#1723 | |
Drives: 13 BRZ WRB
http://www.whiteline.com.au/product_...SF45Z&sq=14690 |
#1724 |
Drives: Subaru BRZ
OP, if you do go with the Strano bar, they don't have any fitment issues anymore. I won't recommend one over the other, but most people use either the Strano bar or the Whiteline bar.
| The Following User Says Thank You to ksconekiller For This Useful Post: | smg1138 (09-24-2015) |
#1725 | |
Grip>Drift
Drives: FRS
I needed whiteline adjustable end links to make it work Sent from my iPhone using Tapatalk
#1726 |
Drives: 2013 Raven FR-S
#1727 |
Grip>Drift
Drives: FRS
A lot. I would say about 2" but I also have an early Strano bar. You can try it without first and add the end links later of you have running issues on anything. Sent from my iPhone using Tapatalk
| The Following User Says Thank You to BlaineWasHere For This Useful Post: | smg1138 (09-25-2015) |
#1728 |
Drives: JAWS
I was getting pretty competitive at local events in CS. Then got header and tune. After reading this thread and seeing all the mods recommended I'm glad I just AutoX for fun
#1729 | |
Drives: '13 FRS - STX
Coilovers ~$3k Front sway bar ~$200 Rear LCA ~$450 (Camber Plates: already bought) 17x9 Wheel, 245-40-17 Tires: ~$2k (Brake Pads/fluid: already bought) Header/Tune ~$2k? I haven't researched this one yet... That should be all the big ticket stuff, could easily spend a few thousand more on bushings, weight reduction, more expensive parts (I'll bet my bottom dollar someone shows up to Nationals next year on Penske's if there wasn't someone on them this year already) or save a couple hundred bucks on buying used parts, some cheaper versions of what I have in mind, revalving non-adjustible dampers etc. |
| The Following User Says Thank You to strat61caster For This Useful Post: | JB86'd (09-26-2015) |
#1730 |
Drives: Many
that's basically my list so far.
I still need the header, tune and front bar, but otherwise, yeah.... Do most of you STX folk run like 1/16"-1/8" rear toe in? I assume yes since that's standard issue RWD setup. I run at least -1/8" in my SM 240, but curious what the preferred street tire setup is. I guess I'll start with -1/16" and see how it goes. My list so far is: Racer-x rlca w/ poly MCS singles raceseng cascam and raceseng rear 1" mounts 400/400# to start 17x9 RPF1s with 255/40s Whiteline shifter bushing Whiteline diff bushing retainer thing Whiteline subframe spacer bushings Whiteline front bar + endlinks (yet to buy) header (haven't decided yet, probably nameless?) 2.5" perrin exhaust setup |
| The Following User Says Thank You to e1_griego For This Useful Post: | strat61caster (09-25-2015) |
#1731 | |
Drives: Ultramarine FR-S
pretty sure it was somewhere in this thread that said is legal and just wanted to make sure since I have this installed right now. |
#1732 | |
Drives: Many
I'm not the arbiter of such things, but I've seen them listed in the parts lists for two recent STX cars so I assumed they were. I'm assuming we'll be corrected shortly if they're not lol |
#1734 |
Drives: Subaru BRZ
I have a newer Strano bar, and it worked fine with stock end links. I've since switched to adjustable links to remove preload, but no fitment issues with the stock ones.
| The Following 3 Users Say Thank You to ksconekiller For This Useful Post: |
#1735 |
I really appreciate the feedback. So, is preload a bad thing? I'm still figuring this out as I go.
#1736 | |
Lost in the twisties
Drives: 2014 BRZ Dark Gray Metallic
I'm currently running 245s and under very hard turning/accelerating I can hear the tires hitting the springs. I'm only running 1.5 negative camber in the front, your negative 2 camber will probably have issues, just things to consider
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread ![]() |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
