Old 07-13-2015, 04:01 PM   #15
Originally Posted by STV3 View Post
Really? Thats odd. Maybe because they come with it built into the taillights and it isn't an additional light its ok.
Originally Posted by swarb View Post
It is a gray(grey?) area. It can't be used as a fog light(in California), but you can use it as a courtesy light or loading light like on trucks.
Found the law.
The problem was that the guys wanted white fogs and they can only be red and the center light is too low according to the law.
24602. (a) A vehicle may be equipped with not more than two red fog taillamps mounted on the rear which may be lighted, in addition to the required taillamps, only when atmospheric conditions, such as fog, rain, snow, smoke, or dust, reduce the daytime or nighttime visibility of other vehicles to less than 500 feet.
(b) The lamps authorized under subdivision (a) shall be installed as follows:
(1) When two lamps are installed, one shall be mounted at the left side and one at the right side at the same level and as close as practical to the sides. When one lamp is installed, it shall be mounted as close as practical to the left side or on the center of the vehicle.
(2) The lamps shall be mounted not lower than 12 inches nor higher than 60 inches.
(3) The edge of the lens of the lamp shall be no closer than four inches from the edge of the lens of any stoplamp.
(4) The lamps shall be wired so they can be turned on only when the headlamps are on and shall have a switch that allows them to be turned off when the headlamps are on
AZP Installs (07-15-2015)
Old 07-13-2015, 04:16 PM   #16
STV3
Señor Member
STV3's Avatar
Found the law.
Ahhhh ok good to know. I have mine wired as a brake/taillight. Havent been bothered yet
STV3 is offline   Reply With Quote
The Following User Says Thank You to STV3 For This Useful Post:
Tcoat (07-13-2015)
Old 07-13-2015, 05:26 PM   #17
Papi
Drives: Crystal White Silica BRZ Limited
Thanks for the info, only thing is when I do the electrical mods I prefer not to splice. I would rather build a harness so I can swap to OEM if I had to. Plus it's much cleaner. Thanks for the law I'm going to measure the light
Papi is offline   Reply With Quote
Old 07-13-2015, 05:53 PM   #18
ryoma
ryoma's Avatar
Nsidious makes a plug and play harness with bulb. all you need to do is drill a hole in the housing. although it's a bit expensive, it's as PnP as you can get. you just connect a plug between the OEM harness to tail light and find a ground.
Old 07-13-2015, 06:04 PM   #19
This may help.
Old 07-13-2015, 06:28 PM   #20
tyrantcf
Drives: '16 WRX, CBR1000RR
Do we not have enough of these rant threads?
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
Old 07-13-2015, 06:31 PM   #21
Speed2th
I love my series blue brz
Speed2th's Avatar
Drives: 2010 335d
i think i read somewhere that if exhaust tip extend to far out and gets hot= burn leg = lawsuit = what American likes to do
There is a company sells plug and play fog light kit
http://nsidiusindustries.bigcartel.c...t-wire-harness
Speed2th is offline   Reply With Quote
Old 07-13-2015, 06:53 PM   #22
Hmmm maybe we need a rant thread for ranting about rants. Could get as confusing as hell though.
RobertPaulson (07-14-2015), tyrantcf (07-13-2015)
Old 07-13-2015, 07:07 PM   #23
One of the rear crash test criteria is that a car should only sustain $XXX (I don't remember the actual dollar value) in a 10mph crash. The bumper skin is designed to absorb most of the force/damage at that low speed and protect the operating parts of the car. Exhaust that protrudes out too far beyond the skin can take the brunt of the force before it is absorbed by the bumper skin. If the exhaust takes the full force it is far more than just some bent tips you are looking at. The force can be transmitted all the way forward and wipe out the exhaust, header, block, wiring and other critical components.
It was this simple 10mph front crash rule that kept the Evos out of Canada up until the X because the old intercooler set up would not survive even a low speed crash and the repairs were above the value threshold.
Oh and yes people could get burned and sue I suppose.
Old 07-13-2015, 07:42 PM   #24
Talus1
Talus1's Avatar
Drives: '06 Cayman, ‘23 BRZ Sport-Tech
Found the law.
The problem was that the guys wanted white fogs and they can only be red...
Funny, we had a Saab 900 and a 9-3, both with rear fog lights, for a combined total of 15 years. We probably only used the rear fog lights a couple of times. In all those years, I never noticed that there was only one light, that it was on the left and that it was red! Must have been the only bulb on either of those cars that didn't burn out! (I've never owned a car on which I had to replace bulbs more often than those damned Funny Swedish Cars).
Talus1 is offline   Reply With Quote
The Following User Says Thank You to Talus1 For This Useful Post:
Tcoat (07-13-2015)
Old 07-13-2015, 09:11 PM   #25
Papi
Thanks for the info on the p n p harness but I actually would like the rear fog not another brake light
Old 07-14-2015, 12:13 AM   #26
Papi
Let me clarify something. I only want the exhaust tips to be flush to maybe 1/4" beyond
The Following User Says Thank You to Papi For This Useful Post:
Tcoat (07-14-2015)
Old 07-14-2015, 11:09 AM   #27
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
For cars only equipped with one rear fog light, according to the EU it has to be either center mounted or on the driver side (I retrofitted this onto my previous Golf GTI and the rear fog light replaced the driver side reverse light, popped in an European light switch, rewired it underneath the dash, and reprogrammed the car computer with VAGCOM).
Also for EU countries if cars are equipped with HID headlights, they need headlight washers and auto leveling to mitigate glare in the event they get dirty. The twins will have these features stock when sold in Europe.
I thought about adding the OEM rear fogs to the BRZ but the wiring harness from the dash to the fuse / relay box just simply doesn't have the wiring for it in place like the RoW cars. In Japan this is an option that can be added since the wiring is already there.
krayzie is offline   Reply With Quote
Old 07-14-2015, 11:50 AM   #28
Icanfaptothis86
tickle fight referee
Icanfaptothis86's Avatar
backup cameras are for n00b choads
Icanfaptothis86 is offline   Reply With Quote
The Following User Says Thank You to Icanfaptothis86 For This Useful Post:
funwheeldrive (07-14-2015)
Gas Station Rant PollosHermanos Off-Topic Lounge [WARNING: NO POLITICS] 98 08-28-2014 09:43 PM
7-11 /RANT Trashed675 Off-Topic Lounge [WARNING: NO POLITICS] 12 04-12-2014 10:52 PM
Just a quick rant brianlo622 Northern California 10 10-12-2013 12:37 PM
Whiteline Rant Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 06-10-2013 10:01 AM
Manga rant! Shadowsong6 Off-Topic Lounge [WARNING: NO POLITICS] 6 07-27-2011 01:33 AM
