#43 | |
Drives: 2013 FRS
| The Following User Says Thank You to ravisraval For This Useful Post: | soulreapersteve (08-18-2015) |
#44 | |
Thupercharged
Does it just sound too flat for your tastes? The more I listen to this system the more I am loving it. Did you find anything wrong with the install/harness connectors? Remember to disconnect the dash speakers?
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
#45 | |
Drives: 2013 FRS
#46 |
Drives: frs
#47 |
Thupercharged
I took my sub back off and wiggled the connections a lot and got some more slack from the harness that you cut the slot for. Maybe its placebo but the sub sounds stronger and its actually got some more fidelity. I wonder if one of the pins was not making good contact when the sub was installed due to not enough slack...
2013 FRS
#48 | |
Drives: frs
#49 |
OEM audio plus customer service is second to none. I have dealt with them extensively because I'm picky about how my music sounds and they have worked with me very patiently. I have never had an issue contacting them by phone or email. Would recommend talking to them about your issues.
#50 |
Drives: Subaru Brz
Im thinking about buying this system where can i get the best deal?
#51 |
Drives: 2013 Subaru BRZ Limited (Black)
| The Following User Says Thank You to ajcarson11 For This Useful Post: | Chrisbrz14 (08-31-2015) |
#52 |
Drives: Scion FR-S
| Audio Equipment Part out! AVH-x4500bt, illusion audio, OEM amp, arc audio and more!!! | CamryDS | Audio/Visual, Electronics, Infotainment, NAV | 25 | 10-23-2015 10:10 AM |
| Pondering audio upgrade options; have questions, want recommendations | SilverlightPony | Electronics | Audio | NAV | Infotainment | 17 | 05-11-2014 06:38 AM |
| soundman's audio build and questions | soundman98 | Electronics | Audio | NAV | Infotainment | 0 | 01-20-2014 09:59 PM |
| Scion Display Audio Questions | 1ucky11 | Electronics | Audio | NAV | Infotainment | 13 | 11-03-2013 12:51 PM |
| 'Noobish' questions as I look to upgrade my car audio audio. | DkY in Vcr | Electronics | Audio | NAV | Infotainment | 0 | 09-22-2012 10:45 PM |
