| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Thanks
Smallest bolt on spacer?
What is the smallest possible bolt on spacer I can buy? I am talking to ones with built in lugs, not the ones that require extended studs.
I am trying to fit stock wheels over AP racing sprint. I read it needs a 10mm spacer but I dont think there are 10mm bolt on available. Maybe I should just buy some slightly longer studs...
#2 |
Off Topic
I've seen 15mm from several dealers, but I've not seen any 10mm. What wheels are you using?
| The Following User Says Thank You to gramicci101 For This Useful Post: | ZionsWrath (09-29-2014) |
#3 |
Thanks
Just trying to put stock wheels over them, stock tires have a lot of life would hate to waste them. I have track wheels that will clear them.
#4 | |
Off Topic
EDIT: Before ![]() After
| The Following 2 Users Say Thank You to gramicci101 For This Useful Post: | Corner3garage (09-29-2014), ZionsWrath (09-29-2014) |
#6 |
#7 |
I was going to chime in with 10mm bolt-on as being the smallest.
However, since the spacer nuts can only be a maximum of 10mm deep, you won't have enough thread engagement to be safe. The technical info I have seen say you should have at least the same nut depth as bolt diameter. Since our lug bolts are 12mm the smallest bolt on spacer should be 12mm, assuming tightened down flush to the hub. |
#8 |
Drives: Scion
![]() ![]() There are 10mm adapters out there but it's a bit of a risk to run them as we have seen something like this happen where the studs on the adapter just tear apart and break away from the spacer/adapter. However, There are some 10mm adapters that people have said worked. ![]() Circuit Sport 5x100 to 5x114.3 Adapter/Spacer (15mm) We carry Circuit Sports 15mm 5x100 to 5x114.3 adapters and 15mm 5x100 bolt on spacer. Many customer have ran these on their cars and have had great results. Last edited by JonMotoring; 09-30-2014 at 05:34 PM. |
#9 |
Drives: WRB Subaru BRZ Limited
Is there a reason you want a bolt on instead of slip on?
#10 |
Thupercharged
I think 10mm is the smallest for spacers with bolts, but you can get 3mm spacers that slip on and won't require longer studs... but it might not be enough to clear whatever you need to clear
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
#11 |
#12 | |
Drives: Blue BRZ
| The Following User Says Thank You to BRZ RN For This Useful Post: | OmarYasin (08-19-2015) |
#13 |
Time Traveller
I wouldn't go thinner than 15mms for bolt on. Recommend H&R Track+ hubcentric alloy spacers
http://trakplus.com/buy |
#14 |
| Sprint Kit + RPF1 17x9+35 To spacer or not to spacer? | Khorne | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 07-03-2014 01:53 PM |
| smallest OD coil over / spring perch | BadBRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-27-2014 01:56 PM |
| What's the smallest oil cap? | Hanakuso | Engine, Exhaust, Transmission | 2 | 07-08-2013 04:55 PM |
| 25mm conversion spacer with 5mm spacer = safe or unsafe? | deedz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 05-05-2013 12:59 PM |
| BRZ crash bolt same as Impreza lower strut bolt? | xwd | Tracking / Autocross / HPDE / Drifting | 0 | 07-05-2012 01:19 PM |
