#113 |
Turbo E85
Drives: 13 wrb brz
i wonder if my 9psi map is working. LOL
Flex Fuel Turbo BRZ
#114 |
Drives: sc00ter
#115 |
Turbo E85
Drives: 13 wrb brz
@Khánh removed my flex fuel kit and set tune back to normal and its good.
maybe my flex fuel kit messed up but i had a hard time starting my car. my boost gauge says im hitting 7.1PSI and AFR looks good so it should be hahaha
Flex Fuel Turbo BRZ
#116 |
Drives: sc00ter
glad it's running! hope you can fix the flex fuel! do you love around an e85 station?
#117 | |
Drives: Scion FR-S 10 Series #2263
(joking joking )
#118 |
Turbo E85
Drives: 13 wrb brz
no not really. but i wanted more power O.O
Flex Fuel Turbo BRZ
#119 |
Drives: FR-S TRD RS1#1488
did a ton of logging and yup...still maxing out at 7.25psi which tells me that I'm being constrained to wastegate pressure. So maybe there's something wrong with my EBCS...
#120 |
Turbo E85
Drives: 13 wrb brz
possibly a different spring in the wastegate? im running a 7psi wastegate, you are prolly too
Flex Fuel Turbo BRZ
#121 |
Yes but I should be able to go beyond that with my boost controller. I'll have it checked out. worst case scenario is i put in my 10psi Tial Q spring but it's not as accurate at running off the boost controller to manage the pressure.
#122 |
Turbo E85
Drives: 13 wrb brz
you should talk to your tuner my tuner told me
7psi wastegate and 12psi BOV
Flex Fuel Turbo BRZ
#123 |
yup. already spoke with Ed at Equilibrium, Zach at Delicious, and Shiv (on our SBD FB group). All are telling me something wrong with the boost controller or the line going to it. the problem with running an 8psi spring or higher on this kit is that the BOV ends up staying open at idle which isn't the best thing to have it doing. I would have to find something to shim it to compensate for that. I bought another Prodrive 3port controller which should be coming in on tuesday just in case. I'm gonna have Young at Autotuned check it out first to see if there's something indeed wrong with the the line going to the controller.
I can easily put in my 10psi BOV spring but I'd rather have a more accurate means like a boost controller managing it. |
#124 | |
A turbo's pressure is regulated via exhaust flow. If you have too much pressure you bypass the turbo and let the exhaust go around it. If you have too little boost you force all (mostly all) of the air through the turbo until the pressure goes up or down. This is all done in the SBD kit with an internal wastegate. The blow off valve could not allow you to increase boost pressure because that means the turbo would have to produce enough volume of air to allow you to bleed it out. And if you were to do it this way then you would be adding extra back pressure in the turbo manifold when it is not needed lowering efficiency.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
| The Following 2 Users Say Thank You to nelsmar For This Useful Post: | Crazypinoy9 (09-05-2015), DAEMANO (09-06-2015) |
#125 | |
I bought my kit just before Chris Riggs added the 10psi wastegate actuator to the kit for free lol
#126 | |
| The Following User Says Thank You to nelsmar For This Useful Post: | Crazypinoy9 (09-05-2015) |
| Tags |
| church, dyno day, e85, jackson racing, supercharger |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Dyno Day Hosted by PRT Performance | pleong | Southwest | 11 | 07-16-2015 09:29 AM |
| Testing Our New Vortech Cold Air Intake @ Pure Automotive Performance! Dyno's Inside! | Pure Automotive | Forced Induction | 24 | 10-21-2013 12:29 AM |
| Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 08:00 PM |
| Mach V's Dyno Testing | tjoy | Engine, Exhaust, Transmission | 20 | 08-06-2012 11:52 PM |
