| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#15 |
That's just anecdotal bullshit. Show me some DATA!
#16 |
| The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (08-26-2015) |
#17 |
Drives: 2015 CWP BRZ Limited
#18 |
Can't argue with that.
#19 |
Drives: 10 Series #974 6m/t
Don't forget to activate the cricket mode. Just turn the key to start position and your all set.
#20 |
Drives: 2013 FRS
This has been.... interesting. I ended up digging out the information I needed in a far off galaxy far far on the other side of the internet.
I could barely read half of the stuff that was posted, so not much help was given. Thanks anyways... |
#21 |
Maybe in the Miata world there's some sort of buttocks display ritual that takes place before spoon-feeding?
I'm pretty sure your faraway search was actually a longago search right here in this pile. Welcome anyways...
#22 | |
![]() I tried my best up in post #6. Several others also tried. Do you have specific concerns/questions that we can try to address ... ?? humfrz |
#23 | |
Drives: 2013 FRS
It's offtopic however. Common wheels that can be ran with (xxx/xx) sized tires that don't require fender-liner removal or Fender lips to be rolled. |
#24 | |
Hopefully, someone will chime in that is knowledgeable on wheels/tires .... ![]() humfrz |
#25 | |
UCSB!!!
Drives: 2017 GTI sport
| The Following User Says Thank You to HachiEnam For This Useful Post: | MisterSheep (09-01-2015) |
#26 |
in orbe terrum non visi
Drives: violent
I guess it's a toss up. I've seen 198 whp with stock exhaust but with the cat cut out of the stock header on e85 with 13.5:1 pistons. Then we changed the front pipe and made 215ish. Then 3 inch everything with a nameless header and made 22X something whp. The header didn't do much at all compared to the factory with the cat busted out of it. Stock exhaust flows fine even on a 8psi turbo car surprisingly. But changing the front pipe always made a good gain. That is after you knock the cat out of the stock manifold.
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
| The Following User Says Thank You to Reaper For This Useful Post: | HachiEnam (09-02-2015) |
#27 |
Drives: violent
Btw all those numbers are not exact, it was awhile ago we were swapping things all over the place seeing what they did. Car did exceed 223+whp on a mustang dyno though.
#28 |
UCSB!!!
New Owner... Overall run down?
Wait 223 NA on a mustang dyno? That's insane! Or is that with 8 psi
| New owner of a CPO (Certified Preowned) BRZ. Question with previous owner's audio mod | tekniq | BRZ First-Gen (2012+) — General Topics | 2 | 12-05-2014 03:15 AM |
| New owner with some q's | shay999 | AFRICA | 14 | 09-08-2014 03:09 AM |
| New Owner | rawrmatty | Southern California | 4 | 07-22-2014 04:32 PM |
| New owner in NY | Scenic Driver | NY / NJ / CT / PA | 11 | 03-03-2013 10:38 AM |
| Tonight: I need a Portland BRZ owner and S2000 owner! | DarrenDriven | Northwest | 2 | 06-19-2012 02:40 AM |
