Old 12-09-2015, 08:39 AM   #15
mcrane
mcrane's Avatar
The more I have been driving it, the better it has gotten. Not sure if getting used to it, or it is being "broken in" more.
mcrane is offline   Reply With Quote
The Following User Says Thank You to mcrane For This Useful Post:
Chrisgalactic (12-09-2015)
Old 12-09-2015, 12:45 PM   #16
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Lol I did change my fluids to Motul, but other than that first and 2nd have been pretty damn clunky especially 2nd gear
Alltezza is offline   Reply With Quote
Old 12-09-2015, 12:54 PM   #17
Trust86
Drives: 2016 Halo FRS
Slap a hello kitty band aid on the transmission
works wonders
Trust86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Trust86 For This Useful Post:
Chrisgalactic (12-10-2015), dvasqu01 (12-09-2015)
Old 12-10-2015, 01:44 AM   #18
dvasqu01
dvasqu01's Avatar
Drives: Scion FRS Whiteout
Originally Posted by RichardCarm View Post
I actually technique for do a little supplementary survey about this.Provides i appreciate you for talking about this valuable helpful data files.a extremely amazing written piece, prepared to accept. document dearly loved perusing nearly every small important information during this present. I'm so so completely satisfied when i take a look at accordingly important piece of content, thank you highly, please make sure to maintain the best perform. I like what we maintain in this case, true love what you really stating and exactly how anyone tell you it. You are insanely putting it exciting people just have enable you to ensure that is stays a good idea This process specified slice definitely probably did option the sunlight to do with for me personally exactly where this unique topic applies. Unfortunately today close to there is certainly at least one element I'm not truly far too at ease with in addition to despite the fact I aim which will reunite through the essential style of one's place, make it easy for all of us find out precisely what the enjoyment with the potential customers ought to say.Beautifully successfully done. We appreciate you covering ! very interesting just how much is it possible to locate a interpretation ?If feels like all bona fide value for your dollar intended for space search is a reasonably options away from. My spouse and i visualise extra affiliate marketers is often forex currency trading for those strength in addition to position they acquire by just correlation more than anythingThanks to find going over your main review. I seriously preferred this task. As i fit one of the links to help you my very own web site to at this website thus other types can easily see the application Brillaint this is definitely wonderful, due!
Wtf!!💁🏼
I'll give you the rice noodle😘
dvasqu01 is offline   Reply With Quote
Old 12-10-2015, 02:11 AM   #19
Brings to mind:
"The infinite monkey theorem, which states that a monkey hitting keys at random on a typewriter keyboard for an infinite amount of time will almost surely type a given text, such as the complete works of William Shakespeare."
Old 12-10-2015, 10:03 PM   #20
Originally Posted by JoeC View Post
just once I would love to drive someone's car that says they have this issue. Perhaps my car doesn't have the issue but I guess I'm skeptical of others that do. This transmission is definitely the tightest, most affirmative transmission I've ever owned. 1st to 2nd, it just clicks right in. Granted, you can't just pull it straight down with no resistance but you move it in motion with all the other parts.
Has anyone driven multiple variants to confirm that some of these cars shift significantly worse than others?
Now shifting gears in my 1-ton Silverado, that takes some time and patience and the gear lever is longer than my leg, hahha
Simple. While it's stone cold, for your 1-2 shift, pause in neutral for a second. Then you will immediately understand.
Old 12-10-2015, 10:43 PM   #21
JoeC
Drives: Subaru BRZ Limited
thanks. I'll try it tomorrow and see if I notice it.
JoeC is offline   Reply With Quote
Old 12-10-2015, 11:17 PM   #22
It's pretty dramatic. @Tcoat
http://www.ft86club.com/forums/showt...51#post2448051
Old 12-10-2015, 11:40 PM   #23
JoeC
crazy. I've never seen that thread. thanks for linking it. first I'm gonna try this in my BRZ then I'm gonna try it in my truck and my jeep.
edit: I guess I had seen that thread but not tcoat's post...
The Following User Says Thank You to JoeC For This Useful Post:
Ultramaroon (12-10-2015)
Old 12-11-2015, 08:36 PM   #24
JoeC
well, I tried it and did notice anything...
shifting from 1st to 2nd:
accelerate in 1st up to 4k RPM
clutch in
pull down to neutral
clutch out
let revs fall
clutch in
pull into 2nd
it went into 2nd just fine. admittedly it doesn't like to downshift into 1st without rev matching but when I match it goes right in.
maybe I'm just lucky
Old 12-11-2015, 08:47 PM   #25
clutch in
clutch out
let revs fall
clutch in
pull into 2nd
I meant just with the clutch depressed, pause for a bit in neutral, then go for second gear. Even after 20K miles, if I don't get through neutral quickly enough, that sucker won't go in unless I yank extra hard. Higher gears are fine but second gear is still short enough that the synchro has trouble spooling the input side through the thick oil.
For the record, I have zero complaints about this transmission, so far. I just instinctively play around to see what technique gets me through the gears using the lightest touch possible. That knowledge, IMO, applies just as well to the more "spirited" driving.
That second part was just extra opinion for whomever. You double-clutch into a rolling first so we're pretty much on the same page.
jcw99 (11-16-2019), JoeC (12-12-2015)
Old 12-12-2015, 06:29 PM   #26
Chrisgalactic
Chrisgalactic's Avatar
Drives: White out Scion Frs
That "pause" works wonders never try'd it before and holy shit does it make a difference! Thanks a lot Ultramaroon
Sent from my SAMSUNG-SM-G900AZ using Tapatalk
Chrisgalactic is offline   Reply With Quote
Old 12-15-2015, 12:42 AM   #27
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
I have fewer than 2000 miles on my Subarota. In that time, though, I've noticed it shares some transmission quirks with my '06 F150 DD. The most notable is, it does NOT like to be forced into a shift. If I'm sitting at a light with the truck in neutral and the light turns green, a quick stab on the clutch pedal and a shove of the shifter into first will yield exactly nothing. It will simply NOT shift into first. On the other hand, a gentle push of the lever leaving time for the various parts to do what they are supposed to do results in a smooth engagement of the gear.
My particular BRZ is very similar. It responds very well to a gentle, but firm, hand on the shifter. Give it a little time. Sometimes the fastest way to get something done is to slow down a little.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following User Says Thank You to Capt Spaulding For This Useful Post:
Chrisgalactic (12-15-2015)
Old 11-16-2019, 04:31 PM   #28
I can see how it's easy for the casual reader to misunderstand my reply to JoeC. I am not advocating for pausing between first and second. I was explaining how to create the condition that causes people to have trouble shifting into second when it's cold.
Different techniques yield different results because physics.
First and Second gears are clunky... mcrane Engine, Exhaust, Transmission 0 12-05-2015 12:39 PM
Shifter feels clunky when going into 5th Jfheisenberg Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 16 04-04-2015 08:41 PM
Anybody change rear gears or trans gears yet? ramosryan Scion FR-S / Toyota 86 GT86 General Forum 2 06-13-2014 01:48 AM
Rear rattle/clunky noise Hawk77FT Issues | Warranty | Recalls / TSB 8 08-18-2013 07:59 PM
