View Poll Results: Have you had any major issues
Yes 13 10.92%
No 102 85.71%
Yes, but they are related to somthing I did (i.e. aftermarket parts) 4 3.36%
Voters: 119. You may not vote on this poll
Old 12-16-2015, 06:21 PM   #43
ARTBRZ
Aloha!
ARTBRZ's Avatar
BRZ comes with flying death sticks
ARTBRZ is offline   Reply With Quote
The Following User Says Thank You to ARTBRZ For This Useful Post:
go_a_way1 (12-16-2015)
Old 12-16-2015, 07:03 PM   #44
Gaiakai
Gaiakai's Avatar
Drives: '21 Civic Type R
Car's So Good I Bought It Twice
Got an FRS June 2012
After a year I sold it and used the the money I got as a downpayment on a red BRZ Limited. I just hit 33,400 miles driving to work today, and my one major problem with the car is that it still doesn't have a goddamn snail under the hood. Which I'll be fixing Soon™.
"Give a man a match and he'll be warm for a minute. Light a man on fire and he'll be warm for the rest of his life."
Follow me on Instagram!
Gaiakai is offline   Reply With Quote
The Following User Says Thank You to Gaiakai For This Useful Post:
Old 12-16-2015, 07:27 PM   #45
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Details??
Front cam cover is seeping oil slightly.
Not enough to do any damage, but enough to be covered under warranty.
Currently debating if I want to have the dealer install STi engine mounts or not.
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
FRSBRZGT86FAN (12-16-2015), go_a_way1 (12-16-2015)
Old 12-16-2015, 07:54 PM   #46
Crashdummy
too much is never enough.
Crashdummy's Avatar
Drives: 2015 FR-S RS1.0, 2005 Corolla XRS
12,500 and NO issues at all!
This warm weather is making me want to take it out of storage. grrrrrrrr
Too much is never enough.......
2016 Colorado Z71 Trailboss, 2005 Corolla XRS, 1987 Cavalier RS Wagon
Nanako's Mod Thread
Crashdummy is offline   Reply With Quote
Old 12-16-2015, 08:34 PM   #47
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
-alex
May as well once it out
Old 12-16-2015, 08:41 PM   #48
Okay guys, I made this thread to be serious hahahaha, I know you are all jelus the BRZ comes with flying death sticks from Australia but lets try to keep it on topic
Hypocrisy alert Hypocrisy alert
:popc orn:
Old 12-16-2015, 08:43 PM   #49
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
:popc orn:
You have been trolled
Old 12-16-2015, 08:47 PM   #50
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Good point..... @go_a_way1 ......
I cleared off my chatter .......
This post will self destruct shortly ..........
Quoted so it lasts forever
humfrz (12-16-2015)
Old 12-16-2015, 08:50 PM   #51
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I'm gonna add to this I only have 4500 miles and so far the issues have been:
1) The AT downshift issue that plagues the 2015 with hard shifts brought it in at 400 miles to a dealer and they didn't do crap and said they would send there info to toyota, took until 4000 miles at the first oil change for a TSB to be applied to fix it
Fuel Pump chirp (non issue)
Issues essentially caused by me:
Front passenger side had a flat tire, a nail was found in the inner sidewall
Uber thin paint, my trunk has slight scratches from a tree branch falling on it as well as a barely noticeable scratch on my drivers mirror cap that I'm 90% was from someone brushing against it
Front bumper doesn't fit right below the headlight, put it back on in a hurry after installing winjets and I'm waiting on new push pins to replace ones damaged from installing win-jets
Old 12-16-2015, 09:21 PM   #52
stevesnj
stevesnj's Avatar
Originally Posted by Rustyspoon View Post
No problems with my 2013. 23k kms
Not even the crickets!!!
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
go_a_way1 (12-17-2015)
Old 12-16-2015, 10:45 PM   #53
KL
Drives: 2013 SWP BRZ
Originally Posted by radroach View Post
Radio doesn't work anymore because it was reset, and the dealership never gave me an SD card to reprogram it. Subaru of America are true bastards for charging $400 for a new SD card. I wish there was some kind of hack for this.
Is this the Pioneer unit? "Reset" as in it needs a password? If so, there IS a hack..
I bought my BRZ used, someone had previously set a password (prev owner said he hadn't but who else would?)
Anyway, I disconnected the battery one day while installing my catch can and when I started the car back up, the HU needed a password to do literally anything other than power up.
Did a little internet research, loaded a program onto a microSD and used it to find what password had been set, which let me unlock the thing and reset the password.
I still have the files if this is the problem you have with your HU.
KL is offline   Reply With Quote
Old 12-17-2015, 01:55 AM   #54
radroach
Drives: car
Mine isn't pw protected, it asks for the SD card. I don't think mine is a pioneer unit.
Old 12-17-2015, 12:37 PM   #55
DarkSunrise
DarkSunrise's Avatar
No major issues for me so far (23k miles, 20+ track days). List of smaller issues I've had:
- CEL/idle issue. Resolved early on with dealer reflash.
- Touchy passenger one-touch window switch. Could have fixed under warranty but it doesn't bother me enough.
- Fuel pump chirps. Don't really notice them.
- Coil pack failure. Annoying, but happened after numerous track days so I'm not complaining. Relatively easy to fix.
- Melted brake piston dust seals. To be expected with track time.
Given the amount of abuse this car has seen, I'm pretty happy with its durability. I do change out the fluids pretty often and am using an oil cooler. I will also be upgrading to BBK and hopefully decreasing brake temps. So far so good.
2022 BRZ Build
2013 FR-S Build
DarkSunrise is online now   Reply With Quote
Old 12-17-2015, 08:47 PM   #56
radroach
Drives: car
Today it sounded like my dash was falling apart, every bump in the road resulted in a squeak or rattle from it.
Also the valvetrain noise can be a little chattery this time of year.
The South African Feel Good Thread Fish Eagle AFRICA 666 06-16-2018 03:18 PM
Anybody know of a mechanic good with thread repairs? ft86Fan NY / NJ / CT / PA 0 01-14-2014 08:43 PM
Checking in slicktop Scion FR-S / Toyota 86 GT86 General Forum 0 05-15-2013 09:55 PM
Just checking in Jaylyons1 Mid-Atlantic 1 12-02-2012 02:36 PM
Checking out your own car Bu-Tang Scion FR-S / Toyota 86 GT86 General Forum 18 06-11-2012 11:41 PM
