Old 09-14-2015, 09:29 PM   #1
Slade
Slade's Avatar
Drives: 14 Limited BRZ
Turn Signals Blink Extremely Slowly
On my 14 Limited BRZ, my turn signals blink very slowly. I've heard of Hyperflashing but never heard of the opposite. I have stock bulbs in the turn signals, front and rear. I only had the car for two weeks so I know its covered under warranty its just my work hours coincide with all three Subaru dealerships by me, I'm off on Saturdays but all three said Saturdays is just for oil changes and inspections and I cant take a day off for a couple of weeks because of how busy we are.
Has anyone had this problem before? It seems like a bad flasher in my opinion Subaru sells it for $45.00 I think I'd be willing to buy it and just fix it myself if anyone here can confirm hats the problem. Thanks.
Slade is offline   Reply With Quote
Old 09-14-2015, 10:07 PM   #2
PNW-BRZ
PNW-BRZ's Avatar
Drives: 2015 Limited
PNW-BRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to PNW-BRZ For This Useful Post:
MisterSheep (09-16-2015), soulreapersteve (09-15-2015)
Old 09-14-2015, 10:15 PM   #3
Have you compared it to another to see if they are the same? Wouldn't want to spend the money just on a guess and then find out it is normal.
humfrz (09-16-2015)
Old 09-14-2015, 10:24 PM   #4
stevesnj
stevesnj's Avatar
The turn signal relay is a grey box 2"x3" under the dash I believe above to drivers left. Just turn the signal on and you locate it. give it some sharp taps like from a screwdriver handle. Could be a stuck contact. You can get an LED signal relay for like $10-15 on amazon.
My 2016 Build thread
Old 09-16-2015, 01:18 AM   #5
Sooooo .....old school ...........
Old 09-16-2015, 01:36 PM   #6
stevesnj
stevesnj's Avatar
Did it work? :P
Old 09-16-2015, 01:52 PM   #7
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Originally Posted by PNW-BRZ View Post
Gah! you beat me to it!
Instagram: trevor.parque
Old 09-16-2015, 02:27 PM   #8
Did it work? :P
Usually worked on the voltage regulator ..........
stevesnj (09-16-2015), Ultramaroon (09-16-2015)
Old 09-17-2015, 02:47 AM   #9
lupindub
Drives: Scion FR-S
As a young un' who's still relatively new to cars, i'm still amazed at what kind of products are out there. Blinker fluid is an actual thing. Blinker fluid. What.
lupindub is offline   Reply With Quote
Old 09-17-2015, 03:27 PM   #10
stevesnj
stevesnj's Avatar
[ame="http://www.amazon.com/81980-50030-066500-4650-Electronic-Flasher-Toyota/dp/B008C9YS0Y"]Amazon.com: 8-Pin 81980-50030 066500-4650 Electronic LED Flasher Assy Relay Fix For Lexus Scion or Toyota LED Turn Signal Light Bulbs: Automotive[/ame]
TapFlasher Problems: Turn Signals Stay Lit, Side Markers Don't Blink bobsacamenoh Cosmetic Modification (Interior/Exterior/Lighting) 4 10-13-2014 11:17 AM
AutoWindow 3 blink Tap-Turn Module schwartzki Exterior Parts (Aero, Lighting, Etc.) 1 08-13-2013 07:28 PM
Is it possible to link the turn signal blink to the side marker on the BRZ? tracerit Cosmetic Modification (Interior/Exterior/Lighting) 1 03-09-2013 03:03 PM
How to: Fixing hyper blink on LED turn signals Laika Cosmetic Modification (Interior/Exterior/Lighting) 0 01-20-2013 07:58 PM
Need help with LED turn signals. Khalis Cosmetic Modification (Interior/Exterior/Lighting) 8 08-12-2012 12:23 AM
