Old 09-04-2015, 09:46 PM   #1
ZHoward
ZHoward's Avatar
Drives: 2013 brz limited
Coolant cost fast?
I just add Subaru super blue coolant 2 weeks ago, and two track days in SoCal, above 100F, and my coolant in white box already blow "low", anybody has this issue?
ZHoward is offline   Reply With Quote
Old 09-04-2015, 09:51 PM   #2
Well, I don't have a BRZ, nor do I live in LA, nor do I track my car ....... but my guess is that your car's system just blew out a bit of coolant when it got really hot.
I'd just check the level, when the engine is cold, and add distilled water if necessary.
ZHoward (09-04-2015)
Old 09-04-2015, 10:01 PM   #3
ZHoward
ZHoward's Avatar
BTW: I have Tomei el header, Motiv HFC front pipe, Megan racing cat back and OFT stage 2 tuning, is that header makes a lot of hot?
Old 09-05-2015, 12:39 AM   #4
Oh, yes, with all that race car stuff, the engine will perspire even more ..... thus lose water ….
Old 09-05-2015, 12:39 AM   #5
ZHoward
ZHoward's Avatar
Thanks a lot !
Old 09-07-2015, 03:41 PM   #6
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
Coolant also evaporates. If you look behind the yellow fill cap (towards the front bumper) you can see a small pinhole vent. After driving for a while or hard like on a track you can see condensation near the hole. I had about half an inch evaporate after a track day at 75*F lol, granted turbo.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
The Following User Says Thank You to zkv476 For This Useful Post:
ZHoward (09-07-2015)
Old 09-07-2015, 04:19 PM   #7
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
Normal - happened to my FRS, and now my BRZ. Usually had to top off after hard driving in hot weather.
aegisdrgn is offline   Reply With Quote
The Following User Says Thank You to aegisdrgn For This Useful Post:
Old 09-08-2015, 03:40 PM   #8
86kahl
86kahl's Avatar
Drives: whiteout, dark tint
Yeah I go through a similar thing during the really hot weeks out here
Sent from my toolbox
86kahl is offline   Reply With Quote
Old 09-08-2015, 03:53 PM   #9
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
You should always monitor coolant levels when the engine is cold. Make sure it's at least at the "Low" level and you should be fine, since it will expand when hot.
As for the system itself, if you are truly worried you should bleed every month or two with this.
[ame="http://www.amazon.com/Lisle-24680-Spill-Free-Funnel/dp/B00A6AS6LY/"]Amazon.com: Lisle 24680 Spill-Free Funnel: Automotive[/ame]
-alex
ZHoward (09-08-2015)
low coolant BRZPDX Northwest 17 06-06-2015 02:42 PM
Mercedes E55 AMG...Fast..but not fast enough. gdrider77 FR-S / BRZ vs.... 18 08-28-2014 04:56 PM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 06:56 PM
What does it cost you to race? (Cost of racing) rice_classic Tracking / Autocross / HPDE / Drifting 63 12-27-2013 10:54 AM
Fast car Fast driver vinyl decal I need help francosolracer Cosmetic Modification (Interior/Exterior/Lighting) 18 10-20-2012 04:43 AM
