Old 02-01-2016, 10:17 AM   #43
Thatguyjeremy
Drives: 13' Asphalt FRS
Hey man, quick question, when you installed the pillow ball mounts, did it "lower" the car more? Figured I'd ask you since you're running it, vs making a post about it lol.. Thanks man
IG: __thatguyjeremy
Thatguyjeremy is offline   Reply With Quote
Old 02-01-2016, 10:25 AM   #44
zeal86
zeal86's Avatar
Drives:
I installed the pillow ball mounts with my pre-adjusted RS*R coilovers so I don't really know how much of an effect the mounts had on the ride height. Are you looking to install these with springs, coilovers, or OEM suspension?
__________________________________________
projekt zeal86 build
zeal86 is offline   Reply With Quote
The Following User Says Thank You to zeal86 For This Useful Post:
Thatguyjeremy (02-01-2016)
Old 02-01-2016, 10:54 AM   #45
Thatguyjeremy
I'm going to be installing them on my basis coilovers since they don't come with the top mounts.. I just don't want them to end up being lower because I hate adjusting ride height lol. Awesome build man!
IG: __thatguyjeremy
Old 02-01-2016, 11:33 AM   #46
zeal86
zeal86's Avatar
Drives:
Thanks for the comp on the build.
I'm leaning towards that any change in ride height whether + or - will be negligible.
Old 02-01-2016, 11:41 AM   #47
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Yeah I also want to say nice build man!! You and I have the same style keeping it super clean and only using quality parts.
Old 02-01-2016, 08:34 PM   #48
zeal86
zeal86's Avatar
Drives:
Beatrush Transmission Mount Bushing Spacer installation pics
The Following 3 Users Say Thank You to zeal86 For This Useful Post:
8R6 (02-03-2016), chaoskaze (02-26-2016), Koj (09-06-2016)
Old 02-02-2016, 10:42 PM   #49
zeal86
zeal86's Avatar
Drives:
Front Sway Bar Install :
Pretty straightforward install... no surprises or hangups.
Great looking part, perfect fitment... very happy with the purchase.
The Following 2 Users Say Thank You to zeal86 For This Useful Post:
8R6 (02-03-2016), Koj (09-06-2016)
Old 02-03-2016, 08:19 PM   #50
zeal86
zeal86's Avatar
Drives:
Here are some more pics of my Beatrush sway bar install along with my Beatrush front underbrace.
8R6 (02-03-2016), Koj (09-06-2016), Mr.Impreza (02-03-2016)
Old 02-03-2016, 10:27 PM   #51
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
I'm picking up the Beatrush front tower bar, rear tower bar and strut tower brace.
Would i be required to get an alignment after that?
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
Old 02-03-2016, 10:31 PM   #52
zeal86
zeal86's Avatar
Drives:
Would I be required to get an alignment after that?
Awesome... you won't be disappointed.
You will not require an alignment... the installs will be very straightforward... let me know if you need any info on the installation that I did not address in this thread.
Old 02-08-2016, 01:37 AM   #53
zeal86
zeal86's Avatar
Drives:
New pics of all my new and older Beatrush suspension parts along with some RS*R components mixed in...
Koj (09-06-2016)
Old 02-08-2016, 04:36 PM   #54
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
@zeal86
Do you have more pictures of the rear top hats? I'm thinking of picking them up but not sure if they will with as I'm not going to be running 60/65mm springs and am worried that I might buy them and not be able to use them.
Thanks! Great photos.
ineedyourdiddly
Old 02-08-2016, 05:14 PM   #55
zeal86
zeal86's Avatar
Drives:
@zeal86
I'll look to see if I have any pics from when I tried to install them. I am not running those because when I went to install them, the supplied threaded spacer/collar was too small a diameter for the RS*R coilovers... so I couldn't accommodate the pillow mounts without acquiring the proper hardware. This was not an issue for the fronts though.
zeal.eightsix Facebook
Instagram | zeal.eightsix
strat61caster (02-08-2016)
Old 02-08-2016, 08:18 PM   #56
zeal86
zeal86's Avatar
Drives:
@zeal86
This is what I got for pics...
Collar / Spacer Interior Diameter
Shaft Diameter
Too small a diameter for the RS*R sports-i coilovers which are listed as ID 65mm. Beatrush pillow ball mounts are listed as ID 60mm.
Great quality just like everything else I own from Beatrush...just not the right size for my set up.
Hope this helps...
Koj (09-06-2016)
Ohlins Road & Track for FRS/BRZ suspension install/review thread mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 628 01-30-2024 06:16 AM
OEM armrest unboxing/review supramkivtt2jz Cosmetic Modification (Interior/Exterior/Lighting) 508 11-22-2017 07:27 AM
The Ultimate LED Switchbacks VLED V3 Tritons Unboxing Install Review & Coupon Yruyur Cosmetic Modification (Interior/Exterior/Lighting) 12 01-10-2014 06:59 PM
Sonar (Spyder) Tail Light Unboxing and Review Yruyur Cosmetic Modification (Interior/Exterior/Lighting) 28 10-20-2013 04:42 PM
DIY Unboxing and Install of JDM CLEAR SIDE MARKER LENS! MrGamer DIY (Do-It-Yourself) Guides 11 07-07-2013 11:19 PM
