Old 07-10-2015, 01:13 PM   #15
DAEMANO
Time Traveller
Originally Posted by Donbrz View Post
NOB Q. If gut cat from stock header, does that trigger a CEL code ?
Probably will. You can reset it with any OBD II tool, but it will pop up again eventually. Better to get a tune because you won't get the most out of a catless header without one. OpenFlashTablets (that include free lifetime tunes) go for about $400 on the board used or $500 brand new the mfg.
The Following User Says Thank You to DAEMANO For This Useful Post:
Donbrz (07-10-2015)
Old 07-10-2015, 03:08 PM   #16
churchx
churchx's Avatar
Drives: 2014 GT86
And if one decides to pay for ecu tune (be it ecutek or OFT), and go catless .. why not change to some even more efficient catless aftermarket header, so that if needed, one still has normal stock header that one can bolt back for MOT exhaust checks or prior car sale, but have more power (and it will weight less) then what gutted cats in stock header may bring?
Old 07-10-2015, 05:44 PM   #17
mad_sb
Drives: 2013 Asphalt FR-S
You will be fine IF you keep the Q300
I did all the other bits first (2 x headers, 2x front / over pipe) and then changed catbacks several times trying to find the right blend of power and low volume.... the Q300 keeps any setup bearable on the twins.
And no, the catted headers do not keep the car quiet, necessarily. Depends on the cat density, placement, header material, material thickness, etc etc. My first header was catted the second was not. with the Q300 it won't make much difference if any at all.
Originally Posted by OnionTou View Post
I'm thinking on buying a header for my car, but all of my friends with headers have particularly loud cars. I like loud cars for the track or whenever I go full throttle. But I don't like a loud car the rest of the time.
As a backstory, I used to have an invidia N1 on my car, without the silencer caps on it, it would wake up every car alarm in the apartment building's garage. With the silencer caps only 2 or 3. I managed to reduce it to 0 when I changed my N1 for the Q300.
Afterwards I changed my OEM frontpipe to a invidia catted frontpipe (noise didn't change much), and same with the overpipe, not much of a difference in sound. Even after I added ECUTek and the car's warm up idle is up at 2000+ rpm
Now I'm looking into getting a header, and I want a quiet one. I've heard that if I stick to catted headers the car will still be quiet. Is this true? Anyone have speedfactory's catted header?
Any suggestions for headers? I would prefer UEL because it delivers more torque at lower rpm, but I'm willing to go EL if it means a quieter exhaust at idle and low rpms.
The Following User Says Thank You to mad_sb For This Useful Post:
Chad86 (05-09-2016)
Old 07-10-2015, 06:22 PM   #18
DAEMANO
Time Traveller
Benefits of a OEM header with gutted cat and straight pipe are:
1. Price. A take-off OEM header sells for $75-$125. Buy it, gut it and keep your orginal header for smog check swaps.
2. Power. The WHP difference between OEM header with gutted cat OEM vs aftermarket is minimal (less than 3 WHP compared to the RevWorks header in NickFRS dyno)
3. Compliance. An OEM header with gutted cat will pass a roadside visual inspection
4. Heat. An OEM header retains the factory heat shields. Heat in the oil pan and on the coilpacks is a well documented issue
5. Noise. An OEM header is quieter because of the aformentioned heat shields.
Undoubtedly a highly optimized aftermarket header can produce a few more WHP and shave some weight, but the above benefits are pretty compelling. Also welding in a straight-pipe makes the OEM header roughly equivalent in power to most of the sub $1000 aftermarket headers.
The Following 3 Users Say Thank You to DAEMANO For This Useful Post:
Donbrz (07-10-2015), drewbot (07-14-2015), Sigh-on-Rice (07-28-2015)
Old 07-11-2015, 02:50 AM   #19
churchx
churchx's Avatar
Drives: 2014 GT86
To me only 1. & 3. seems important enough. 2. - there are several providing much more gains. Not 3, not 5, but +20 above gutted stock i believe (of course PTuning's or Ace's cost accordingly higher). Why compare with least performing? 4. - even with stock header for track use i'd think about oil cooler. 5. many intentionally go for noise increase with aftermarket parts, don't see it as issue. Get extra loudness from header swap, get less agressive/not too loud rest of exhaust upgrades (or even leave stock).
Old 07-12-2015, 05:10 PM   #20
Vmax911
Drives: WRB BRZ
How does a heat shield make it quieter?
Vmax911 is offline   Reply With Quote
Old 07-12-2015, 05:19 PM   #21
DAEMANO
Time Traveller
Insulation. Essentially the clamshell of formed metal plates that is the stock heat shield acts as a vibration damper that reduces certain sound waves.
Top is stock bottom is Borla UEL.
Kushkaki (12-18-2018)
Old 07-12-2015, 05:24 PM   #22
Vmax911
Drives: WRB BRZ
Hmm, I thought the loudness associated with headers was due to the sound coming out of the tail pipe, not the vibration of the header mounted to the engine. I guess you could add some Dynamat to your header and if it's too loud, lol!
Old 07-12-2015, 05:59 PM   #23
Chad11491
Drives: 85.5 Porsche 944, '15 mustang GT PP
I have an uncatted JDL UEL and a q300. It is maybe 10% louder than all stock, and sounds amazing and deep. No drone. Perfect for a DD.
Chad11491 is offline   Reply With Quote
Old 07-14-2015, 11:31 AM   #24
OnionTou
OnionTou's Avatar
Drives: Toyota GT 86
Can you tell me what brand of headers you had? thank you!
OnionTou is offline   Reply With Quote
Old 07-14-2015, 04:22 PM   #25
mad_sb
namless coated both before the revision and after (i had to rma mine due to fitment issues)
fa20club long tube catted, also tried the catless version.
Old 07-15-2015, 10:27 PM   #26
Turdinator
Señor Member
Turdinator's Avatar
@OnionTou & @akash_
Sooo... The stock header only sucks vs. aftermarket because it has a standard cat. And we know that the stock EL header is quieter than an aftermarket one, but why? Well it's because...
1. The stock cat is denser than an aftermarket high-flow cat
2. The stock header is made from thicker metal than an aftermarket header
3. The stock header retains both top and bottom heat shields
Easiest way to get the best of both worlds would be to either:
1. Gut the cat in the stock header and optionally have a muffler shop weld in a straight pipe
2. Cut off the stock cat and have a muffler shop weld in a straight pipe
The stock EL header is actually a pretty decent piece. People that have removed the stock cat from the stock header report equal gains to an aftermarket catless header.
The other benefit of doing this is that you can't tell any modifications have been done afterwards (because the stock heat shield is covering everything). So you don't have to worry about passing a visual inspection.
Read here:
http://www.ft86club.com/forums/showthread.php?t=55770
I am not saying you are wrong but the linked thread is a bad example as it is a supercharged car and swapping headers is quite different to doing so on an NA car.
1974 TA22 Celica
2013 86 GT
Old 07-27-2015, 03:52 PM   #27
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
Just want to point out that I love your setup and exactly what I'm planning to do.
I want to leave the header last because of noise. Maybe work on audio a bit and then do header last cause I don't go to the track or anything so won't matter much. Maybe in a few years they will make a quieter header haha.
What overpipe brand did you use
Cause i also want the invidia catted frontpipe and want an overpipe that ill match it well
Also how did the gains feel after the front pipe, over pipe and tune for a daily driver car?
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
Old 07-27-2015, 03:57 PM   #28
chas3wba0
chas3wba0's Avatar
Drives: Yes
Just switched back to stock catback and this is what it sounds like. The rest of the exhaust is aftermarket, cats in both the header and front pipe:
[ame="https://www.youtube.com/watch?v=zuZhV7MZ3_g&list=PL-yYtv6mizg6LnXijtKs3sLeSdnZpF2qV&index=13"]Catted UEL header + Berk catted FP + stock catback + E85 - YouTube[/ame]
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
The Following 2 Users Say Thank You to chas3wba0 For This Useful Post:
Mr.Impreza (07-28-2015), TofuJoe (09-30-2016)
Greddy SP Elite + Borla UEL Headers = Very Quiet NoFear99 Engine, Exhaust, Transmission 52 06-01-2016 02:22 AM
WTT: N1 catback for something quiet Zixxerguy Engine, Exhaust, Bolt-Ons 21 05-21-2015 08:10 PM
Quiet FI Lord-Hydro Forced Induction 58 03-06-2015 08:34 PM
'Quiet' Header SpeedyJay Engine, Exhaust, Transmission 24 06-11-2014 05:46 PM
WA orders gone quiet? Bounce AUSTRALIA 8 12-05-2012 12:54 AM
