Old 12-21-2015, 05:33 PM   #15
bhmax
Drives: 13 BRZ, 17 Focus RS
Mine does it too. Haven't tried to sort it out yet.
bhmax is offline   Reply With Quote
Old 12-21-2015, 07:57 PM   #16
Euro7R
Drives: 2013 Subaru BRZ
I bought Autoglym Trim Gel and applied it on mines. No rubbing or lifting of the seal strip ever since then. Been over 1.5 years now.
Euro7R is offline   Reply With Quote
Old 12-21-2015, 07:59 PM   #17
BRZnut
Drives: BRZ DGM Limited
I do not know if this stuff works once the problem starts , but I have been using this from the start with no gasket issues. Others have posted good results too:
[ame="http://www.amazon.com/einszett-914806-Gummi-Pflege-Rubber/dp/B004B8GTQG/ref=sr_1_1?ie=UTF8&qid=1450742317&sr=8-1&keywords=gummi+pflege"]Amazon.com: einszett 914806 'Gummi Pflege Stift' Rubber Care Stick - 3.4 fl. oz: Automotive[/ame]
The Following User Says Thank You to BRZnut For This Useful Post:
zc06_kisstherain (12-22-2015)
Old 12-21-2015, 09:30 PM   #18
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
http://www.ft86club.com/forums/showthread.php?t=11682
This has been happening since 2012 including myself. I got it replaced under warranty. If you leave it alone, it will get worse. I don't know how much of a help it will be to put some kind of grease since the rubber piece is already deformed. For mine, I had to get out of the driver seat, go around to the passenger seat, close the door while holding the weather strip, then finally get out of the passenger seat. Otherwise, the window wouldn't close properly.
My warranty is out too now and if this happens again (or the passenger side), I would like to do it myself. So, I'm interested in DIY too.
Old 12-21-2015, 09:32 PM   #19
Trust86
Drives: 2016 Halo FRS
Spit on it
Then put a hello kitty band aid on the seal
Trust86 is offline   Reply With Quote
Old 12-21-2015, 10:38 PM   #20
BRZnut
Aside from using the Gummi liquid, I also ran regular black weather stripping behind the gasket to give it a thicker and more durable feel. This helps keep the gasket in place with less "play" when the window closes over it.
Old 12-21-2015, 10:42 PM   #21
Originally Posted by Trust86 View Post
Spit on it
Please limit shitposting to the general forum and off topic. These are the tech threads.
Tcoat (12-22-2015)
Old 12-22-2015, 12:20 PM   #22
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
mine has same symtoms when rain or humid
Old 12-22-2015, 02:08 PM   #23
Here's a clip I took a while back when I was working on a DIY for window alignment. Compare the height of the indexing to your own. I don't know the vin for the production change but I bet everyone with this issue has an early 13 without the updates applied.
[ame="https://www.youtube.com/watch?v=RVahTymv2T4"]after - YouTube[/ame]
Tcoat (12-22-2015)
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
Window seal cracking ironsurfer129 Scion FR-S / Toyota 86 GT86 General Forum 9 11-29-2014 09:59 PM
window seal deforming mokinbird87 Issues | Warranty | Recalls / TSB 33 10-31-2014 06:14 PM
window seal? ravenblackfrs Issues | Warranty | Recalls / TSB 3 01-29-2014 06:12 PM
Drivers Side Window (Not Seal) Mister Issues | Warranty | Recalls / TSB 20 12-16-2013 03:56 PM
