#43 |
Drives: 13' Asphalt FRS
Hey man, quick question, when you installed the pillow ball mounts, did it "lower" the car more? Figured I'd ask you since you're running it, vs making a post about it lol.. Thanks man
IG: __thatguyjeremy
#44 | |
Drives:
__________________________________________ projekt zeal86 build |
| The Following User Says Thank You to zeal86 For This Useful Post: | Thatguyjeremy (02-01-2016) |
#45 | |
I'm going to be installing them on my basis coilovers since they don't come with the top mounts.. I just don't want them to end up being lower because I hate adjusting ride height lol. Awesome build man!
IG: __thatguyjeremy
#46 | |
Drives:
I'm leaning towards that any change in ride height whether + or - will be negligible. __________________________________________ projekt zeal86 build |
#47 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
#48 |
Drives:
Beatrush Transmission Mount Bushing Spacer installation pics
![]() ![]() ![]() ![]() ![]() ![]() __________________________________________ projekt zeal86 build Last edited by zeal86; 02-01-2016 at 09:52 PM. |
#49 |
Drives:
Front Sway Bar Install :
Pretty straightforward install... no surprises or hangups. Great looking part, perfect fitment... very happy with the purchase. ![]() ![]() ![]() ![]() ![]() ![]() __________________________________________ projekt zeal86 build |
#50 |
Drives:
Here are some more pics of my Beatrush sway bar install along with my Beatrush front underbrace.
| The Following 3 Users Say Thank You to zeal86 For This Useful Post: |
#51 |
Mr.Fujitsubo
Drives: 2018 STI
I'm picking up the Beatrush front tower bar, rear tower bar and strut tower brace.
Would i be required to get an alignment after that?
2015 Toyota 86 ~ The Sold Car ~ Build Journal OFT Stage 1 Tune Review ![]() |
#52 | |
Drives:
You will not require an alignment... the installs will be very straightforward... let me know if you need any info on the installation that I did not address in this thread. __________________________________________ projekt zeal86 build |
#53 |
Drives:
New pics of all my new and older Beatrush suspension parts along with some RS*R components mixed in...
| The Following User Says Thank You to zeal86 For This Useful Post: | Koj (09-06-2016) |
#54 |
Drives: '13 FRS - STX
@zeal86
Do you have more pictures of the rear top hats? I'm thinking of picking them up but not sure if they will with as I'm not going to be running 60/65mm springs and am worried that I might buy them and not be able to use them. Thanks! Great photos. |
#55 | |
Drives:
__________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram | zeal.eightsix |
| The Following User Says Thank You to zeal86 For This Useful Post: | strat61caster (02-08-2016) |
#56 | |
Drives:
Collar / Spacer Interior Diameter ![]() Shaft Diameter ![]() Too small a diameter for the RS*R sports-i coilovers which are listed as ID 65mm. Beatrush pillow ball mounts are listed as ID 60mm. ![]() Great quality just like everything else I own from Beatrush...just not the right size for my set up. Hope this helps... __________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram | zeal.eightsix |
| Ohlins Road & Track for FRS/BRZ suspension install/review thread | mav1178 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 628 | 01-30-2024 06:16 AM |
| OEM armrest unboxing/review | supramkivtt2jz | Cosmetic Modification (Interior/Exterior/Lighting) | 508 | 11-22-2017 07:27 AM |
| The Ultimate LED Switchbacks VLED V3 Tritons Unboxing Install Review & Coupon | Yruyur | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 01-10-2014 06:59 PM |
| Sonar (Spyder) Tail Light Unboxing and Review | Yruyur | Cosmetic Modification (Interior/Exterior/Lighting) | 28 | 10-20-2013 04:42 PM |
| DIY Unboxing and Install of JDM CLEAR SIDE MARKER LENS! | MrGamer | DIY (Do-It-Yourself) Guides | 11 | 07-07-2013 11:19 PM |
