PM
So you like to go fast.... ScionFrsFan Off-Topic Lounge [WARNING: NO POLITICS] 3 01-04-2013 07:49 AM
Fast car Fast driver vinyl decal I need help francosolracer Cosmetic Modification (Interior/Exterior/Lighting) 18 10-20-2012 04:43 AM
