#197 |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
I'm actually headed to the shop in about an hour and a half to go pick it up. I have an appointment at work first, though.
| The Following User Says Thank You to slicktop For This Useful Post: | MisterSheep (01-20-2016) |
#198 |
Drives: 10 Series #974 6m/t
so who will be rewiring a new harness for you? just for reference.
#199 |
Trust Automotive in Chesapeake, VA. They've put together pretty much the entire car. Props. Anyone looking for a no BS build, contact them.
| The Following User Says Thank You to slicktop For This Useful Post: | NyC Zn6 (11-19-2015) |
#200 |
The car is back home and it's running very well. The video I had, had too much edited out so I'll have to make another one without me talking or giggling like a man-child.
#201 |
You're like the...
Drives: '13 6MT FRS / '14 Ram 1500 Sport
Vids vids vids.
Also, would the Adapter+350Z transmission line up the same as a V160 you figure?
| The Following User Says Thank You to JTOFJPN For This Useful Post: | MisterSheep (01-20-2016) |
#202 |
Killed Scion
Drives: 2013 FR-S Whiteout
subbed
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
| The Following User Says Thank You to MisterSheep For This Useful Post: | slicktop (01-20-2016) |
#203 |
Drives: 85 corolla gts
You should be able to get the cd009 trans to fit. It is a tight fit with the v160 and the cd009 is a bit bigger. Some sheet metal adjustment may be require. As well the shifter set up will require a modification to make it short enough. It will be very tight. Next up is the Emtron KV8 install. I do not know who is more excited for that, slicktop or me.
| The Following User Says Thank You to Ross For This Useful Post: | slicktop (01-20-2016) |
#204 | ||
Additionally, yes, the car is getting an Emtron KV8 instead of the Motec M150. Should be a good fit to my needs at a lesser cost than the Motec. Hope to have the car back out a few weeks from now as we're about to have a blizzard come through the Mid Atlantic. Vids will come soon after. I've been in contact with some video/photographers to do some professional work. Additionally, I'll be attending Hot Import Nights in Atlanta this year (provided work doesn't get in the way!) so there will be plenty of coverage of the car this year.
#205 | |
You're like the...
#206 |
We only used the v160 on slicktops car. I just happened to have a v160 and a cd009 sitting on the floor, one from a supra build and the other from a g35 build we are doing. So I took some measurements. I feel the v160 fits well but they are becoming to expensive for what they are sense Toyota has stopped production of them. I would like to get my hands on an ar5 to look over the shifter assembly. See what would need to be done to make that work. As those are relatively cheap and just swap a bell housing to mate to the engine.
#207 | |
You're like the...
I have started my pricing list (see att), it pains me here in Canada with the 1.49CAD->USD exchange right now, but I'm looking to be ready for a swap whenever all your shale oil companies go bankrupt lol.
| The Following User Says Thank You to JTOFJPN For This Useful Post: | Stigasaur (01-26-2016) |
#209 |
I haven't, but I estimate it being about 3,000lbs.
#210 |
Emtron EMS just came in last night. Looking forward to the new EMS setup. If it all works out, it'll open up a lot of swaps as a direct competitor to MoTeC in regards to CAN functionality at a much less expensive option.
| Tags |
| 2jz, 2jz brz gt86 frs swap, 2jz frs, 2jz frs swap, 2jz swap |
| Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 08:52 PM |
| Mr and Mrs FR-S Build | jaydee_do_work | Member's Car Journals | 2 | 12-04-2013 10:51 AM |
| 86 BUILD, AUS | JS86JS | Member's Car Journals | 9 | 05-31-2013 09:59 AM |
| My build... well some of it | cruzinbill | Electronics | Audio | NAV | Infotainment | 41 | 04-01-2013 05:02 PM |
| STX build | Evil86 | Tracking / Autocross / HPDE / Drifting | 2 | 01-08-2013 04:40 PM |
