#57 |
Drives: 2014 Pearl White BRZ
The stock transmission and axles will cry about this.
#58 | |
Drives: Toyota GT86
'This engine is 100% stock, unopened 2013 FR-S so standard in every way. There is also a rumour going round about it blowing up. It is indeed still running and is 100% healthy. It has done 12+ pulls at 450 - 690bhp the day of the pictures, with the highest pull being towards the end but not the last. I did two additional pulls in the 630 - 650bhp range after making 693bhp, to back this figure up.' |
| The Following 4 Users Say Thank You to EcuTek For This Useful Post: |
#59 |
Drives: 2JZ FRS
I can't see how you could make almost 700whp with a 6266 on 27psi, with an E cover on it as well. At 27psi with mbt timing we make 580-600 on a 6262 with an S cover. Plus larger and way shorter piping than the full blown kit came with, plus the upgraded core. Granted it's at 10:1 compression but I'm sure your timing is less to compensate for compression ratio making everything somewhat similar. I trap 133mph, I'd love to see a trap for this car to back up that dyno number that seems a little exaggerated
#60 | |
Drives: Civic
This turbo manifold was the PRL kit that there were only apparently a few of this design made. I didn't do the install; but can get more details of needed. The compression ratio for sure would have a lot to do with the difference in power vs psi range but to what extent; I can't be sure on this car and the pump e85 fuel we are using. I am hoping we have some track data to share with you guys soon, but that might not be for a little bit since we are getting the car ready for pick up next weekend. |
#61 | |
Drives: red frs
I know of more than 5 cars that dyno'd there and then made pulls the following day or week elsewhere and were down over 30-70hp. These guys numbers are always suspect at best... |
#62 |
Drives: None
A lot of TC cutting in there but it does show that its not spinning the wheels that bad. Doesn't actually sound that quick in fairness considering it's 2.5 times stock power
| The Following User Says Thank You to Tim Radley For This Useful Post: | raven1231 (08-10-2015) |
#63 | ||
Drives: 2015 Scion FR-S
| The Following User Says Thank You to Travisty75 For This Useful Post: | WHITE (08-10-2015) |
#64 | |
Drives: 2JZ FRS
| The Following User Says Thank You to spitfire481 For This Useful Post: | Shit Luck (08-13-2015) |
#65 |
Drives: 350z
I remember in 2015 where gopros, cameras, and phones that take video were everywhere... Lets see some video!
#66 |
Drives: '13 BRZ
| The Following User Says Thank You to BRZoomTX For This Useful Post: | Tim Radley (09-03-2015) |
| Tags |
| e85, ecutek, frs, racerom, world record |
| Stock, tuned with Ecutek | 19eightysix | Software Tuning | 10 | 03-23-2015 01:46 PM |
| P087 Code and Car Dies, EcuTek Tuned, FI---Help! | kmbkk | Software Tuning | 34 | 04-05-2014 11:53 PM |
| Worlds Fastest Turbo BRZ gets faster! Accelerated Performance Built - Visconti Tuned | Visconti | Forced Induction | 697 | 11-13-2013 07:18 PM |
| What is the highest HP/Torque going all motor? | Atropine | Engine, Exhaust, Transmission | 40 | 10-29-2013 05:45 AM |
| Worlds fastest BRZ - Accelerated Performance Built - Visconti Tuned !!! | Visconti | Forced Induction | 135 | 09-06-2012 06:43 PM |
