#113 |
Drives: GT86
I specifically drove and listened for cluncks and to see if I could notice droop issues or the fronts topping out because of the preload. No such thing. But wouldn't want to run much more preload, there is no top out bump stop, just metal to metal. Remaining droop travel in front is approx 40mm or bit more than 1,5", that usually is plenty for road driving.
If I were you I'd try yours without the preload and see what that does. |
#114 | |
Drives: 2013 FR-S Argento
Maybe I do? It's not much preload but it's easy enough for me to reduce to 0 preload and try it out.
| The Following 2 Users Say Thank You to bfrank1972 For This Useful Post: | CSG Mike (11-25-2015), Trettiosjuan (11-26-2015) |
#115 | |
Drives: GT86
Edit: An alternative set-up that keeps most of the height adjustability would be just to use a 7kg spring of the original lenght and without preload, it would still improve bump travel by having the damper sit closer to halfway the travel with the weight on the car. Last edited by Trettiosjuan; 11-26-2015 at 06:42 AM. |
#116 | |
Drives: GT86
#117 | |
That's where I'm currently at, but I'm wondering if the 4mm at the rear is causing the light clunk noise in the rear - possible the coils are contacting each other. If I can find time this weekend I'll reset the rear preload/height and see if that changes anything. Otherwise I have no complaints, feels great, and the extra camber afforded by the front plates really liven up the front end. Sent from my iPhone using Tapatalk |
#118 |
Drives: 2013 FR-S Blue MT
Do these have exposed adjusters sticking up through the carpet in the trunk like the Flex-Z's?
#119 |
Drives: GT86
Yes. I threaded wheel lugs over so that luggage can't mess with damping adjustment...
| The Following User Says Thank You to Trettiosjuan For This Useful Post: | CxG (07-26-2017) |
#120 |
Drives: GT86
#121 |
Drives: Toyota GT86
Hi
Does anyone know if these can be used with standard top mounts ? The reason being my local sprint regs do not allow modified mounts with spherical bearings. Thanks |
#122 |
Drives: Toyota GT86
#123 |
Drives: GT86
#124 |
Drives: 10 Series Scion FR-S
Installed Flex A this weekend, and I must say I love this coilovers, after running lowering springs for over a year now and the ride was just getting unbearable day to day.
I'm currently running 9mm of preload front and 6mm of preload in the rear with 9 clicks from stiffest setting and the car feels so comfortable. I will post how well it handles at the track once I go on novermber, but as a baseline, my car was on Swift spec-r (4.4K front, 5.3K rear) with koni shocks and it was very tail happy with a bit of body roll... so far on the street the teins make the car feel way more planted, but will give a full review once I take it to the track, and yes, I know this are not meant to be corner carving coilovers, but its a compromase I had to make to DD the car without destroying me. |
#125 |
Drives: 2013 BRZ Limited
just installed a pair the other night. I only got to take them around the block for a bit but instantly felt better than the eibach sportlines i was on and potentially even better than stock. Had them set about 8 clicks softer than the hardest setting. Going to put them to the test at an autocross next weekend and will update with the results after.
#126 |
Drives: 2017 Toyota 86 Halo
Bump, anyone have any updates/reviews?
| Tein Flex A and Z!!! | breadcrumbz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 25 | 05-24-2016 04:44 PM |
| Tein Flex Z | Bigmaxy | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 01-27-2015 04:22 AM |
| WTB - Tein Street Flex and some LCA's | Sugi | Want-To-Buy Requests | 1 | 01-25-2015 04:12 PM |
| FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut | kvnchu | Brakes, Suspension, Chassis | 26 | 12-09-2013 02:10 PM |
| FS: Tein Flex Coilover | Jade 86 | Brakes, Suspension, Chassis | 43 | 06-15-2013 10:35 PM |
