Old 08-07-2015, 03:58 PM   #15
stevo585
Drives: White 2014 BRZ
Group Buy?
Also does this actually work? Doesn't appear so.
Use coupon code "FT86CLUB" for 5% off your purchase!
stevo585 is offline   Reply With Quote
Old 08-10-2015, 11:08 AM   #16
Jeff@Racer X Fab
Drives: Subaru BRZ, Toyota MR2 Turbo
Originally Posted by Teseo View Post
Its possible to take a pic on front view?
I'd like the idea of having a V mount with it
I will grab a few pics, when we are working on the alternative mounting solutions.
Originally Posted by celek View Post
@racerx1715 do you have any over all pressure drop numbers vs stock or added capacity recommendations on install?
No pressure drop numbers, the added volume with the cooler (setrab 613) and lines/fittings is about 24 fluid ounces or 3/4 of a quart.
Originally Posted by stevo585 View Post
Group Buy?
We might be able to do a group buy.
Yes, this should work. It was case sensitive, but I had that changed to eliminate any confusion.
Jeff@Racer X Fab is offline   Reply With Quote
The Following 4 Users Say Thank You to Jeff@Racer X Fab For This Useful Post:
celek (08-10-2015), DAEMANO (08-17-2015), stevo585 (08-10-2015), Teseo (08-10-2015)
Old 09-11-2015, 02:12 PM   #17
DAEMANO
Time Traveller
Just noticed that Racer-X put the thermostatic adapter plate kit up for sale by itself. This is pretty darn great for those wanting to build their own kit. $129.
http://racerxfabrication.com/frs-brz...-adapter-plate
The Following User Says Thank You to DAEMANO For This Useful Post:
Jeff@Racer X Fab (09-11-2015)
Old 09-12-2015, 02:12 PM   #18
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
@racerx1715 looking at purchasing the plate as I'm really not a fan of my current mocal one. Quick question - is there enough clearance to get a socket on the bolt to tighten up the plate? Seems tight on yours (it's impossible on mocal's). Thanks!
Also, any news on upper mounting solution / changing the core? I think a straight threaded fitting into the core like the JR / Perrin options are optimal, eliminating another AN seal there would be great peace of mind to eliminate another area for potential leaks.
1Cor10:23 is offline   Reply With Quote
Old 09-14-2015, 11:53 AM   #19
Jeff@Racer X Fab
Yes, the thermostatic adapter plate was made to work with a 1" socket and still has a bit of wiggle room.
To follow up from our previous post, yes we are working on the optional mounting solution and will also be adding a Bell core as an option along with the more common Setrab cores.
Here is a pic of the oil cooler kit installed with our prototype air box, which we should also be wrapping up very soon.
The Following 7 Users Say Thank You to Jeff@Racer X Fab For This Useful Post:
1Cor10:23 (09-14-2015), BigFatFlip (09-14-2015), ChrisD (09-23-2015), DAEMANO (09-14-2015), DustinS (09-16-2015), kbye (09-14-2015), WillRacer1jz (10-18-2015)
Old 09-16-2015, 02:34 PM   #20
2.superslownj
Drives: 2014 Raven FRS
So the kit is available for purchase now??
2.superslownj is offline   Reply With Quote
Old 09-16-2015, 02:45 PM   #21
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
That intake... I wish I was still N/A so I could run it. Gains looked real good
The Following User Says Thank You to DustinS For This Useful Post:
Jeff@Racer X Fab (09-17-2015)
Old 09-16-2015, 03:38 PM   #22
ryoma
ryoma's Avatar
is the intake CARB legal?
Old 09-17-2015, 01:55 PM   #23
Jeff@Racer X Fab
Yes, they are available for purchase. We have a little over 40 kits in stock.
No, the intake is not currently CARB legal.
Old 09-17-2015, 01:57 PM   #24
1Cor10:23
1Cor10:23's Avatar
@racerx1715 does the intake require a re-turn for efficiciency vs stock?
Old 09-17-2015, 03:39 PM   #25
ryoma
ryoma's Avatar
does that mean you will be in the process to make it CARB legal? I need a CARB legal intake to stop being afraid of CHP lol
Old 09-18-2015, 01:55 AM   #26
DAEMANO
Time Traveller
You're going to have little to no choices on intakes with CARB. If you're not willing to pay to play, just get a drop in filter and call it a day.
The Following 2 Users Say Thank You to DAEMANO For This Useful Post:
Jeff@Racer X Fab (09-18-2015), WillRacer1jz (10-18-2015)
Old 09-18-2015, 09:36 AM   #27
Jeff@Racer X Fab
I think you meant re-tune?
The intake does not require a retune. It is designed to work with the OEM ECU and uses the same diameter as the stock intake. We are also utilizing an OEM paper filter that shockingly provides very good results, within 1 whp of the K&N equivalent.
Unfortunately we will probably not be looking into it. The cost to get CARB approved is quite expensive.
The Following User Says Thank You to Jeff@Racer X Fab For This Useful Post:
1Cor10:23 (09-18-2015)
Old 09-18-2015, 09:38 AM   #28
1Cor10:23
1Cor10:23's Avatar
@racerx1715 yes, re-tune* my bad. Sounds great, when will it be available?
Racer X Fabrication oil pan design and development! Jeff@Racer X Fab Engine, Exhaust, Transmission 87 06-03-2015 11:10 AM
Racer X Fabrication Holiday sale!! Ends Dec 2nd. Jeff@Racer X Fab Announcements, Contests, Giveaways 2 12-01-2014 09:24 AM
DIY Changing Cam Plate Racer X fabrication Mr. DIY (Do-It-Yourself) Guides 0 08-06-2014 12:56 AM
Racer X Fabrication heat shield, help us to help you Jeff@Racer X Fab Engine, Exhaust, Transmission 31 07-17-2014 09:20 AM
Racer X Fabrication, New vendor intro Jeff@Racer X Fab Announcements, Contests, Giveaways 0 03-12-2013 11:50 AM
