-   DIY (Do-It-Yourself) Guides (https://www.ft86club.com/forums/forumdisplay.php?f=43)
-   -   FIX: No more slamming the trunk! (https://www.ft86club.com/forums/showthread.php?t=96495)
Owentdc 10-20-2015 05:02 PM
These are some pictures describing what needs to be done to allow the trunk to close more easily. The gasket is so new and plump that it negates the purpose of the stoppers. Once the gasket compresses, the stoppers may need to be re-installed!
http://www.ft86club.com/forums/pictu...pictureid=9800
http://www.ft86club.com/forums/pictu...pictureid=9803
http://www.ft86club.com/forums/pictu...pictureid=9802
Impureclient 10-24-2015 12:02 AM
Good call! My last vehicle had them which you can screw in or out to adjust. These ones are all or nothing. I pulled mine out and it worked like a charm.
I've already been driving at least a half dozen times with the trunk unlocked, but down, because I didn't slam it shut. The only way you can tell is the "door open" light on inside.
Packofcrows 10-24-2015 12:58 AM
Can't you just shave them down?
stevesnj 10-24-2015 01:23 AM
I believe the stoppers are to keep tension on the latch so the trunk doesn't move up and down. If you start hearing a rattle from the rear it's because the stoppers are off.
LXXXV1 10-24-2015 04:46 AM
Do you even lift?
Impureclient 10-24-2015 11:45 PM
I am not getting any rattling while driving and I also tested it with enough bass from the trunk sub to rattle the garage door and it didn't make a sound.
Owentdc 10-25-2015 11:27 AM
I need to thank you but I don't have 10 posts in yet. :thanks: So....
Owentdc 10-25-2015 11:37 AM
Ummm, sure you can. But how much do you shave off? That could be a lot of back and forth. Then, if you shave too much off, what then?
Besides, I needed to find the culprit first. It's easy now to say the stoppers were in the way but there are quite a few people complaining about this on the interwebs who seem to be putting up with it.
stevesnj 10-25-2015 04:49 PM
They are probably there then to keep a certain amount of tension on the weatherstripping or puts upward tension so it pops open.
Lorico 10-25-2015 04:59 PM
Lol this is a DIY
Stop everything. And go to the gym
Impureclient 10-25-2015 06:59 PM
Originally Posted by Lorico (Post 2431271)
Lol this is a DIY
I want a DIY to make the door handles to not have the spring in there. Sometimes I have to ask a stranger in a parking lot to open my doors.
Seriously though, this just makes the trunk so that you don't have to slam it down to catch the lock. You can push it down and it catches with almost no pressure removing those things.
The slamming to shut the trunk cheapens the car to me and now it just easily locks with more a precision feeling. Try it as it takes like a minute to do and if you don't like it or see no difference, pop them back on.
This was a genius idea and one of those small thing that make a big difference if you are nitpicky when it comes to doors and trunks that have to be slammed to shut properly.
White64Goat 10-25-2015 08:33 PM
I would have to assume that there is also some adjustment available in the latch mechanism (haven't looked) to reduce shutting force.
Owentdc 10-26-2015 06:10 AM
I looked and there does not appear to be a slot in the latch under the bolts to allow for adjustment. I tried that first.
stevesnj 10-26-2015 02:01 PM
Okay this is the height of laziness...lol Just slam it a little harder. :bonk:
