#15 | |
Drives: SWP BRZ
just give it a shot. nothing to lose but time. likely they won't do anything if your car does not have any issue |
| The Following User Says Thank You to zc06_kisstherain For This Useful Post: | whataboutbob (09-29-2015) |
#16 | |
AutoX-10/10ths every run
| The Following User Says Thank You to whataboutbob For This Useful Post: | strat61caster (09-29-2015) |
#17 |
disconnected main harness connectors on top rear of motor and used electrical contact cleaner on both ends of each connector. No more CELs at this point, but still getting lots of misfires. Cyl 4 still has the oem original coil. 1-3 have revised coil packs. Going to order a new coil for 4 and see what happens with the misfires.
Note, this is NOT tune related. I've run these tunes for a while without issue.
#18 |
I have also just started getting P0351 at the local track and it seems to happen at the end of the session. Engine runs and feels fine, but the code has come up twice, once for each of the first and second sessions. Engine is completely stock, and the car is one of the early production models (delivered in 2012), besides crickets this is the first issue that's come up.
Sounds like it's not uncommon, and it's just due to the coil packs themselves going bad. I don't mind throwing some money at parts to fix it myself, so if anyone has 100% resolved this please lend some insight! |
#19 |
Drives: 2013 FRS
Oil cooler
#20 | |
Drives: Scion FR-S, Ultramarine
#21 | |
Drives: bmw
PointMeBy - auto enthusiast / 86 / car blog - https://www.pointmeby.com
IGoByPlane - travel/credit/auto experience blog - https://www.igobyplane.com |
| The Following User Says Thank You to sickmint79 For This Useful Post: | wheelhaus (10-26-2015) |
#22 |
Ok, I just poked through the other mini threadzilla talking about the similar/same issue, coil packs, misfires etc. Consensus appears that replacing the coil packs is the only solution, even if the problem creeps up again. Silver lining is that it's an easy fix and not indicative of pending doom or anything.
| The Following User Says Thank You to wheelhaus For This Useful Post: | Bonburner (10-27-2015) |
#23 |
Kurenai Samurai
Drives: Red and manual
i converted my car to a gear driven distributor with a cap/ rotor and plug wire setup. works now. little more ohm resistance than when i had the coil packs but hey it got rid of the cel.
#24 |
So we swapped in the replacement motor and didn't change any electronics and the car is running fine now. Suspect one or more burned exhaust valves but have yet to tear down the old motor to verify.
#25 |
Drives: Raven FR-S 6M
I'm having a hard time believing this. Please post some pics.
“The World is Flat”
[||•]=(86)=[•||] |
| The Following User Says Thank You to Apoc For This Useful Post: | Thrustin (01-09-2019) |
#26 |
Kurenai Samurai
#27 | |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
EDIT: Found it. Doesn't seem to mention anything about the wiring harness. ![]() The TSB does mention misfire DTCs but it looks to be just an updated TSB about the old wandering idle issue which was related to cam sensor/sprockets and early ECU calibrations which was mostly all fixed and I haven't seen the issue persist since.
| The Following 3 Users Say Thank You to ATL BRZ For This Useful Post: |
#28 | |
Lap time enthusiast
Drives: Asphalt '13 FR-S 6MT
@ATL BRZ |
| The Following User Says Thank You to raul For This Useful Post: | ATL BRZ (11-19-2015) |
| CEL P0351 Ignition Coil "A" Primary Control Circuit/Open | romin | Engine, Exhaust, Transmission | 468 | 11-26-2021 04:05 PM |
| CEL P0301, P0351, and P0172 | Darryljr11 | Issues | Warranty | Recalls / TSB | 16 | 06-07-2015 06:37 PM |
| ignition coil pack #2 and #3, dealer won't cover | vestal52 | Issues | Warranty | Recalls / TSB | 28 | 10-16-2014 11:24 PM |
| Ignition Coil C replacing - need assistance | Synack | Issues | Warranty | Recalls / TSB | 8 | 09-09-2014 03:35 PM |
| P0354 Ignition Coil Malfunction Trending | Gords_zenith | Issues | Warranty | Recalls / TSB | 8 | 05-15-2014 01:41 PM |
