Old 11-12-2015, 11:35 PM   #15
Hawk77FT
Drives: GTS 86
Do you trust they REALLY did replace the TOB .. ??
Maybe they put it in backwards ... ??
Maybe they replaced it with another old one, that looked OK....??
Pay me no never mind .....
The new clutch came with a new TOB. Also, they have put everything they have changed in a package to look at. The plate was on its way out.
All bearing and stuff been changed with brand spanking new ones.
Hawk77FT is offline   Reply With Quote
Old 11-12-2015, 11:57 PM   #16
hmmmm..........well, I hope it's not the transmission input shaft bearing .....
That would require major surgery.
Hawk77FT (11-12-2015)
Old 11-12-2015, 11:58 PM   #17
Hawk77FT
Drives: GTS 86
It might actually be that I reckon
Sent from my HTC_0P6B using Tapatalk
Old 11-13-2015, 07:58 PM   #18
Tonypepatone
Drives: 2013 ScionFRS
I don't think pushing in the clutch would effect this though.
Sent from my Nexus 6 using Tapatalk
Tonypepatone is offline   Reply With Quote
Old 11-13-2015, 09:05 PM   #19
Why wouldn't it .... ??
If you push the clutch in ..... the engine is disconnected from the transmission, thus the input shaft would quit turning, thus a bad bearing wouldn't make any noise.
Unless, I've got it backwards ......
Old 11-13-2015, 09:32 PM   #20
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
I have this noise too. I thought it's normal. I got the throw-out bearing replaced for another reason, and that didn't get rid of this noise.
http://www.ft86club.com/forums/showthread.php?t=28296
Old 11-15-2015, 06:20 PM   #21
Hawk77FT
Drives: GTS 86
Sounds like it is. Kinda...low revs, around 600 rpm? When cold?
Old 11-16-2015, 11:10 AM   #22
shellslinger
Drives: Whiteout FRS
Did you change your manual transmission fluid to motul?
shellslinger is offline   Reply With Quote
Old 11-16-2015, 03:11 PM   #23
Sigh-on-Rice
Mine doesn't happen at 600. It's more like 650-700, so it only makes this noise when the A/C compressor is running. After everything is completely warmed up, the noise goes away.
The Following User Says Thank You to Sigh-on-Rice For This Useful Post:
Hawk77FT (11-16-2015)
Old 11-16-2015, 04:13 PM   #24
Hawk77FT
Drives: GTS 86
Did change it few times already, same result
Old 11-16-2015, 04:48 PM   #25
shellslinger
Ah I see, I've been having the cold morning chatter as well. But this only occurred after I had changed the stock fluid to Motul.
The Following User Says Thank You to shellslinger For This Useful Post:
MisterSheep (11-16-2015)
Old 11-16-2015, 06:13 PM   #26
Hawk77FT
Drives: GTS 86
Have you taken it to the dealer? Or have it checked by anyone?
Old 11-16-2015, 07:01 PM   #27
Late to the party. There is always some backlash clatter in the gearbox at low rpm, especially for the light flywheel crowd.
I have heard a couple recordings of what sounds like an actual knock as the gearsets rotate in neutral. I don't know what that is but if it wasn't there before and is there now, something in the gearbox changed.
Can you post up a clip?
Old 11-16-2015, 07:10 PM   #28
Sigh-on-Rice
No, I thought this is a normal noise, so I haven't taken it to the dealer. I'm pretty sure it was making this noise since it was brand new. It just got louder after the transmission fluid was changed, but it happens to other people too. So, I'm thinking it's normal and something I don't need to worry about.
Valvetrain chatter on KW SC FRS nlowell Issues | Warranty | Recalls / TSB 4 05-03-2015 12:20 PM
Flywheel Chatter samisons Issues | Warranty | Recalls / TSB 13 12-05-2014 10:30 AM
Drivetrain chatter on cold mornings? jm1681 Issues | Warranty | Recalls / TSB 7 10-24-2014 11:48 AM
Diff chatter when cold? BRZrkr BRZ First-Gen (2012+) — General Topics 1 06-23-2014 10:17 AM
Odd Chatter Noise? Chrisposey Forced Induction 5 05-05-2014 10:37 PM
