Old 11-09-2015, 01:08 AM   #1
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Car over boosted tonight : (
Was doing 2nd gear pulls for log and hit about 20 psi on a 7.5 psi map smh: ( lots of smoke and car won't start now ...
Sent from my SM-N920T using Tapatalk
SoCal80six is offline   Reply With Quote
Old 11-09-2015, 01:15 AM   #2
azynneo
azynneo is offline   Reply With Quote
Old 11-09-2015, 01:24 AM   #3
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Time for a V8!
The Following User Says Thank You to EAGLE5 For This Useful Post:
Pat.Thornton (11-09-2015)
Old 11-09-2015, 01:24 AM   #4
Trac Toy
Trac Toy's Avatar
Time for a new piston or four...
Either torched a hole in em or crushed the ring lands I would think...
.o0+Eric+0o.
2016 Chrysler 200S 3.6
2013 FRS 6MT
Trac Toy is offline   Reply With Quote
The Following User Says Thank You to Trac Toy For This Useful Post:
wparsons (11-10-2015)
Old 11-09-2015, 01:38 AM   #5
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Originally Posted by jsimon7777 View Post
Time for a V8!
Would be better and less stressful
The Following 2 Users Say Thank You to SoCal80six For This Useful Post:
Dream20b (11-09-2015), EAGLE5 (11-09-2015)
Old 11-09-2015, 01:40 AM   #6
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Yea it sucks only should've been running 7.5 psi but it kept going up. Hoping rod didn't go through block seen a little oil not sure if it came from dump tube or what.
Old 11-09-2015, 01:46 AM   #7
EAGLE5
Dismember
EAGLE5's Avatar
I know this sucks, but it is also an opportunity to be more awesome than ever before. I'll just leave this here:
http://www.cxracing.com/mm5/merchant...ry_Code=ESKSUB
SoCal80six (11-09-2015)
Old 11-09-2015, 01:49 AM   #8
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Thanks man appreciate it and that's very true always room for improvement.
Old 11-09-2015, 03:31 AM   #9
Docmattic
Drives: GT 86
That sucks mate good luck with the rebuild or whatever you choose to do.
If you don't mind me asking what kit were you running?
Docmattic is offline   Reply With Quote
Old 11-09-2015, 03:51 AM   #10
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Was running a maperformance kit with precision 5858 turbo
Old 11-09-2015, 03:53 AM   #11
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Been running great for the past month but switched map to run 7.5 on e85 instead of 11.5 and for some reason over boosted tonight.
Old 11-09-2015, 07:09 AM   #12
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
I'm interested to know what vacuum line popped off. Evap?
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 11-09-2015, 07:11 AM   #13
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Dat China Express quality though...
The Following 9 Users Say Thank You to Sportsguy83 For This Useful Post:
CSG Mike (11-09-2015), DocWalt (11-09-2015), Freeman (11-09-2015), Lonewolf (11-09-2015), NyC Zn6 (11-09-2015), raven1231 (11-09-2015), RobertPaulson (11-09-2015), SoCal80six (11-09-2015), wparsons (11-10-2015)
Old 11-09-2015, 07:12 AM   #14
Sportsguy83
Drives: Limited BRZ
Your tune should have had over boost protection built into it, extremely easy for a tuner to set it up as long as you have an aftermarket MAP sensor....
(Assuming you're tuned with Ecutek)
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
rb6freak (11-09-2015), wparsons (11-10-2015)
Boosted's BRZ Boosted Member's Car Journals 41 11-05-2018 09:32 PM
About to be boosted! willharp360 Forced Induction 18 06-04-2015 10:15 AM
Boosted! FRS-cotty Northwest 21 03-13-2015 10:02 PM
My Boosted BRZ protpibe Member's Car Journals 84 09-22-2014 03:26 PM
Boosted BRZ mike the snake Member's Car Journals 3 12-28-2013 11:11 AM
