Old 08-18-2015, 06:57 PM   #1
James426
Drives: 2013 FRS
Quick offset question
Hi guys
Looking at getting some Works D9R 18" rims
The shop has 8.5 +38 front and 9.5 +38 rear.
I usually see people with a larger offset on the rear when they do staggered.
Does having he same offset make sense in this case (staggered setup)?
Just wondering if it'll look weird.
Thanks a million for your advice all
James426 is offline   Reply With Quote
Old 08-18-2015, 07:08 PM   #2
BPAuto
BPAuto's Avatar
Drives: GT-R, S2000, Evo VIII-X, BRZ, FRS+
Hey James, that should be a pretty good fit for the FRS. It's not a super aggressive setup but pretty sporty for the FRS / BRZ
BPAuto is offline   Reply With Quote
The Following User Says Thank You to BPAuto For This Useful Post:
Special_K (08-19-2015)
Old 08-18-2015, 07:09 PM   #3
Special_K
Bannéd
Special_K's Avatar
Drives: 2013 DGM BRZ
Originally Posted by James426 View Post
Hi guys
Hey man, I'm sure you can find this somewhere in the wheel section, but I'm bored and here to help. I honestly think it will look just fine...
I have the BBS CH-R 18x8 +38 and at stock height they perfectly ride the line between poke in the front and tuck in the rear. It really all depends on how low you go and what amount of camber. I dropped about 2.75 inches, and the front sits just about flush, but the rears tucked in about 22mm due to my aggressive camber setup for AutoX.
For everyday street use, I have Perrin 25mm spacers in the rear, and it gives it a perfect profile IMO. Really depends on the rest of the setup, but if you are running between stock height and -1" you should be golden.
For reference, the pic shows how it sat before adding any significant camber or the rear spacers.
Special_K is offline   Reply With Quote
Old 08-19-2015, 05:47 PM   #4
BPAuto
BPAuto's Avatar
Nice wheels
Old 08-19-2015, 05:59 PM   #5
Special_K
Bannéd
Special_K's Avatar
Originally Posted by BPAuto View Post
Nice wheels
Thank you good people of BPAuto! Picked them up off of member bobsacamenoh for too good a deal to pass up. They weren't quite the style I was originally planning on, but as soon as I mounted them I fell in love.
Old 08-19-2015, 06:46 PM   #6
BPAuto
BPAuto's Avatar
They look good either way.
Question on offset FRStrent Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 02-18-2015 08:21 AM
Quick Offset Question Dezoris Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 06-19-2014 12:31 AM
Quick question?!?! tr1x5tuh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 01-18-2014 02:55 PM
A Quick Question! emerald_ir Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 01-18-2014 07:43 AM
Quick vid of new Nameless Offset revised system GTB/ZR-1 Engine, Exhaust, Transmission 35 02-07-2013 07:02 PM
