Old 08-26-2015, 12:32 PM   #15
Yep! We prove that here every single day.
That's just anecdotal bullshit. Show me some DATA!
Aztec (08-26-2015), Tcoat (08-26-2015)
Old 08-26-2015, 01:14 PM   #16
Ultramaroon (08-26-2015)
Old 08-26-2015, 02:25 PM   #17
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
As a note, the plural form of 'anecdote' is not 'data'.
jawn is offline   Reply With Quote
Old 08-26-2015, 02:29 PM   #18
Can't argue with that.
Old 08-26-2015, 04:23 PM   #19
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Don't forget to activate the cricket mode. Just turn the key to start position and your all set.
Old 08-29-2015, 10:48 AM   #20
HatchirokuV2.0
Drives: 2013 FRS
This has been.... interesting. I ended up digging out the information I needed in a far off galaxy far far on the other side of the internet.
I could barely read half of the stuff that was posted, so not much help was given.
Thanks anyways...
HatchirokuV2.0 is offline   Reply With Quote
Old 08-29-2015, 02:01 PM   #21
Maybe in the Miata world there's some sort of buttocks display ritual that takes place before spoon-feeding?
I'm pretty sure your faraway search was actually a longago search right here in this pile.
Welcome anyways...
Old 08-29-2015, 02:12 PM   #22
Thanks anyways...
Well now, @HatchirokuV2.0, sorry we disappointed you .....
I tried my best up in post #6.
Several others also tried.
Do you have specific concerns/questions that we can try to address ... ??
Old 08-30-2015, 09:19 PM   #23
HatchirokuV2.0
Drives: 2013 FRS
Sure.
It's offtopic however. Common wheels that can be ran with (xxx/xx) sized tires that don't require fender-liner removal or Fender lips to be rolled.
Old 08-30-2015, 09:42 PM   #24
Sure.
Sorry, I won't be much help ..... the wheels and tires that came with my car suits my needs, except that I put on all-weather tires in the winter.
Hopefully, someone will chime in that is knowledgeable on wheels/tires ....
Old 08-31-2015, 11:47 AM   #25
HachiEnam
UCSB!!!
HachiEnam's Avatar
Drives: 2017 GTI sport
Originally Posted by Reaper View Post
the manual transmission is made of glass. E85 and aflex fuel kit is the most power per dollar. Up to 30whp increase. The front pipe is the most restrictive part of the exhaust. Stock brakes do great with good pads and fluid. Stock engine can hold over 400whp. If you track it get an oil cooler. Stock suspension cant be adjusted other than toe unless you buy some parts. The front bumper will eventually sag. Acorns will dent your roof/trunk/hood so dont park under a tree. Deleting the rear seat doesnt save much weight. The OEM battery is heavy. If you lower it on stock wheels 15mm spacers make a big visual differance.
Isn't the headers the most restrictive part of the exhaust?
HachiEnam is offline   Reply With Quote
The Following User Says Thank You to HachiEnam For This Useful Post:
MisterSheep (09-01-2015)
Old 09-01-2015, 11:31 PM   #26
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
I guess it's a toss up. I've seen 198 whp with stock exhaust but with the cat cut out of the stock header on e85 with 13.5:1 pistons. Then we changed the front pipe and made 215ish. Then 3 inch everything with a nameless header and made 22X something whp. The header didn't do much at all compared to the factory with the cat busted out of it. Stock exhaust flows fine even on a 8psi turbo car surprisingly. But changing the front pipe always made a good gain. That is after you knock the cat out of the stock manifold.
The Following User Says Thank You to Reaper For This Useful Post:
HachiEnam (09-02-2015)
Old 09-01-2015, 11:33 PM   #27
Reaper
Reaper's Avatar
Drives: violent
Btw all those numbers are not exact, it was awhile ago we were swapping things all over the place seeing what they did. Car did exceed 223+whp on a mustang dyno though.
Old 09-02-2015, 11:11 AM   #28
HachiEnam
UCSB!!!
HachiEnam's Avatar
New Owner... Overall run down?
Wait 223 NA on a mustang dyno? That's insane! Or is that with 8 psi
New owner of a CPO (Certified Preowned) BRZ. Question with previous owner's audio mod tekniq BRZ First-Gen (2012+) — General Topics 2 12-05-2014 03:15 AM
New owner with some q's shay999 AFRICA 14 09-08-2014 03:09 AM
New Owner rawrmatty Southern California 4 07-22-2014 04:32 PM
New owner in NY Scenic Driver NY / NJ / CT / PA 11 03-03-2013 10:38 AM
Tonight: I need a Portland BRZ owner and S2000 owner! DarrenDriven Northwest 2 06-19-2012 02:40 AM
