Old 01-16-2016, 01:26 PM   #29
nunonuna
nunonuna's Avatar
Originally Posted by gMit View Post
I hate to ask the noob question but here I go.
If i buy this https://www.japanparts.com/parts/detail/42170, is it as simple as taking old shifter out and installing new one, or do I need new springs? I'd get my mechanic to do it.
When it comes to shifters, I don't have much knowledge in the area.
Appreciate the help!
Edit: I want to add that I live in Australia. I've been looking at where to purchase some mtec Springs but have had no luck. Best place I can find is their site.
It seems they ship to your country.
http://pages.ebay.com/motors/link/?n...588264&alt=web
As for the transmission mount, I suggest to get whiteline insert instead of new mounting. Much easier to install and cheaper.
nunonuna is offline   Reply With Quote
Old 01-16-2016, 05:51 PM   #30
gMit
Drives: Pearl BRZ
Originally Posted by Metabrz View Post
You dont need new springs. I recommend getting the STi transmission mount kit as well. Shifting is rock solid with mounts - that 2nd gear harshness is all but gone. The occurrence and harshness both reduced.
Thanks for the replies. I'm looking into transmission mounts. I can get the Perrin rear shifter bushing relatively cheap.
Would I need to get a new reverse lockout or can i just utilize the current one?
gMit is offline   Reply With Quote
Old 01-17-2016, 03:32 AM   #31
SPCorBUST
SPCorBUST's Avatar
The STI shifter comes with a new plastic reverse lockout already installed.
The STI transmission mount feels better than the Whiteline bushing.
The Perrin rear shifter bushing is ok.
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 01-17-2016, 03:34 AM   #32
SPCorBUST
SPCorBUST's Avatar
Its simple. Unbolt and bolt in. No springs.
Old 01-17-2016, 03:37 AM   #33
SPCorBUST
SPCorBUST's Avatar
Originally Posted by weederr33 View Post
Lawl. I already have the USDM TRD quickshifter so I won't.
I'm seeing if I can run both the TRD Quick Shift kit and the STI Gear Lever (short shifter). They are completely different parts. I'm thinking I may have compatibility issues with my aluminum driveshaft and the TRD kit though.
Old 01-17-2016, 03:57 AM   #34
gMit
Drives: Pearl BRZ
Is this the STI transmission mount everyone is referring to?
https://www.japanparts.com/parts/detail/1693
Old 01-17-2016, 01:25 PM   #35
SPCorBUST
SPCorBUST's Avatar
That one is not. That's for the Forester; the FR-S and BRZ transmission mount is very similar, but it is different. I have a picture of it in my build thread from when I did the install after switching from the Whiteline positive shift kit bushing.
This is the droid you are looking for:
https://www.japanparts.com/parts/detail/43060
Old 01-17-2016, 07:46 PM   #36
Metabrz
001 of 012
Metabrz's Avatar
Drives: MY12 NZDM Subaru BRZ "BRZ001"
Yup.
BRZ001: Peace Love and Wheelies @metabrz on IG
Metabrz is offline   Reply With Quote
Old 01-21-2016, 02:54 AM   #37
voyager2285
voyager2285's Avatar
Drives: WRB BRZ
@Trap63 do you have pictures of how the shift boot is different then OEM? Japanparts have a note saying that it's different so it'll be included, but I already have one from JPM that I'd like to keep. Thanks!
voyager2285 is offline   Reply With Quote
Old 01-21-2016, 04:11 AM   #38
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
I loose this description of Japanparts. I confirm you that Alcantara JPM will fit as you see.
Trap63 is offline   Reply With Quote
Old 02-17-2016, 03:24 PM   #39
WolF_RS
WolF_RS's Avatar
Drives: 2015 Ultramarine Scion FR-S (MT)
Any news on the TRD quick shift kit retrofitting on to the STi SS?
WolF_RS is offline   Reply With Quote
Old 02-17-2016, 06:41 PM   #40
SPCorBUST
SPCorBUST's Avatar
I tried once, it did not work where the adapter bolts up. The other pieces worked though. I haven't given up yet and will try it again soon though, the first time around it was late and I was in a rush to finish.
Sent from my SM-G925T using Tapatalk
Old 02-17-2016, 09:08 PM   #41
SPCorBUST
SPCorBUST's Avatar
I should add that I have an aluminum driveshaft, and I believe that is the main issue.
I fully believe the TRD quick shifter will work with the STI shifter if you have just those two items.
Old 02-17-2016, 10:07 PM   #42
WolF_RS
WolF_RS's Avatar
I'm guessing difference in sizing from the stock driveshaft?
How would you say both the quick shift and SS would feel if it were to bolt up together, just those two assemblies?
Gear lever rattle - fixed sav AFRICA 16 01-30-2020 09:22 PM
Gear lever rattle Freedom Engine, Exhaust, Transmission 18 11-10-2015 11:17 AM
Ferrari like gear lever ? mashal Scion FR-S / Toyota 86 GT86 General Forum 54 10-20-2015 02:03 AM
Gear lever rattle Freedom AFRICA 0 05-25-2015 04:17 AM
Front KNocking Noie and Gear Lever rattle Naughty AFRICA 17 10-26-2013 02:56 PM
