Old 10-07-2015, 10:49 PM   #29
BRZnut
Drives: BRZ DGM Limited
The pattern in all similar threads around here seems to be the same....once mods are seen, the dealer will deny warrantee service no matter what. Also seems to go for doing your own maintenance...unless you go to the dealer for routine service, good luck having a repair covered.
The Following User Says Thank You to BRZnut For This Useful Post:
stugray (10-08-2015)
Old 10-07-2015, 11:13 PM   #30
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
this is because dumb dealers. And unless they are ridiculed publicly they won't change.
why? is offline   Reply With Quote
Old 10-08-2015, 12:15 AM   #31
pantdino
Drives: Firestorm 2013 FR-S
Originally Posted by kmac_brz View Post
ok everyone, just called and got an update.
Apparently my steering gear is stripped out! The advisor then followed with, this is not just something that happens, something had to have caused this. So i dont know if its going to be covered because this isn't normal. I responded with well is that not what warranty is for? Things that are not expected or normal, immediately he says, well it was in an accident in august so who knows what happened. I said I do, i got tapped at a traffic light and a cop happened to be there in the next lane and the dent popped out on its own. He just said I will call you tomorrow but I dont think they will cover it.
I wouldn't get too upset yet. Just bc some know-nothing service rep guy says what he says doesn't mean there aren't intelligent men who will examine the rack and determine what failed.
I don't know how an owner could destroy his steering rack even if he TRIED. Maybe park right against the curb and turn the wheel into it full lock?
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
pantdino is offline   Reply With Quote
Old 10-08-2015, 12:17 PM   #32
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
This service guy sounds like a prick
797Performance.com
nickmerronesucks is offline   Reply With Quote
The Following User Says Thank You to nickmerronesucks For This Useful Post:
Chad11491 (10-08-2015)
Old 10-09-2015, 03:10 PM   #33
kmac_brz
Drives: 14 WRB BRZ
Hey everyone, I need your help. I'm now being told it's not my steering gear causing the problem it's the fact that I have aftermarket HID lighta that caused the BCM to short out. Has anyone ever heard of this? They want to charge me 240$ for diagnosis
kmac_brz is offline   Reply With Quote
Old 10-09-2015, 03:14 PM   #34
kmac_brz
Drives: 14 WRB BRZ
Ok everyone they just called and told me it's not my steering gear it's the BCM is burnt out because of the aftermarket HID in the car, has anyone ever heard of such a thing or is it even possible
Old 10-09-2015, 03:17 PM   #35
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Ok everyone they just called and told me it's not my steering gear it's the BCM is burnt out because of the aftermarket LED'S in the car, has anyone ever heard of such a thing or is it even possible
Yes. Shorting out the BCM is a thing that happens.
No, I have no idea if the steering wheel lock would be affected by the BCM.
jawn is offline   Reply With Quote
Old 10-09-2015, 03:26 PM   #36
kmac_brz
Drives: 14 WRB BRZ
there saying my HID's shorted out the BCM so its not covered under warranty. But yet my headlights still work? how is it possible headlights that shorted out the BCM are stil working. Is this a known issue?
Old 10-09-2015, 03:50 PM   #37
jawn
jawn's Avatar
http://www.ft86club.com/forums/showthread.php?t=66721
Old 10-09-2015, 03:52 PM   #38
jawn
jawn's Avatar
http://www.ft86club.com/forums/showthread.php?p=2113774
Old 10-09-2015, 04:10 PM   #39
ryoma
ryoma's Avatar
your car is a BRZ, so it is equipped with HID's. what do you mean aftermarket HID? did you actually buy a whole HID system even though your car came with HID's, or did you just replace the bulbs? if you just replaced the bulbs, I call bullshit on the dealer. they're just trying to find a reason to deny your warranty. however, if you did do an LED interior conversion, that might be a possible reason for your BCM to short circuit. but them giving you that HID reason sounds suspicious to me.
Old 10-09-2015, 04:28 PM   #40
kmac_brz
Drives: 14 WRB BRZ
Ok i called them out on it, I have Valenti tails he is saying any LED bulb put in the car can cause the BCM to short. But again the tail lights are working, there were led underglow lights in the car that don't work and haven't worked since I had it, can that cause this?
Old 10-09-2015, 04:31 PM   #41
jawn
jawn's Avatar
Depends on where it's drawing power from. If the underglow piggybacks off an existing circuit, it's possible and it would explain why they don't work.
Are your courtesy lights in the doors still functioning?
Old 10-09-2015, 04:44 PM   #42
kmac_brz
Drives: 14 WRB BRZ
Yes, the subaru lights that light up the ground work if that is what you are taking about as does the dome light
FS: Works bell steering wheel hub, buddy club seat rail, momo steering wheel in Socal mtsui Interior Parts (Incl. Lighting) 5 08-11-2015 01:15 AM
Steering wheel locked no start kmac_brz Issues | Warranty | Recalls / TSB 1 07-08-2015 11:35 PM
scion frs steering wheel air bag and steering wheel Jhon19lopez Interior Parts (Incl. Lighting) 7 01-04-2014 07:04 PM
Swapping steering wheels with a new tC steering wheel. jonathan9573 Cosmetic Modification (Interior/Exterior/Lighting) 4 12-21-2013 12:45 AM
Steering wheel shaking after dealer visit today stratodyne Issues | Warranty | Recalls / TSB 19 08-09-2013 10:51 PM
