#85 |
Drives: FR-S Whiteout
Okay. I will try that. Although those 2 pulls in the first graph were using different headers along with cam timing. The lower output one was a Tomei El header. If you look at the red trace on the 2nd graph where I began the pull from lower RPM the torque is actually a bit higher. Unfortunately I never did do a pull from under 2000rpm with the tomei.
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 11-29-2015 at 11:14 AM. |
| The Following User Says Thank You to solidONE For This Useful Post: | thambu19 (11-29-2015) |
#86 |
Drives: Scion FRS
@solidONE
Yes the AFR for best torque changes with engine to engine design and with engine speed to another speed. From experience it goes from leaner than 12.5 at lower speeds to richer at peak power. The 11.8 I suggested was to keep exh temp below 900C (some reasonable safe limit) IF you feel your header, exh valves etc can take hotter temp you can go leaner than that. On my stock FRS with a LIVE CAT no way I would go leaner than 11.5 anywhere just to be safe. |
| The Following User Says Thank You to thambu19 For This Useful Post: | solidONE (11-29-2015) |
#87 |
Drives: Scion FRS
Contrary to popular belief engine knocks slightly more with slight enrichment. This is because of slightly faster and hotter combustion. It's called water gas shift reaction
Sent from my HTC One_M8 using Tapatalk Last edited by thambu19; 11-29-2015 at 08:29 PM. |
#88 | |
Drives: Scion FRS
Sent from my HTC One_M8 using Tapatalk Last edited by thambu19; 11-29-2015 at 08:25 PM. |
#89 |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
@solidONE, thanks for posting those tables. I'd lost the set of tables developed by someone else for the long tube header. Now I can start from those to develop a set for the Phantom ESC and long tube header owners.
If I say yes, will that make you think I understand?
#90 | |
What about in low/mid-load situations? Does this still hold true? Specifically the areas when I have the fueling dialed slightly richer than stoich at 60.~70 loads, low to mid rpms. Or, does this only apply to peak loads going WOT or close to WOT?
Intent > Content
cowardice is the mother of cruelty. |
#91 | |
Drives: Scion FRS
It always holds true. If going richer the AFR should be richer than ~13.3 to really see benefits of knock resistance but operating slightly rich can improve combustion and you will feel a smoother engine but not good on emissions
| The Following User Says Thank You to thambu19 For This Useful Post: | solidONE (11-30-2015) |
#92 | |
Drives: FT86
If you guys have tactrix you can monitor cat temp for B01C roms. ECU uses o2 sensor heater current to calculate temps Ram_cat_temp FFF8DBD4 add this to your logcfg.txt file paramname = CAT_Temp paramid = 0xFFF8DBD4 isfloat = 1 else you can use Techstream to monitor I'm not seeing much over 720C on E85 hot day hard uphill mountain run AFR target about 12.3 high rpm/load probably be a good parameter for shiv to add to OFT logging |
| The Following User Says Thank You to steve99 For This Useful Post: | solidONE (11-30-2015) |
#93 | |
About the cam timing, would you recommend changing the exhaust timing to reduce overlap on my current tables to being with? Or should I reduce intake cam advance? Or a bit of both? You mentioned reducing the overlap, are you talking about the 3200~4800 range, the 4800~6100rpm range, or just all of it? lol http://datazap.me/u/solidone/plm3-ca...1628-1595-1658 @steve99 I've not had the chance to pick up a tacktrix yet, although I'd assume the secondary cat wouldn't be as susceptible to damage from overheating since most stage 2 setups (including mine) do not run a cat on the header. I've actually measured surface temps on the exhaust and it runs much much cooler after the over pipe. Not saying that it's in any way "cool," but it does not get nearly as hot as the header.
Intent > Content
#94 | |
Drives: Scion FRS
Sent from my HTC One_M8 using Tapatalk |
| The Following User Says Thank You to thambu19 For This Useful Post: | steve99 (11-30-2015) |
#95 | |
Drives: Scion FRS
The reason you are running colder (although 720C sounds pretty cold to me) is because of E85. E85 will cause colder exh temp due to the additional spark. The more spark added in the colder the exh and vice versa. Same with cams. The earlier its opened the hotter it is. I am wondering if ECU ever uses this value to manipulate fueling. Like adding extra fuel on top of open loop fueling if the temps are too high. Will need those running headers to tell us what temps they are seeing for exh and cat. |
#96 | |
Drives: Scion FRS
#97 | |
Drives: FT86
I will try to plug my tactrix into someones car with stock header on petrol and see what the temps are |
| The Following User Says Thank You to steve99 For This Useful Post: | thambu19 (11-30-2015) |
#98 | |
![]() The exhaust cam retard table is actually not hugely different than the stage 1 OTS tables designed for use with factory headers. Although the OTS stage 2 tables actually run even more exhaust retard than the stage 1. I'll have to see if I can find the stock rom see what they look like. Difference compared to OTS STG1: ![]() Difference to OTS STG2 EL: ![]() Thanks again for all the pointers, BTW. ![]() Edit: Yup the intake cam is staying advanced further than designated by the cam tables. 4th gear pull just now: http://datazap.me/u/solidone/af-lear...zoom=2699-3008 3rd gear pull in the same log where it drops down to 37.5* at 4800 rpm. Still not at 35* when it was set to on the table: http://datazap.me/u/solidone/af-lear...zoom=1595-1732 There's got to be something else effecting the cam timing that we don't yet know about.
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 12-01-2015 at 03:10 AM. |
| Timing chain issue? | Hardpack | Issues | Warranty | Recalls / TSB | 14 | 01-10-2016 11:25 PM |
| AVCS failures? | hmong337 | Forced Induction | 26 | 02-12-2015 03:01 PM |
| Stock Rom: Timing + Learn Value | sw20kosh | Software Tuning | 7 | 12-11-2013 07:09 PM |
| E85, Boost and Ignition Timing | jamesm | Software Tuning | 23 | 12-11-2013 02:19 PM |
| Timing belt shredded..?! | drei | CANADA | 5 | 12-06-2013 05:54 PM |
