BC Coilovers - How stiff is stiff?
Searched the suspension thread a bit just to make sure I wasn't repeating a topic already discussed, but wondering those that have the BC's, how stiff are ya'll running? Please no, "you get what you paid for" posts, or "BC coils suck", just want owner's feedback on this. I just installed mine last Saturday and have both set at FULL soft with 3 clicks to hard and these suckers STILL don't move an inch even when being on top of the car.... Worries me a little, but at the same time the handling is out of this world.. Is this normal for the pre-load to be that stiff? Just wanted to get some input.
#2 |
Drives: FRS
what spring rates did you get on your set? sounds like theyre probably one of those eleventy million pound spring rates often found with BC coils
| The Following User Says Thank You to 8R6 For This Useful Post: | XxFooManDrewxX (09-23-2015) |
#3 |
#4 |
Drives: 86
Adjust them all the way down to soft, front and rear. Go 8 clicks towards hard, adjust from there
| The Following User Says Thank You to HATED1 For This Useful Post: | XxFooManDrewxX (09-23-2015) |
#5 |
Will try that! I'm just surprised having them 3 clicks from soft is still stiff as a rock.. But then again, I've never had coils, so i'm just not sure what to expect from them as far as ride-ability is concerned.
| The Following User Says Thank You to XxFooManDrewxX For This Useful Post: | HATED1 (09-23-2015) |
#6 |
Señor Member
Unless you order some custom springs with softer spring rates they will never be soft. You didn't adjust the collars that make contact with the springs at all did you?
#7 | |
Sent from my SM-N910P using Tapatalk
#8 | |
Stiff is relative. Stiff can be anything. Stiff and controlled. Stiff and bouncy. Did you go clockwise or counter clockwise for full soft? How much preload did you use? You are using the word preload wrong. What do you mean by "STILL don't move an inch even when being on top of the car.... " ? How low are you? 8k/8k is on the firm side on a street car. 2.3k/3.8k is stock. You DOUBLED++ your spring rates. So expect it to be firm. not all springs are created equal. http://www.e90post.com/forums/showthread.php?t=408367 http://www.northamericanmotoring.com...gs-dynoed.html I would say the BC springs are more similar to the megan springs than the swift springs. |
| The Following 2 Users Say Thank You to swarb For This Useful Post: | Captain Snooze (09-23-2015), flippy (09-24-2015) |
#9 |
Señor Member
No do not touch them. The collars come adjusted so they are just snug to the spring and thats all they should be, no tighter.
| The Following User Says Thank You to STV3 For This Useful Post: | XxFooManDrewxX (09-23-2015) |
#10 | |
| The Following User Says Thank You to XxFooManDrewxX For This Useful Post: | CSG Mike (09-24-2015) |
#11 |
The nature of coilovers compared to stock is going to be more stiff no matter what. The shocks are more aggressively built. So what you are experiencing is riding on coilovers compared to stock shocks.
| The Following User Says Thank You to Kami Speed For This Useful Post: | XxFooManDrewxX (09-23-2015) |
#12 | |
It IS relevant because you have never experienced it. You have your definition of preload wrong slightly. Look it up. I am not sure if BC coils are setup from the factory. STV3 says not to touch them so I assume they are already setup. Have someone who has experience with coilovers go for a ride in the car, I am pretty sure you got what you paid for! ![]() Did you go clockwise or counter clockwise for full soft? 8k/8k is a firm street setup. Not many companies sell street setups with rates that high. |
| The Following User Says Thank You to swarb For This Useful Post: | XxFooManDrewxX (09-23-2015) |
#13 | |
| The Following User Says Thank You to XxFooManDrewxX For This Useful Post: | swarb (09-23-2015) |
#14 |
Drives: S60R/Corvette
Much like I'm doing in-house for Penske for other reasons, this forum could take this "relative" subject and make it real and quantitative.
If someone took a small amount of time to calculate the wheel rate/frequency at each standard spring rate front and rear for this chassis then anyone wondering how "stiff" there setup was could reference that data. You could say the OEM setup felt this way which is 1.25hz and my new spring set felt this much stiffer and its at 1.9hz. Now you have something to compare to get a feel for how stiff any other set of springs would be. Wheel frequencies can be compared to any other car's wheels frequencies as well so you can relate your other car/future car and make educated decisions on future setups. I believe all the data one would need is available in the suspension model sticky.
Ryan M.
Strange Engineering Director of Suspension Development |
| The Following 2 Users Say Thank You to RBbugBITme For This Useful Post: | wparsons (09-23-2015), XxFooManDrewxX (09-23-2015) |
| Tags |
| bc coilovers, coilovers, frs, suspension |
| How to get a better street/stiff feeling | Mikepage | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 01-24-2015 08:28 PM |
| MT: 1st and 2nd stiff when cold | Harvey | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-27-2014 06:50 AM |
| stiff stearing? | Jeong | Issues | Warranty | Recalls / TSB | 5 | 11-18-2013 12:28 PM |
| In Search of Coilovers (Clearance/Street/Track/Not Super Stiff) | FR-S Matt | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 06-06-2013 08:36 PM |
| 1st gear in FRS a little stiff? | Brody602 | Engine, Exhaust, Transmission | 4 | 04-18-2013 08:46 PM |
