Drives: 2013 Pearl White 6MT
Why does my car have green topped valve covers?
Someone at toyota said it was because they put nitrogen in the tires? Wife's car has them too. I think they are ugly. I'm gona get some nice chrome ones
#2 |
Drives: FRS-Raven-MT
It's to designate that there is nitrogen in the tires. So you or whoever is filling up the tires doesn't mix it with air.
| The Following User Says Thank You to TruRace For This Useful Post: | Tcoat (01-12-2016) |
#3 |
Drives: 2005 Toyota Camry
Valve stem cap.
Valve covers = what's over the cylinder head in the engine bay. -alex |
| The Following 25 Users Say Thank You to mav1178 For This Useful Post: | 3_NA_HAF (01-15-2016), 8R6 (01-12-2016), Braces (01-13-2016), c4lvinnn (01-18-2016), humfrz (01-13-2016), Jake360 (01-13-2016), MaximeT (01-13-2016), MisterSheep (01-14-2016), NWFRS (01-13-2016), PeterFRS (01-18-2016), pushrod (01-12-2016), raven1231 (01-14-2016), roddy (01-12-2016), Sarlacc (01-12-2016), SkAsphalt (01-15-2016), soulreapersteve (01-13-2016), strat61caster (01-13-2016), Summerwolf (01-13-2016), Tcoat (01-12-2016), tcroft91 (01-15-2016), Tectoniic (01-13-2016), Teseo (01-12-2016), tslyw (01-15-2016), why? (01-15-2016), YamahaR86 (01-13-2016) |
#4 |
And if they do mix air with it don't panic. It just means you have air mixed with the nitrogen and that has zero effect since air is 78% nitrogen anyway. Nitrogen filled tires are a huge rip off.
Now if they would fill them with helium and make the car lighter. For god sake do not fill them with hydrogen though.
| The Following 15 Users Say Thank You to Tcoat For This Useful Post: | Cole (01-13-2016), Demandred7 (01-13-2016), Gunman (01-13-2016), imaguitar (01-13-2016), JB86'd (01-12-2016), Lelantas (01-12-2016), PandaSPUR (01-12-2016), Sarlacc (01-12-2016), soulreapersteve (01-13-2016), stevesnj (01-12-2016), strat61caster (01-13-2016), tslyw (01-15-2016), Tye300 (01-13-2016), why? (01-15-2016), xFury (01-15-2016) |
#5 |
not a twin owner
Drives: 2016 Veloster Turbo DCT
[OT] Tcoat, I'd like to thank you for your post but being a forum newbie I have no idea how to do it. Is there a button or link I am not noticing. Or is it because newbies are not allowed to thank? Help! ;-) [/OT]
#6 |
About the only good thing that filling it with nitrogen does, is that it is usually with zero moisture.
This ensures the least amount of tire pressure change as temperatures change. -alex |
| The Following 2 Users Say Thank You to mav1178 For This Useful Post: | justatroll (01-13-2016), strat61caster (01-13-2016) |
#7 | |
I'm not even sure you can see our valve covers in our engine bays
#8 | ||
| The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | Ashikabi (01-12-2016) |
#9 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Nitrogen is affected exactly like any other noble gas by temperature. It will expand and contract.
H20 molecular bonds in the tire can be broken by temperature changes. Then the individual 0 and H molecules take up more space than they did before. Won't matter in the slightest on the road. Track bench racing appellation.
"I gotta rock." -- Charley Brown |
| The Following 2 Users Say Thank You to bcj For This Useful Post: | strat61caster (01-13-2016), Tcoat (01-12-2016) |
#10 |
not a twin owner
#11 |
Nitrogen will expand and contract... however, not to the degree of plain old air. So for example during an autocross session, you start when it's cooler out and after a few runs your tires are hot and when you finish later in the day when it's even hotter your tires will go up several PSI. Nitrogen will only go up a few PSI. I'm not good enough to worry about tire pressures yet but all the better drivers are constantly fiddling with theirs
#12 |
Geo Tyrebighter Esq
Derp. True.
Tires are still permeable though. Nitrogen leaks out at a slower rate than smaller atoms. Helium will leak faster. Hydrogen would fall out faster than anything. Oxygen would leak out slower than Nitrogen, but if you had a bag full of Oxygen in a crash, you may have a bad day.
| The Following User Says Thank You to bcj For This Useful Post: | why? (01-15-2016) |
#13 | |
Drives: '13 Ultramarine
There is a minimum number of posts before you can thank...IIRC, it's 10.
#14 | |
| Topped off coolant with Prestone | radroach | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 12 | 12-13-2015 10:14 PM |
| Replacement windshield with "green tint/green shade" | extrashaky | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 07-07-2014 12:02 PM |
| Anybody have a lead on custom fitted car covers and seat covers for the FR-S? | Grateful Dave | Cosmetic Modification (Interior/Exterior/Lighting) | 17 | 08-27-2012 10:41 AM |
| CBS FRS at Green Toyota | Integratedfool | Great Lakes | 0 | 06-25-2012 01:24 PM |
