go_a_way1
Old 11-01-2015, 04:23 PM   #9605
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by vfrqqq View Post
So my ESC is still not engaging when my PROcede controller is conneceted to the system. I went through and confirmed that I do have continuity on all of my connections on the PROcede wiring harness and tap points. I also confirmed that the PROcede controller has 12VDC on the red wire. After check all that, I also looked at whether the ESC controller is seeing voltage on the one signal wire from the PROcede controller. With the PROcede disconnected from the ESC controller (i.e., the WOT switch was connected up to the ESC controller so that the ESC didn't spool up--see below), I measured the voltage between the signal wire and ground while applying the throttle and with the engine running and observed no discernable change in voltage. So I’m guess that is probably why my ESC isn’t engaging with the PROcede installed; the ESC controller doesn't seem to be seeing any signal from the PROcede. I still haven’t confirmed whether my PROcede controller already has a throttle map loaded, but I’m hoping to solve my problems without having to lug my PC and monitor over to my garage. Beyond this, I’m not sure what I can do to troubleshoot my PROcede controller.
Incidentally, the ESC appears to spin up on its own when the ignition is in the ON mode and when the WOT switch or the PROcede controller is physically disconnected from the ESC controller—perhaps because there is no signal to the ESC controller? I'm not sure whether j_Zer0 and I are seeing the same situation, just different circumstances.
You need to set one of the parameters on the procede. It's multiple pages back. I'll try to find the picture I made.
Installed Mods:
Old 11-01-2015, 04:24 PM   #9606
Sojhinn
Sojhinn's Avatar
Here you go:
https://drive.google.com/open?id=0B1...VlGOG5lV1dqWE0
https://drive.google.com/open?id=0B1...G5NRC10a2FoenM
Sojhinn
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
vfrqqq (11-01-2015)
Old 11-01-2015, 04:42 PM   #9607
vfrqqq
Ultra Senior Member
vfrqqq's Avatar
Drives: 2014 BRZ Premium, WRB
Originally Posted by Sojhinn View Post
Awesome! I'll hook up the PROcede to my PC and see if that doesn't fix it.
vfrqqq is offline   Reply With Quote
Old 11-01-2015, 08:27 PM   #9608
vfrqqq
Ultra Senior Member
vfrqqq's Avatar
Fixed!!
The PROcede controller is soooo much better than the WOT switch!
The Following 2 Users Say Thank You to vfrqqq For This Useful Post:
Shiv@Openflash (11-02-2015), TM (11-02-2015)
Old 11-02-2015, 10:33 AM   #9609
Kpage
Kpage's Avatar
Drives: 2015 FRS Release Series 1.0
New List
Hey Guys, can we get an updated list? the last one I saw was in june-july. and I know that several have gone out and new users added.
Thanks!
KP
Kpage is offline   Reply With Quote
The Following 5 Users Say Thank You to Kpage For This Useful Post:
BBDGriptonia (11-02-2015), GT86meMR2 (11-02-2015), rhythmM (11-03-2015), stevo585 (11-02-2015), Yoda (11-02-2015)
Old 11-02-2015, 12:19 PM   #9610
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Fixed!!
Right on
Shiv@Openflash is offline   Reply With Quote
Old 11-02-2015, 02:11 PM   #9611
Yoda
Drives: Crystal Black BRZ(Sophia)
Thanks!
KP
This times 10
Yoda is offline   Reply With Quote
The Following User Says Thank You to Yoda For This Useful Post:
Old 11-02-2015, 03:04 PM   #9612
Kpage
Kpage's Avatar
I just want to go fast(er) than I do now...
The Following User Says Thank You to Kpage For This Useful Post:
DAEMANO (11-03-2015)
Old 11-03-2015, 03:29 PM   #9613
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Originally Posted by Yoda View Post
This times 10
I probably will be next person to have ESC...
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
Old 11-03-2015, 03:56 PM   #9614
Yoda
How are you so sure. Did they send you an email
Old 11-03-2015, 04:24 PM   #9615
Kpage
Kpage's Avatar
I thought I saw yours was on the way already. :-)
Sent from my SM-G900V using Tapatalk
Old 11-03-2015, 04:28 PM   #9616
iJeff
iJeff's Avatar
Drives: 2016 Raven FR-S
This times 10
Lists aren't published anymore but you can ask about your spot.
iJeff is offline   Reply With Quote
Old 11-03-2015, 04:40 PM   #9617
zc06_kisstherain
Drives: SWP BRZ
go back and read posts in this thread
Yoda (11-03-2015)
Old 11-04-2015, 03:22 AM   #9618
rhythmM
rhythmM's Avatar
Drives: 2014 Subaru BRZ Limited MT - White
Hey, did you already receive your kit?
Phantom Super Charged - 2014 BRZ
rhythmM is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
