Old 12-29-2015, 12:39 PM   #57
stevesnj
stevesnj's Avatar
Don't muddle up the issue ...... many have already made up their minds ......
Well it's just info from the Toyota engineers that's all. Not muddling info is it?
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
Ultramaroon (12-29-2015)
Old 12-29-2015, 01:30 PM   #58
Well, now, you just can't believe everything you read in the owners manual .....
stevesnj (12-29-2015), Ultramaroon (12-29-2015)
Old 12-30-2015, 01:27 AM   #59
pantdino
Drives: Firestorm 2013 FR-S
Originally Posted by Sideways View Post
Never had any problem with studs on my brz. I use anti seize on my lug nuts too, but not every time I remove my wheels and I only use a very small dab of it. .
I think that's the solution-- don't slobber so much on the threads can't grab, but just enough you can't get rust / chemical seizure between the metals.
There are numbers for how much you should decrease torque for a "oiled" fastener-- it's about 25%.
I use 70 ft-lbs and sparingly anti-seized lug nuts.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
pantdino is offline   Reply With Quote
Old 12-30-2015, 01:34 AM   #60
pantdino
Originally Posted by Nickosport View Post
I'd like to add that anti-seize is not a lubricant; its an abrasive.
So all of that BS above about lubricated vs. nonlubricated torque in this particular situation means precisely squat.
This makes a lot of sense- and explains why I have never had a fastener on which I had applied anti-seize come loose.
The owner's manual says to not use OIL or GREASE on the threads. Anti-seize is not on the list.
The Following User Says Thank You to pantdino For This Useful Post:
stevesnj (12-31-2015)
Extened Studs? BlaineWasHere Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-29-2013 12:29 PM
Down hill breaking... ABS? shaofis Issues | Warranty | Recalls / TSB 11 10-22-2012 05:28 PM
Breaking Bad: Season 5 |-Goku-| Off-Topic Lounge [WARNING: NO POLITICS] 15 07-22-2012 02:02 AM
Breaking Bad Season 4 tranzformer Off-Topic Lounge [WARNING: NO POLITICS] 4 10-10-2011 09:17 PM
