Old 01-04-2016, 01:47 PM   #1
Ak1m0to
G20 Guru
Ak1m0to's Avatar
Drives: Infiniti G20 / FRS
Send a message via AIM to Ak1m0to
Monogram Push Start Issue
Hi Everyone,
Not sure if any of the Monogram/ 10 Series/ Limited people are having this issue.
Lately, I've come across while trying to start my car (AT), the car doesn't start.
All the lights on the dash will light up, the radio works, the green light comes on that it recognizes the key, and the steering wheel isn't locked.
I've also tried unplugging the battery to reset the car, still no luck.
And I changed the batteries inside the key fobs.
I also heard the cell phone can interfere, so I've also tried turning the phone off.
Thing is, the immobilizer light will flash and the green key light is solid.
It doesn't do it all the time, and usually if I wait around for about 30 minutes or so, the car will eventually start.
Only thing I can think of is my battery could be dying.
2014 model with 60k miles.
Any ideas?
Slowmatic Drfiterz, from P to D in a heartbeat.
Ak1m0to is offline   Reply With Quote
Old 01-04-2016, 01:57 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
My guess is battery
Old 01-04-2016, 02:09 PM   #3
My guess is battery
Yep, that would be my guess too.
I suggest you check the battery:
http://www.aa1car.com/library/battery_runs_down.htm
Or, take the car into a shop and have them do a "load test" on the battery.
Life is too short to put up with a weak battery.....
go_a_way1 (01-04-2016)
Old 01-04-2016, 02:40 PM   #4
CokeSlap
Drives: 2014 Monogram FRS Whiteout
Im jumping on the battery train as well. I thought someone had a similar issue and it was the battery or my mind could be making things up. Though battery would definitely be the first thing to check especially during this time of year and the changing temps.
Previous Ride
1992 Acura Integra GSR in Aztec Green Pearl
CokeSlap is offline   Reply With Quote
Old 01-04-2016, 02:53 PM   #5
My usual response to these is unhook the battery and hook it back up to reset but since you have already done that I will hop on the battery train as well. A dying battery can do the weirdest stuff sometimes.
Old 01-04-2016, 03:11 PM   #6
speaking of trains, this one is not the place for weak batteries .....
Tcoat (01-04-2016)
Old 01-04-2016, 08:22 PM   #7
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
Too bad you have an automatic. Otherwise you could push start it.
Muaddib is offline   Reply With Quote
Old 01-04-2016, 08:31 PM   #8
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Sounds like a dying battery to me.
jawn is offline   Reply With Quote
Old 01-04-2016, 08:34 PM   #9
@jawn ...... hops on the train ..........
jawn (01-04-2016)
Old 01-12-2016, 03:08 PM   #10
Ak1m0to
G20 Guru
Ak1m0to's Avatar
Well, I changed the battery this past weekend and while leaving work yesterday, the car didn't want to start up again.
After trying different things like locking the car, going outside, wait for the factory alarm to set, unlock, get try to start, ect...
The car finally started about 30 minutes later.
Only thing I can really think of now is maybe bad ECU?
I have enough juice on the battery and the alternator is reading just fine.
Any other ideas?
Old 01-12-2016, 04:03 PM   #11
Any other ideas?
Now, you have a new battery.......hmmmmm
Are you sure the new battery had a full charge .. ??
(it wouldn't be the first one - weak off the shelf)
Did you clean the inside of the battery cable clamps .. ??
When you say "it won't start" does it turn over and not fire ..... or nothing happens when you hit the start button .. ??
Does it go: click-click-click after you push the start button .. ?? (heck, I don't even know if they do that anymore ..... ).
DANG electronics .......
Back in the day, I would suggest you check the cable connection on the starter.
Then check the battery ground connection to the block/frame.
However, you may have to take it into the dealer ......
Old 01-12-2016, 04:04 PM   #12
jawn
jawn's Avatar
Any other ideas?
You don't have stuff plugged in do you? An OFT, perhaps?
Old 01-12-2016, 04:48 PM   #13
NahumCC
Drives: 2013 FR-S 10 Series
Two switches to check come to mind and I don't know if they have them for certain since I have a manual. Someone will correct me if I'm wrong.
There are generally two switches that can stop you from getting a push button car started. The first is a brake switch and the other is gear selector position sensor.
The first switch's job is obvious. The other switch, sometimes referred to as a NSS (Neutral Safety Switch) is meant to prevent an automatic from being started in anything other than park or neutral.
NahumCC is offline   Reply With Quote
The Following User Says Thank You to NahumCC For This Useful Post:
humfrz (01-12-2016)
Old 01-12-2016, 05:53 PM   #14
Ak1m0to
G20 Guru
Ak1m0to's Avatar
I tested the battery with a volt meter when I bought it, and also had it on a trickle charger before install.
Clean all the terminals and applied a little dielectric grease to both terminals.
Everything turns on, radio, lights, gauges, but the car doesn't turn over.
It's as if I only hit the push button without pressing the brake or clutch pedal.
Only thing I have plugged in is my radar, and phone charger.
Recently, I've been unplugging those items when I shut the car off to make sure nothing is draining the battery.
I've made a habit to shut the radio off, turn off the A/C, unplug the radar and charger before I turn the car off.
No OFT, car is tuned via ECUTEK by Motoeast.
Thanks, I'll look into those switches, may be a faulty one that's going out, but not completely.
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 07:06 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 03:45 PM
STI Push Start Inextirpable CANADA 1 03-15-2013 03:52 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 04:44 AM
GTS come with push start? adam AUSTRALIA 13 06-04-2012 04:28 AM
