#15 | |
Drives: Hydra EMS Powered FRS Raven Black
Now I've tuned a high power NA Miata with ITBs. With a Hydra we got about 175 whp on unleaded race. Apparently this was some sort of record but what do I know I tuned mostly turbocharged setups in the 600+ range . You need a really good EMS (with specific configurations for ITBs) and a lot of knowledge to tune the ITBs well.I know our main focus for the FRS/BRZ is going to be developing the Hydra EMS so that we can turbocharge this engine effectively. Now we may be dropping the compression first and going backwards from there. I definitely want to get the direct injection setup working so we can at least fully tune this engine's variable cam timing, maybe drop our Hydramist system on it, and tune either race gas or E85. I'm just not sure the NA guys are going to drop $2000-2500 on the EMS but I know the turbocharged guys will in a heartbeat. Thanks, Phil Grabow |
| The Following User Says Thank You to Element Tuning For This Useful Post: | ESBjiujitsu (06-06-2012) |
#16 | |
Drives: 13 FR-S, 00 Spyder&Celica, 08 Tundr
Nothing currently on the market is configured to control these particular devices. NOTHING - not a single damn EMS. |
#17 | ||
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
![]() Now if Cobb gets their product to market, that would be awesome... ![]() Regards! |
#18 |
Kuruma Otaku
I remembered seeing this, too.
![]() Separate ECU/DI injector driver according to Perrin. Anyone have any more details on its operation?
Because titanium. |
#19 | |
What's holding me back right now is an ECM IO diagram. I couldn't get one yet on the Subaru Technical website so if anyone has access please let me know. Thanks, Phil Grabow |
#20 |
Drives: FR-S|(2)AE86|TA22|E30M3|E36M3|BPLeg
Hey Phil, good luck. Had several friends with Hydras in there Subbies and all were happy, driveability was also very good.
I spoke to a contact at a large ECU company that we all know (though I am not sure I can disclose ) and was informed that they had an project lined up with the V8 IS-F (a very similar implementation of fuel system) and they told me that its if fact, very complex even for them, and they were not able to do it yet! (it was a swap of the IS-F engine)Direct injection as the only fuel delivery wasn't a problem for them, but the combination they found in the IS-F was a problem. Waiting to hear back on BRZ/FRS developments. |
#21 |
Kuruma Otaku
^ Guys with bike tuning experience may be helpful. The phasing of the DI and port may be similar to the port and outboard 'showerhead' injectors that some bikes use.
Because titanium. |
#22 | |
It's honestly amazing how much ground I've made already with this car and we have the connectors, dual AVCS, and the DBW stuff already worked out. Unlike the IS-F there is much less integration with the FRS/BRZ as far as the CAN systems and the transmission (We are not really working towards the Auto integration yet just the manual). The CAN bus stuff can be difficult and we've just about got it all dialed for the 08+ STis it will also require work on this car. Until we fully developed the CAN integration on the STi we ran the OEM ecu in parallel so that it could report some of the dash functions like speed and coolant temp. It's possible on the early release of the FRS/BRZ ECU we'll do the same. If demand doesn't materialize then it's going to be hard to justify the engineering costs associated with cracking all this stuff and for many manufacturers it just boils down to dollars and cents. I don't want abandon the NA guys as I I've discovered hidden power in the dual AVCS systems for the STi and I could likely do the same for these cars. With integration of the Hydramist water/meth system and or race/E85 I think I can get substantial power gains. For high power NA to work with the high compression however we need those direct injectors. |
#23 |
Drives: car
The only individual electronic throttlebodies in use for street cars that I can think of are on high end engines like what you find on the S65 engine for for BMW E60 M5 or the 1LR-GUE engine for the Lexus LFA.
What you have here is a set of butterfly valves attached to a common shaft for each bank. Each bank needs its own throttle position sensor and a control method needs to be devised. For BMW, they control the two banks independently and coordinate between the two banks using a high speed data bus. One of the main advantages is that the throttle valves are placed downstream of the plenum. Therefore the software does not need to model a large delay/time constant to account for the filling of the manifold as charge air is moving from the airflow meter towards the cylinder. This issue of time constants is one of the reasons why people run into fueling problems when they install a front mount intercooler on their WRX. The internal airflow model gets messed up. If you are able to manufacture a part that works, it would still not be easy to control ITBs consistently. Of course you could do some basic lookup table but it would be an uphill climb to make it behave on the street. Who knows how many man hours went into writing Toyota's software for ITB control. |
| The Following 3 Users Say Thank You to arghx7 For This Useful Post: |
#24 |
Shipping to Hawaii?...
Drives: '13 Asphalt FR-S
#25 | |
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
http://www.purcellperformance.com/Te.../FT86_full.jpg |
| The Following 2 Users Say Thank You to JP For This Useful Post: | markmatley (06-07-2012), old greg (06-07-2012) |
#26 | |
#27 | |
I think that a solid tune along with some hot cams will be a tight setup for many folks... Cheap no, but pure? YES. a few key mods, along with very comprehensive variable valve timing control (built into said tune) could make a very street friendly setup with wicked mid and top-end power. I might have to give you guys a jingle shortly
#28 | |
![]() The problem I see is not with the implementation from the technical standpoint, its available now... its going to be the cost. Very hard to justify for this car... the ITBs will be costly, let alone the ECU solution. If the demand is there, along side the turbos and S/C... It might happen, probably see it from a company like Toda. |
| Southeast sound OFF! | OldSkoolToys | Southeast | 133 | 05-25-2012 01:31 AM |
| 86 Sound System | Skorov | AUSTRALIA | 25 | 05-09-2012 05:51 PM |
| GT86 Sound | joe | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 03-22-2012 06:03 AM |
| New Video with better sound | Sabastian | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 22 | 08-04-2011 10:30 AM |
| What should the FR-S sound like? | 1660 | Off-Topic Lounge [WARNING: NO POLITICS] | 26 | 07-31-2011 02:33 AM |
