Old 12-16-2015, 02:36 PM   #15
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by Gen3MR2 View Post
I continued to state that that was not the warranty I was calling about, I was calling about corrosion and perforation, 60 month unlimited miles.
Perforation = a hole, rusting all the way through.
The dealer is correct, this would have been under the base bumper-to-bumper warranty.
Your best hope is for this to become an actual hole within 5 years.
-alex
Old 12-16-2015, 02:55 PM   #16
Justin.b
Drives: 13 Hot Lava, 01 Miata, 09 Outback
Still worth talking to ANOTHER dealer since some guys have indeed had stuff like that fixed. Really depends on the dealer though I guess.
Have they done it outside of the bumper to bumper warranty period?
You're in Canada. Your dealers are nicer.
-Justin
Justin.b is offline   Reply With Quote
Old 12-16-2015, 02:59 PM   #17
-Justin
There were a couple of guys on here that had it done outside of warranty yes and the were US. Would certainly take a decent dealer but it has happened.
Suppose it also helps if they have built a rapport with the dealer and approached them in a professional polite manner.
Old 12-16-2015, 03:11 PM   #18
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
The only chance for coverage is if there is an actual rust hole in the metal. Until then, Toyota's not going to pay the dealer and the dealer isn't going to start the stroll don this path.
Until there is a hole, the rust is only an appearance issue in their opinion.
-Justin
There have been cases on the forum where a dealer has don't corrosion and perforation warranty repair out of spite and goodwill, I feel he has a chance as well.
Old 12-16-2015, 03:26 PM   #19
stugray
Drives: 2013 GBS BRZ Limited
The way that panel is "warped" and the way the cracks formed it almost looks as if the body was deformed in that area.
In my other car (also a uni-body) that is called the "longeron" and it takes almost all of the load on the car.
Any chance the car was accidentally taken off-roading, been "mowing the weeds" at the track, ever been stolen or joyridden when you were not present?
In any case it does not look like your run-of-the-mill random body corrosion.
Old 12-16-2015, 04:01 PM   #20
Justin.b
If that's the case, OP should just keep shopping it to dealerships.
The problem is that he doesn't have much leverage at a dealership he hasn't purchased from since they're not really obliged to do it.
-Justin
The Following User Says Thank You to Justin.b For This Useful Post:
FRSBRZGT86FAN (12-16-2015)
Old 12-16-2015, 08:07 PM   #21
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Looks like you slammed the door into something, gotta be more careful of how the passenger closes the door.
Instagram: stimson
Old 12-16-2015, 10:58 PM   #22
pantdino
Drives: Firestorm 2013 FR-S
-alex
I agree. It would be reasonable to call a "perforation" something you can see light thru or push an object thru. Steel that has turned to iron oxide is still there, although it has no strength.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
pantdino is offline   Reply With Quote
Old 12-16-2015, 11:42 PM   #23
Oh, my ...... that's just the start .......
Best stock up on wire mesh and bondo .......
Cole (12-17-2015)
Old 12-17-2015, 09:23 AM   #24
stevesnj
stevesnj's Avatar
I think waiting for a rusty hole is crazy. Contact Scion Customer support, they are very helpful and tell them you didn't expect this to happen and you're disappointing this happened so quickly on a new car and they need to take care of it. The warranty is one thing, but what if it's due to misapplied anti corrosion coating during manufacture and where else on the car is this happening that you can't see. Here's the number...
CALL US
To speak with a Scion Customer Experience Representative, call: 1.866.70.SCION
Mon–Fri 5:00 a.m. – 6:00 p.m. PST
My 2016 Build thread
Old 12-17-2015, 10:28 AM   #25
FRSBRZGT86FAN
CALL US
That's 8:00 AM - 9PM for us EST folks
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
stevesnj (12-17-2015)
Old 12-17-2015, 10:54 AM   #26
I don't know what sort of luck you will have with Scion themselves since the warranty for rust is very clearly for perforation. May have some luck if he can find a sympathetic dealer but doubt there will be any such sympathy from corporate Toyota.
I am very curious as to what went wrong to cause that bubbling and rust though as in has been very rare here and when I checked my winter/salt driven car I found it to still be pristine.
Old 12-17-2015, 10:57 AM   #27
Justin.b
Is there any evidence of damage and/or repair? Can you see body filler under the paint where it's opening up? That would usually be a stuck to the back side of the paint and would be a light color but significantly thicker than the paint itself.
If this is a repair done incorrectly by the dealer before the car was delivered then you may be able to chase them down that way.
-Justin
Old 12-17-2015, 10:58 AM   #28
-Justin
Good call!
Corrosion Warranty Claim aghuman Issues | Warranty | Recalls / TSB 27 04-02-2015 09:40 PM
Safe mods to avoid warranty- feedback/experience? slags BRZ First-Gen (2012+) — General Topics 8 09-19-2014 02:05 PM
Any experience with mod-friendly dealers and warranty? 1Cor10:23 CANADA 8 03-08-2014 09:33 PM
Good warranty experience dave77 Issues | Warranty | Recalls / TSB 9 01-21-2014 01:12 AM
Corrosion on sway bar mounts SubiePig Issues | Warranty | Recalls / TSB 5 10-29-2013 06:01 PM
