Old 07-26-2015, 04:23 AM   #547
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by MGPAX View Post
but cant find a program that will work with the oft .csv files.
You just need to open the csv in a spreadsheet program like Excel and remove the 1st few rows before the data headers. Then everything will work dandy
.: Stealth 86 :.
Kodename 47 DJ:
MGPAX (07-26-2015)
Old 07-27-2015, 07:22 AM   #548
freerunner
freerunner's Avatar
Drives: GT86
Yes that transition area between open/closed loop always presents some issues. yes just try manually adjusting those values
just keep the maf curve smooth
look at the open loop data and the closed loop data in that area and come to a compromise in the middle is usually a good starting point
Originally Posted by Wayno View Post
For 3.2V, you should scale with low load open loop. Then attempt to lean it up with load limits for WOT if required. Otherwise you'll run lean at low load.
Thank you both for answering.
Hmm. Do you have any hints where I can gather further information about load limits?
freerunner is offline   Reply With Quote
Old 07-27-2015, 07:52 AM   #549
steve99
Drives: FT86
have a lok at wayno,s tune thread in software tuning it has suggested load limit mods, you might need to update your definitions to see trhem though
Old 07-27-2015, 11:53 PM   #550
itsjustdavep
itsjustdavep's Avatar
Drives: Asphalt Scion FR-S
Originally Posted by itsjustdavep View Post
what about these, i think i may have a small leak from header to OP, not sure if that'd reflect in the logs
http://datazap.me/u/itsjustdavep/len...g=0&data=12-13
http://datazap.me/u/itsjustdavep/len...og=1&data=1-13
@steve99 any insight on why I've gone rich?
2013 Asphalt HRI Tuned-K&N DropIn-Tomei UEL-Tomei OP-Invidia FP-Nameless Muffled Trackpipe...and corn
itsjustdavep is offline   Reply With Quote
Old 07-28-2015, 01:28 AM   #551
steve99
Drives: FT86
If thats an oft e85 tune it look pretty normal ,they do tend to run richer than commanded afr with the standard maf scaling.
if you have a leak it mist be a small one
you can rescale the maf to make it run to the commanded afr if you have a stable e% source of e85, the oft guys make it run rich for safety.
Old 07-28-2015, 07:05 PM   #552
Husker BRZ
Go Big Red!!
Drives: 2013 SSM BRZ Limited
Hey guys! I'm looking for some input as this is the first datalog I've posted and only third datalog that I've actually done. I just flashed the stage 1 93 tune after I had installed my grimmspeed intake. I'm waiting on the grimmspeed tune from the OFT guys because I can't get the files to load in RomRaider and I'm not sure I'm brave enough to edit things yet since I'm still learning. Any input on the datalog would be greatly appreciated!
http://www.datazap.me/u/huskerbrz/lo...5?log=1&data=1
Husker BRZ is offline   Reply With Quote
Old 07-28-2015, 11:03 PM   #553
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
Would also like some input, I just got the OFT yesterday and flashed the Stg 2 93 UEL tune paired with the OFH and a drop-in filter. I logged a 2nd gear pull and some normal driving.
http://www.datazap.me/u/jonavalon/lo...5&tmax=7109.00
Regular driving logs
http://www.datazap.me/u/jonavalon/lo...=0&data=1-5-12
http://www.datazap.me/u/jonavalon/lo...log=0&data=1-9
JonAvalon is offline   Reply With Quote
Old 07-31-2015, 09:54 AM   #554
mid_life_crisis
Drives: FR-S 10 #103 AT
I've loaded Wayno's stage 1 mods, not including the ones for startup noise.
There is absolutely no knock correction on a warm morning, so I'm thinking I could get a bit more aggressive with the timing, just need a suggestion as to a starting point.
Also, should I tweak the MAF scaling?
The car has no hardware mods that affect anything but sound. Axle back (mostly done for looks, I hated the tiny exhaust tips it came with) and sound tube delete.
Thanks
http://datazap.me/u/midlifecrisis/lo...8?log=0&data=1
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 08-02-2015, 10:29 AM   #555
aagun
Drives: 86
i flash back to stock JA01J ROM for knock test . i fount the timimg go to 10^ ATDC . for 15s at start up mod . is that safe for catalyst
http://www.datazap.me/u/aagunss/log-...-1254&mark=806
aagun is offline   Reply With Quote
Old 08-02-2015, 12:54 PM   #556
phrosty
Your WOT pulls were running lean. Don't go WOT immediately after flashing, especially with an aftermarket intake and unscaled MAF. You need to wait for ECU to learn LTFTs - do some highway driving.
AFRs look great.
You've got some occasional knock you might want to address. Might be due to high temps or bad fuel.
phrosty is offline   Reply With Quote
The Following User Says Thank You to phrosty For This Useful Post:
Husker BRZ (08-02-2015)
Old 08-02-2015, 01:21 PM   #557
JonAvalon
SCBYD0
JonAvalon's Avatar
Originally Posted by phrosty View Post
AFRs look great.
Thanks! Yea temps are high here and fuel isn't exactly great in my area. I'm hoping that's the case.
I just filled up on my first tank of E85 yesterday (possibly E70), I've logged a few throughout the day to get the residual petrol gets out. The adv multiplier was below 1 but in logs 3 & 4 straightened back to 1. LTFT ranges between -3.91 to -7.81. Are things starting to look normal? I will be taking it out later to do some more logging.
http://datazap.me/u/jonavalon/1st-e8...og=0&data=1-12
http://datazap.me/u/jonavalon/2nd-e85-log?log=0&data=1
http://datazap.me/u/jonavalon/1st-e8...3?log=0&data=1
http://datazap.me/u/jonavalon/1st-e8...4?log=0&data=1
Old 08-02-2015, 02:32 PM   #558
phrosty
Negative LTFTs are normal with residual 93. Over the next several fill ups it'll get to zero and maybe beyond if you have good E%.
JonAvalon (08-02-2015)
Old 08-02-2015, 06:40 PM   #559
Husker BRZ
Go Big Red!!
[QUOTE=phrosty;2343531]Your WOT pulls were running lean. Don't go WOT immediately after flashing, especially with an aftermarket intake and unscaled MAF. You need to wait for ECU to learn LTFTs - do some highway driving.
Thanks for the feedback! Since I'm a total noob to this what should LTFTs be around? 0? I haven't figures out RomRaider yet but this way I'd at least know what to kind of look and watch for.
And for the WOT pulls I did those after driving around normal for a few days which was before I did this datalog. Is that enough time for the ECU to learn?
Old 08-02-2015, 07:35 PM   #560
steve99
Drives: FT86
[quote=Husker BRZ;2343756]
is your intake stock ?
are you running E85 or petrol tune ?
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 02:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 01:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 10:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 05:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 10:27 AM
