Old 01-31-2016, 12:12 PM   #1
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
RCE Tarmac 2 Owners: What's your street setup?
I installed some Tarmac 2's a few months ago on my FRS. The recommended settings are good for autox/track, but I'm trying to soften them up a bit for street use. I'd like to hear what some other people are using just to get some ideas. I'm basically trying to soften them up as much as possible with minimal bounce for daily driving.
smg1138 is offline   Reply With Quote
The Following User Says Thank You to smg1138 For This Useful Post:
Clipdat (02-03-2016)
Old 02-01-2016, 01:30 PM   #2
Silverspeed
Drives: 2014 FR-S
I always ran mine at 2 clicks from full soft front and rear on the street. I had 400# springs front and 450# rear. They rode sweet. Very comfortable.
Silverspeed is offline   Reply With Quote
The Following 2 Users Say Thank You to Silverspeed For This Useful Post:
Clipdat (02-03-2016), smg1138 (02-01-2016)
Old 02-01-2016, 03:27 PM   #3
Pat
Pat's Avatar
Drives: 2023 BRZ
I'm considering T2s in a year or two and live in Denver. One of my concerns is street comfort. I wish I would have had a chance to ride in your car with the T2s before you got rid of them.
Sooo....why DID you get rid of them?
Old 02-01-2016, 11:45 PM   #4
Silverspeed
Drives: 2014 FR-S
I just bought a set of T3's! I can't seem to leave well enough alone. Loved the T2's so I think I'll love the T3's even more. Going to try some stiffer spring rates this season and I think the T3's will support that plan a bit better than the T3's.
You should come out to some of the local SCCA autocrosses as there are two other guys that will be running T2's with 400/450 rates. You should be able to do some ride-alongs with them or see how the T3's are working with me.
marco_mc22 (05-08-2021), Racecomp Engineering (02-02-2016)
Old 02-02-2016, 01:01 AM   #5
smg1138
smg1138's Avatar
Any particular reason for the staggered spring rates? RCE sells them 400 square as stock.
Old 02-02-2016, 11:43 AM   #6
Pat
Pat's Avatar
Drives: 2023 BRZ
Thanks, Silverspeed. I'd love to do that. I have only driven in one autocross. I enjoyed it, but doubt I'll drive in another one. I would like to meet you out there to go for a ride, though. Or buy you a beer sometime.
Do you or the other guys on T2s ever make it out to tracks around here? I'm regularly at HPR.
Thanks again!
Old 02-02-2016, 01:50 PM   #7
wparsons
wparsons's Avatar
If/when I order T2's I'd be getting them with 400/500 to keep the balance closer to stock. Spring rates will be preference on how you like the car to be balanced.
flickr
Pat (02-02-2016)
Old 02-02-2016, 03:13 PM   #8
kch
Senior Misanthrope
kch's Avatar
Hoping for some more responses as I'm looking for the same thing. Ride quality on downtown roads is a little brutal at recommended settings.
The Following User Says Thank You to kch For This Useful Post:
Old 02-02-2016, 04:27 PM   #9
Silverspeed
Drives: 2014 FR-S
Yep. 400/400 is the standard set up but the T2's can handle more spring rate with no issue. I ran 450's in the rear to create a bit more rotation. I think it's a personal preference/sway bar thing. That is personal preference regarding how loose you like your set up and the type of bars you're running that figure in creating that set up. If I was running more bar in the rear I might have been happy with less spring rate. Maybe even less than 400.
I've also found out the hard way that our air (or lack there of) in Denver lends itself to a looser set up because of having less power to drive the car into oversteer at corner exit. When I went to Lincoln this year I was running a lot of rear bar and while the car was fine in CO, in NE the car was loose off. 15% more power will do that I guess.
The Following User Says Thank You to Silverspeed For This Useful Post:
Old 02-02-2016, 04:34 PM   #10
Pat
Pat's Avatar
Drives: 2023 BRZ
Heh...I learned the same thing. After many track days at 5,000 feet I took the car to Topeka. HELLO. Very different driving experience.
Then I returned to my high-altitude home. [Price is Right losing horn]
Setting up a car for race tracks is different than setting up cars for autocross. Knowing this, for a track car at altitude, would you keep rates at 400 all around?
Old 02-02-2016, 10:48 PM   #11
Mad_Mike
Mad_Mike's Avatar
Drives: 2013 Scion FRS firestorm
I've been running my T2s on the recommended settings since I got them over a year ago. I drive it every day and don't find them uncomfortable, then again I live in florida
Mad_Mike is offline   Reply With Quote
The Following User Says Thank You to Mad_Mike For This Useful Post:
Old 02-03-2016, 05:01 PM   #12
These were my settings after about 90 days of doing everything under the sun.
For what the OP is asking for just take out 4 clicks of rebound FIRST from what this shows. THEN , if thats not enough, remove 2 clicks of compression( bump).
Hope that helps.
Myles
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
kch (02-03-2016), smg1138 (02-03-2016), turbocat (07-26-2016)
Old 02-03-2016, 05:06 PM   #13
For whatever its worth, in THIS case I am suggesting tuning for comfort by using rebound as the factor. If we were tuning for performance at the track or while auto crossing it would normally ( not always) be compression.
With the Tarmac 3's I find myself tuning with compression ( low speed and high speed) more-so.
On the T3's the compression side is mono tube and the rebound side is twin tube.
Myles
Old 02-03-2016, 06:39 PM   #14
smg1138
smg1138's Avatar
Thanks, Myles! I'm going to give that a shot.
Racecomp Engineering (02-05-2016)
KW V3 Setup for Street use. Supermassive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 09-03-2016 03:48 AM
Tarmac 2 recommended damper setup Rocket.BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 06-24-2016 06:30 PM
KW V3 Owners, What's Your Setup? qtwre Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 06-06-2016 07:34 PM
Koni yellow/RCE tarmac setup-initial review ncmx5 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-12-2014 01:55 PM
FS; TEIN basis - best for street setup! hong Brakes, Suspension, Chassis 8 10-16-2014 02:58 PM
