Old 10-20-2015, 06:02 PM   #1
Owentdc
Drives: 2016 Halo FRS
FIX: No more slamming the trunk!
These are some pictures describing what needs to be done to allow the trunk to close more easily. The gasket is so new and plump that it negates the purpose of the stoppers. Once the gasket compresses, the stoppers may need to be re-installed!
Owentdc is offline   Reply With Quote
The Following User Says Thank You to Owentdc For This Useful Post:
Impureclient (10-24-2015)
Old 10-24-2015, 01:02 AM   #2
Impureclient
Drives: 2015 FR-S
Good call! My last vehicle had them which you can screw in or out to adjust. These ones are all or nothing. I pulled mine out and it worked like a charm.
I've already been driving at least a half dozen times with the trunk unlocked, but down, because I didn't slam it shut. The only way you can tell is the "door open" light on inside.
Old 10-24-2015, 01:58 AM   #3
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Can't you just shave them down?
Old 10-24-2015, 02:23 AM   #4
stevesnj
stevesnj's Avatar
I believe the stoppers are to keep tension on the latch so the trunk doesn't move up and down. If you start hearing a rattle from the rear it's because the stoppers are off.
My 2016 Build thread
The Following 2 Users Say Thank You to stevesnj For This Useful Post:
Lorico (10-25-2015), S84kam (10-27-2015)
Old 10-24-2015, 05:46 AM   #5
LXXXV1
LXXXV1's Avatar
Drives: 2014 FR-S Monogram, Whiteout 6MT
Do you even lift?
2007 Honda CBR600RR-Pearl White/Silver - Totaled
2014 Scion FR-S Monogram-Whiteout - #LXXXV1 (build)
φφκα
LXXXV1 is offline   Reply With Quote
The Following 8 Users Say Thank You to LXXXV1 For This Useful Post:
8R6 (10-24-2015), continuecrushing (10-24-2015), echo419 (10-26-2015), Hyper4mance2k (11-07-2015), Lorico (10-25-2015), MaXimus (12-10-2015), STV3 (10-27-2015), tobin (10-27-2015)
Old 10-25-2015, 12:45 AM   #6
Impureclient
Drives: 2015 FR-S
I am not getting any rattling while driving and I also tested it with enough bass from the trunk sub to rattle the garage door and it didn't make a sound.
The Following User Says Thank You to Impureclient For This Useful Post:
Owentdc (10-25-2015)
Old 10-25-2015, 12:27 PM   #7
Owentdc
I need to thank you but I don't have 10 posts in yet. So....
Old 10-25-2015, 12:37 PM   #8
Owentdc
Ummm, sure you can. But how much do you shave off? That could be a lot of back and forth. Then, if you shave too much off, what then?
Besides, I needed to find the culprit first. It's easy now to say the stoppers were in the way but there are quite a few people complaining about this on the interwebs who seem to be putting up with it.
Old 10-25-2015, 05:49 PM   #9
stevesnj
stevesnj's Avatar
They are probably there then to keep a certain amount of tension on the weatherstripping or puts upward tension so it pops open.
Old 10-25-2015, 05:59 PM   #10
Lorico
Drives: 2015 FRS
Lol this is a DIY
Stop everything. And go to the gym
Lorico is offline   Reply With Quote
Old 10-25-2015, 07:59 PM   #11
Impureclient
Drives: 2015 FR-S
Originally Posted by Lorico View Post
Lol this is a DIY
I want a DIY to make the door handles to not have the spring in there. Sometimes I have to ask a stranger in a parking lot to open my doors.
Seriously though, this just makes the trunk so that you don't have to slam it down to catch the lock. You can push it down and it catches with almost no pressure removing those things.
The slamming to shut the trunk cheapens the car to me and now it just easily locks with more a precision feeling. Try it as it takes like a minute to do and if you don't like it or see no difference, pop them back on.
This was a genius idea and one of those small thing that make a big difference if you are nitpicky when it comes to doors and trunks that have to be slammed to shut properly.
Owentdc (10-26-2015)
Old 10-25-2015, 09:33 PM   #12
White64Goat
I would have to assume that there is also some adjustment available in the latch mechanism (haven't looked) to reduce shutting force.
Old 10-26-2015, 07:10 AM   #13
Owentdc
I looked and there does not appear to be a slot in the latch under the bolts to allow for adjustment. I tried that first.
Old 10-26-2015, 03:01 PM   #14
stevesnj
stevesnj's Avatar
Okay this is the height of laziness...lol Just slam it a little harder.
Trading Carbon Fiber VIS Racing Trunk for Asphalt Grey Trunk + Cash asphaltkyle Exterior Parts (Aero, Lighting, Etc.) 19 10-13-2015 07:51 AM
WTT: Satin White Pearl BRZ Limited Trunk with Spoiler for Wingless Trunk R0ME0 Exterior Parts (Aero, Lighting, Etc.) 3 01-07-2014 10:36 PM
Trade my Crystal Black Silica BRZ limited trunk (w/ wing) for wingless trunk (SF Bay) Iamthebatman Exterior Parts (Aero, Lighting, Etc.) 2 07-18-2013 03:12 PM
Slamming the FRS evanmd Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 07-15-2013 01:56 AM
Slamming my FRS / Spring Rate Question. 636 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 01-28-2013 07:24 PM
