Old 09-24-2015, 06:29 PM   #1723
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
Originally Posted by smg1138 View Post
Can anyone recommend a good sway bar setup for STX? I feel like I've got my FRS just about dialed in for AutoX, but would like to tame the tail just a bit more in the fast transitions. At the moment I'm still using the stock sway bars, but was thinking about maybe putting a Strano bar up front. Any feedback would be appreciated.
Current Mods: RCE Yellows, Camber Bolts, RPF1 17x9 +35, Hankook RS3 245/40-17, JDL UEL Header, OFT E85 Tune, K&N Filter
My suggestion for you.
http://www.whiteline.com.au/product_...SF45Z&sq=14690
2superblus is offline   Reply With Quote
Old 09-24-2015, 11:03 PM   #1724
ksconekiller
Drives: Subaru BRZ
OP, if you do go with the Strano bar, they don't have any fitment issues anymore. I won't recommend one over the other, but most people use either the Strano bar or the Whiteline bar.
ksconekiller is offline   Reply With Quote
The Following User Says Thank You to ksconekiller For This Useful Post:
smg1138 (09-24-2015)
Old 09-25-2015, 02:04 AM   #1725
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Thanks for the recommendation. Are there currently any fitment issues with the Strano bar? I was reading through some older threads and noticed that was an issue a couple of years ago.
I needed whiteline adjustable end links to make it work
Old 09-25-2015, 10:31 AM   #1726
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Oh, really? How much are you lowered?
smg1138 is offline   Reply With Quote
Old 09-25-2015, 02:09 PM   #1727
BlaineWasHere
Grip>Drift
Drives: FRS
A lot. I would say about 2" but I also have an early Strano bar. You can try it without first and add the end links later of you have running issues on anything.
The Following User Says Thank You to BlaineWasHere For This Useful Post:
smg1138 (09-25-2015)
Old 09-25-2015, 04:51 PM   #1728
JB86'd
JB86'd's Avatar
Drives: JAWS
I was getting pretty competitive at local events in CS. Then got header and tune. After reading this thread and seeing all the mods recommended I'm glad I just AutoX for fun
JB86'd is offline   Reply With Quote
Old 09-25-2015, 07:01 PM   #1729
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Yeah, I'm playing with the idea of building an STX car to go do nationals once or twice in a few years, car is so good with camber I don't want to do CS. I'm ballparking myself at least $7k away from even considering my car competitive:
Coilovers ~$3k
Front sway bar ~$200
Rear LCA ~$450
(Camber Plates: already bought)
17x9 Wheel, 245-40-17 Tires: ~$2k
(Brake Pads/fluid: already bought)
Header/Tune ~$2k? I haven't researched this one yet...
That should be all the big ticket stuff, could easily spend a few thousand more on bushings, weight reduction, more expensive parts (I'll bet my bottom dollar someone shows up to Nationals next year on Penske's if there wasn't someone on them this year already) or save a couple hundred bucks on buying used parts, some cheaper versions of what I have in mind, revalving non-adjustible dampers etc.
ineedyourdiddly
JB86'd (09-26-2015)
Old 09-25-2015, 07:20 PM   #1730
e1_griego
e1_griego's Avatar
Drives: Many
that's basically my list so far.
I still need the header, tune and front bar, but otherwise, yeah....
Do most of you STX folk run like 1/16"-1/8" rear toe in? I assume yes since that's standard issue RWD setup. I run at least -1/8" in my SM 240, but curious what the preferred street tire setup is.
I guess I'll start with -1/16" and see how it goes.
My list so far is:
Racer-x rlca w/ poly
MCS singles
raceseng cascam and raceseng rear 1" mounts
400/400# to start
17x9 RPF1s with 255/40s
Whiteline shifter bushing
Whiteline diff bushing retainer thing
Whiteline subframe spacer bushings
Whiteline front bar + endlinks (yet to buy)
header (haven't decided yet, probably nameless?)
2.5" perrin exhaust setup
e1_griego is offline   Reply With Quote
The Following User Says Thank You to e1_griego For This Useful Post:
strat61caster (09-25-2015)
Old 09-25-2015, 07:53 PM   #1731
48Spoons
Drives: Ultramarine FR-S
My list so far is:
MCS singles
400/400# to start
Is the diff thing you got?:Name:  tn_kdt925.jpg
pretty sure it was somewhere in this thread that said is legal and just wanted to make sure since I have this installed right now.
48Spoons is offline   Reply With Quote
Old 09-25-2015, 07:55 PM   #1732
e1_griego
e1_griego's Avatar
Drives: Many
yeah that's it.
I'm not the arbiter of such things, but I've seen them listed in the parts lists for two recent STX cars so I assumed they were.
I'm assuming we'll be corrected shortly if they're not lol
Old 09-25-2015, 08:47 PM   #1733
ksconekiller
Drives: Subaru BRZ
Yep, legal.
48Spoons (09-26-2015)
Old 09-25-2015, 08:54 PM   #1734
ksconekiller
Drives: Subaru BRZ
I have a newer Strano bar, and it worked fine with stock end links. I've since switched to adjustable links to remove preload, but no fitment issues with the stock ones.
The Following 3 Users Say Thank You to ksconekiller For This Useful Post:
BlaineWasHere (09-26-2015), drewbot (09-25-2015), smg1138 (09-25-2015)
Old 09-25-2015, 09:45 PM   #1735
smg1138
smg1138's Avatar
I really appreciate the feedback. So, is preload a bad thing? I'm still figuring this out as I go.
Old 09-25-2015, 11:25 PM   #1736
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
Thanks for the pics! I'm actually using RCE Yellow springs, so maybe mine won't look quite as monster truck. I may just go with 245's to be safe though since I'm running -2 camber up front. I think that should be enough meat on a good 200TW tire. BTW good choice on the RCE Tarmac 2's.
I'm running aftermarket springs as well. One of the problems with springs is that they're alot wider than coilovers.
I'm currently running 245s and under very hard turning/accelerating I can hear the tires hitting the springs. I'm only running 1.5 negative camber in the front, your negative 2 camber will probably have issues, just things to consider
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 07:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 02:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 12:02 PM
