#43 | |
Lets say you're going around one of those cloverleaf freeway onramps, and are in the mood for some brisk cornering speeds. With a supercharger, you can slowly squeeze the throttle until you get the exact amount of power you want. It's just like having a larger engine. With a turbo, you will most likely (with bad results): - squeeze the throttle more and more, waiting for the desired amount of power, and then suddenly have too much - squeeze the throttle some, but not completely, anticipating the turbo to spool, so you eventually have the exact power you want Less likely (but perfectly good results): - squeeze the throttle a lot (maybe completely), and lift off partially as the turbo spools, to precisely modulate the throttle for the exact amount of power you want (but remember, if you lift too much, your BOV actuates, or you reduce output too much, and have to re-spool your now de-spooled turbo) - Squeeze the throttle a lot and let your aftermarket traction control do it's thing. |
#44 |
Junior
Drives: a car
A well thought out kit with a sized turbo will do great with the stock CR and everyday driving, granted what CSG mike implies is that you may need to alter your driving style if you arent used to turbo cars, or more accurately, a boosted 86 dyno plot.
#45 | |
Drives: 2013 Asphalt FRS
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
#46 |
I'm familiar with a boosted fa20, mine makes 644Whp and 521wtq. I first have to get some driving style lol I just pin it when in doubt.
#47 | |
Drives: 2013 FRS / 2013 427 Vert
Thought it would help reprinting the original question as a reminder that it specifically pertains to aftermarket choices for this chassis. I've known from the beginning that I would be going the FI route eventually and I wanted to be sure I made a reliable choice to sustain through 20 or so track days per year in the Southeast. My original thought was the Jackson Racing kit made the most sense and I spent the last year considering other alternatives including low mount turbo kits. In the end my first instinct was right for me and I just received the high boost JR kit. These are the reasons for my decision
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
#48 |
Drives: Velocity Orange 86 GT
Awesome. You should have alot of fun with that. The moral of the story is get what you are going to enjoy. Even though a turbo is better.
| The Following User Says Thank You to Northwest86 For This Useful Post: | FRS Justin (12-25-2015) |
#49 |
Legendary Member
Drives: HyperBlue BRZ
I'm wondering, with a turbo kit, what parts of the engine are best to upgrade so you don't have things breaking in the future or causing stress? I don't know a lot about engines internally but I've heard you'll need upgraded fuel injectors, forged rods & pistons. Of course this all depends on how much boost psi. Say for a stage 2 turbokit running 9 psi or 12. Tracking the car (4 times a year or something) and also a DD commuter. What should be upgraded for the longevity of the vehicle? Would there be a need for upgraded parts of the turbo kit eventually? Like a more efficient aftermarket radiator or something? I'm just wondering. I plan on going FI in the future after I do exhaust + headers tune and tires + wheels + suspension work. I'm planning on doing brakes the same time as the turbo for stopping power with the increased HP.
#50 | |
Drives: GBS BRZ Harrop SC/PTuning Header
For the majority of people who are not drag racing their cars or dealing with the issues associated with altitude, SC will likely be the easiest way to gain power without overloading the engine internals (like our famously thin piston rods). |
| The Following User Says Thank You to Trefoil For This Useful Post: | FRS Justin (12-25-2015) |
#51 | |
I wouldn't recommend running ANY turbo at 12 psi on track, unless you have a significant budget. If the word budget even comes to mind, that's going to be a risky proposition. Get your supporting mods first, and then get the turbo kit. Brakes + cooling, and then turbo. Going the other way around is a recipe for disaster at the track. Too much cooling and brakes = you'll go home and drive another day. Not enough cooling or brakes = bad things happen. |
#52 | |
Just how a turbo without a wastegate or boost controller will just keep increasing boost, you just set up the SC for the SC's maximum, and then drop the boost to your desired amount with the EBC. You can, theoretically, have a turbo car's powerband with supercharger thermal management. This particularly works well if you can stuff a giant centrifugal unit Unfortunately it's a bit cost prohibitive to do with something like the Edelbrock, since you have to modify or replace the manifold.
| The Following User Says Thank You to CSG Mike For This Useful Post: | Trefoil (12-28-2015) |
| Supercharger vs Turbocharger Comparison | Zan | Forced Induction | 33 | 09-26-2015 02:18 PM |
| My autox, track car, DD, FRS | bkblitzed | Member's Car Journals | 35 | 12-01-2013 01:52 PM |
| Comparison between a supercharger and a turbocharger at the same boost level | buditjoenawan | Forced Induction | 50 | 10-04-2013 02:21 PM |
| Track and Autox Video | Dezoris | Tracking / Autocross / HPDE / Drifting | 0 | 05-06-2013 01:38 AM |
