Old 09-14-2015, 02:16 PM   #15
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
the further back you can get the vents the better they will work. You want them close to level otherwise air will build up on the rear slat of each vent and choke off the vent in front of it since its a flat plane. Mounting over the belts works with vents that have less fins and more negative drop from the hoodline plus some ducting from the radiator up. not possible with my front mount turbo. you can see in the pictures my turbo is still pretty close.
heres some wind tunnel testing of closer spaced vents moved further forward and why i chose the current design/location. In the video you can see the front vents on the gtr dont do anything. Thats because the vent angle is too steep causing air to "pack up" on the slat behind each vent. The rear vents are at a much shallower angle. The same angle as my trackspec vents in there current location and function much better.
Old 09-14-2015, 04:19 PM   #16
#maverick#
#maverick#'s Avatar
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
how are these in the rain? Do they have some sort of rain guard?
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#maverick# is offline   Reply With Quote
Old 09-14-2015, 04:42 PM   #17
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
Thanks, great video.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 09-14-2015, 05:33 PM   #18
Reaper
Reaper's Avatar
Drives: violent
why would you use a rain guard? you do realize an engine compartment has a GIGANTIC hole in the front that water comes through at 65mph when driving in the rain right? The only drawback to a vented hood is if your coolant overflow tank burps(if its over filled) it comes out the vent.
Old 09-14-2015, 08:25 PM   #19
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I guess it's car dependent. I wish there was a pressure map for the front of the twins, but I don't think anyone who's invested the money to generate one wants to share.
The GTR as pictured in the video has a very small low-pressure area at the front of the hood, so that would explain the video.
But some cars have a larger low-pressure area at the front of the hood:
I do admit that the hood shape of the twins shares more with the GTR than the GC Impreza however.
Old 09-14-2015, 08:29 PM   #20
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
30*F ambient temp drop!?! Any difference in IAT's or fluid temps since in isn't an oven anymore? I'm all for this but, really I only think this will look good on a full track car or a twin of darker color like yours.
Old 09-14-2015, 10:31 PM   #21
Reaper
Reaper's Avatar
Drives: violent
nice find. the video i posted is from a shop i work at. we're hopefully sending the shop brz/or my frs to the wind tunnel this fall/winter. We also have a guy that does cfd and 3d car scanning so its all only a matter of time.
Old 09-14-2015, 10:38 PM   #22
Reaper
Reaper's Avatar
Drives: violent
it looks pretty docile on my car. But i think any other color you might want to color match it. Either way i took the pictures in lighting and angles that made them stand out since that was the point of the picture. When the car is dirty or not under florescent lighting it looks less aggressive.
I honestly didnt log as much as i usually do last track day. its all subjective since it was a different track with different weather conditions. you would have to run back to back on the same track same day. But running a 450hp turbo frs in the south and not having cooling issues hot lapping it is doing pretty well. I have a completely stock cooling system minus the oil cooler. temps were 200 water 230 oil running 20 minute sessions hard enough to destroy a set of tires. If there's enough interest ill tape them off next test and tune day. I also have the capability to do thermal imaging but its kind of a hurdle to set it up. Ill get around to it though this winter. Also hopefully wind tunnel time soonish.
Old 09-15-2015, 12:00 PM   #23
RedFR-s
Builder/Driver/Enthusiast
RedFR-s's Avatar
Drives: 2013 FR-S 6MT Turbo Firestorm
I love this idea. Was trying to figure out a good way to vent a top mount oil cooler and this looks like it will work and far more cost effective than a CF alternative. Just need the balls to cut the OEM hood.
Andy
1977 Triumph Spitfire 1500 - New Project
2013 Firestorm FR-S 6MT Turbo - Sold
2013 Honda CBR 250 Repsol- Toy
2017 Toyota Tacoma - The Rig
RedFR-s is offline   Reply With Quote
Old 09-15-2015, 01:54 PM   #24
Draco-REX
Corner Junkie
Draco-REX's Avatar
Any pics of the underside? Thanks.
Old 09-15-2015, 02:30 PM   #25
Rookie84
Drives: '02 GS300, '12 S80 T5, '15 BRZ 6MT
I like it. I was also looking to do this at some point and was looking for a manufacturer of such vents.
BTW, is a rain cover available? If it is, it would seal the deal for me. I want to leave the rain cover on for street use and take them off for track days.
Rookie84 is offline   Reply With Quote
Old 09-15-2015, 03:15 PM   #26
NW86
Drives: 2014 Firestorm FR-S
Those look awesome and saves me some money on buying a vented carbon fiber hood. BTW the s2000 vents are on their websute now.
NW86 is offline   Reply With Quote
Old 09-15-2015, 04:49 PM   #27
Reaper
Reaper's Avatar
Drives: violent
Doooo iiittt.
Old 09-15-2015, 09:40 PM   #28
plucas
plucas's Avatar
Drives: Subaru
Fluid flow around a vehicle is very dependent on the car's design. Just because it works for one, doesn't mean it can be used as a blanket term for all vehicles. You also cannot always trust CFD or wind tunnel testing to have real world results. One big misconceptions of wind tunnels are that they reproduce what the car will see on the road or track. However, this is false. Wind tunnels only simulate the conditions on the road or track. Simulations inherently deviate from reality and it is often hard to quantify all the sources of the error. This is not to say that using wind tunnels or CFD is wrong or isn't helpful. The complete opposite is true. CFD and wind tunnels are very useful in helping design proper parts that work. However, you need to have the experience and know the theory to really understand the reality. You need to have the proper inputs (CFD) or choose the right tunnel for your needs (wind tunnel testing).
We have done CFD testing for the FT86. We do not have the funds for proper wind tunnel testing so results have not been verified by this route. However, on the track, we have seen the real word results. Also I have backed up many CFD cases to other CFD houses and windtunnels. Three examples are the ahmed model, DrivAer models, and the Perrinn LMP1. I will now get off the boring information and get to the CFD of the FT86.
Pressure Plot on the car, specifically the hood
Pressure Cut Plot offset from the center line of the car
Iso Surface around the car showing lower pressure
plucas is offline   Reply With Quote
Seibon TS hood heat shield texasbound972 Cosmetic Modification (Interior/Exterior/Lighting) 0 10-09-2014 11:08 AM
Rotrex vs Turbo (AVO) for Track use (transient response, IATs, heat management, etc) glamcem Forced Induction 56 08-25-2014 06:07 PM
Top half car covers for cabin heat management on track dp1 Scion FR-S / Toyota 86 GT86 General Forum 2 06-26-2014 11:08 AM
raising the hood to combat the heat? BRZPDX Cosmetic Modification (Interior/Exterior/Lighting) 1 04-03-2014 12:41 AM
Avo turbo heat management on track ICantAffordAnLFA Forced Induction 18 09-09-2013 11:00 AM
