Old 08-01-2015, 10:09 PM   #365
steve99
Drives: FT86
Originally Posted by bass_114 View Post
First time user here loving the new tune but curious to try out that tune to make the exchaust pop...downloaded the rom raider although i cant seem to figure how to upload a stock map to begin editing.
Ive looked through the youtube vids but none seem to help the maps seem to already be there in the vids.
thanks for the help
read the romraider tips link below
help on romraider on the romraider site
you cannot open a tune file\rom untill you point romraider to the matching definition files so it knows where the tables in the rom are
you will need to download the definition files and tune files from the oft downloads site
Old 08-01-2015, 10:10 PM   #366
Husker BRZ
Go Big Red!!
Drives: 2013 SSM BRZ Limited
did you update the template file to 8.2 ?
Yes. I don't know if it has anything to do with it but I changed some of the data logging options to the lateral and fwd/rev g's just to test it out and it hasn't been the same since.
Husker BRZ is offline   Reply With Quote
Old 08-01-2015, 11:27 PM   #367
bass_114
bass_114's Avatar
Drives: wrb brz
Yes i have downloaded both the definition files and the tune files now just wondering how i can open them in rom raider and start editing. Are there any vids to show how this is done? Thanks again
bass_114 is offline   Reply With Quote
Old 08-02-2015, 04:48 AM   #368
steve99
Drives: FT86
no videos i know of romraider and openflash oft are totally independant.
you will need to read how to,s on romraider site or maybe search youtube for how to use romraider
Old 08-03-2015, 10:58 AM   #369
Myv
Myv's Avatar
Drives: SWP BRZ Limited MT
Question regarding the adv multiplier, I read some posts where I'd want it to be as close to 1 as possible, what does it mean when I'm seeing it at 0.75? (Stage 1 91 Oct)
Myv is offline   Reply With Quote
Old 08-03-2015, 11:36 PM   #370
steve99
Drives: FT86
IAM of 1 means you have very low levels of knock
IAM of .7 means you have some knock and the ecu is managing this by reducing the ignition timing over the entire rpm range the stock tune will knock generally knock more and have a lower iam than this, seen stock cars in south africa with iam of 0.2
this happens on 91 fuels you can have a read of the knock correction links below and the tune tweaks thread
Myv (08-04-2015)
Old 08-04-2015, 01:34 AM   #371
D_Thissen
D_Thissen's Avatar
Which 91 are you using?
Old 08-04-2015, 09:48 AM   #372
Myv
Myv's Avatar
Thanks, I'll start logging and check out what can be done with it
ESSO 91 this time, I switch back and forth between ESSO and Shell.
Old 08-04-2015, 10:46 AM   #373
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
A few local members ( @1Cor10:23 and @wparsons, at least) including myself have had poor IAM's on any GTA 91 fuel.
From my couple days of logging last year, between Costco and Shell I was getting anywhere between 0.80 and 0.94...
Currently I run a variant of the 91 OTS tune with 94 (IAM is rock solid 1.0) and I believe @wparsons runs the 93 OTS with 93/94
drewbot is offline   Reply With Quote
Old 08-04-2015, 10:56 AM   #374
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Yeah I also run 91 OTS on 94 octane. If it's hot enough, I also run a bit of Torco Accelerator.
1Cor10:23 is offline   Reply With Quote
Old 08-04-2015, 11:46 AM   #375
Myv
Myv's Avatar
The chirps from Petro 94 kind of irks me lol
Old 08-04-2015, 12:48 PM   #376
faltyda
Drives: 2014 BRZ Limited
Relatively new OFT user here, recently jumped up to the 2.067 OTS map but don't think I had the newest template file. Will this cause any issues?
I felt like the previous tune version was better and I could actually feel a difference, however with the 2.067 it feels sluggish and somewhat bogs down at low
RPMs under WOT. I understood this to be an issue with aftermarket intakes but mine is completely stock? Any suggestions on how to really remedy this?
faltyda is offline   Reply With Quote
Old 08-04-2015, 01:05 PM   #377
JB86'd
JB86'd's Avatar
Drives: JAWS
You might have issues if you try to monitor things or datalog, the readings may be incorrect. How many miles have you driven on the new tune?
JB86'd is offline   Reply With Quote
Old 08-04-2015, 01:27 PM   #378
wparsons
wparsons's Avatar
Yep, and yep.
The OTS 91 map and OTS 93 map are identical at lower revs, and the knock issue I have is in the low rev high load area (too much gas in the ~2500-3500rpm range). Oddly enough I get no knock on a track with 91 octane on the OTS 91 map, but I get a bunch driving in traffic.
I'm currently running an unmodified OTS 93 map on 94 octane.
flickr
randomthoughts (09-10-2015)
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 08:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 09:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 03:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 03:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 08:14 PM
