go_a_way1
Old 07-09-2015, 02:50 PM   #2801
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by FR-Shred View Post
How are 17x9 +42?
My camber was -2.6 with lowering the car before I did LCA.. I didn't want to run that much camber in the rear without that or more camber in the front. But since I don't have camber plates in the front so I can only get -1.5 in the front. I had the shop put the rear camber at -1 to keep handling good.
Any experience with +42 offset?
I was unaware of using two camber bolts.. hmm.. with that I would probably bump the front up to -2 and -1.5 in the rear.
Okay, that explains a bit why you had so little camber in the rear.
+42 offset is okay but a bit on the high side and will limit the width of tires you can run unless you add spacers (which effectively changes offset).
I recently mounted a set of 18x9 +42 BremmerKraft wheels with 245/35R18 tires for a customer.
We had enough clearance to the inside strut to even add crash bolts but was still very tight and he has some light rubbing during autox. Should be fine for daily driving and everything translates to 17" the same with a 245/40R17 tire.
Slick is offline   Reply With Quote
Old 07-09-2015, 08:15 PM   #2802
FR-Shred
FR-Shred's Avatar
Originally Posted by swarb View Post
Rear camber is not adjustable without lower control arms or some other type of bushing/etc.
Mach V wheels are +42 and many people seem to run them with no problem. With 255 tires they may be close to the strut.
I have lower control arms. So 17x9 42 with 245 or 255 tires will work with a 1-2" drop and -1.5 F and -1 R camber?
Ok sweet. I'm looking at a set that they have 35 and 42.. 35 seems to poke too much unless you run a lot of camber which I 1. Don't have 2. Don't want. Looking at 17x9 42 with 245 or 255 tires and 1-2" drop and -1.5F camber and -1R camber.
FR-Shred is offline   Reply With Quote
Old 07-16-2015, 06:13 PM   #2803
shaunieboy77
Drives: gray 2015 scion frs
Originally Posted by JoeBoxer View Post
I'm here to help also guys better to ask than end up with less than ideal fitment.
what size tires would i need for 18x9.5 +34 with verrryyyyy little stretch, very little?
shaunieboy77 is offline   Reply With Quote
Old 07-16-2015, 06:48 PM   #2804
swarb
Many people run x9 +35 and it does not poke much if at all, you can look at pics and decide for yourself. Also take account the camber settings, +35 with near stock(0) camber pokes a tiny bit if at all, but with enough camber, it does not. +42 will be cutting it close to the struts if you don't have coilovers, and you may need a spacer. It is a lot easier adding a spacer than it is trying to get rid of poke, as adding too much camber is not ideal. I personally like the look of +35 and that would be my choice.
Look at the meaty tire thread. Then look at the aggressive wheel thread. I would suggest 245/35-18.
Old 07-16-2015, 08:47 PM   #2805
Johnny.
Johnny.'s Avatar
Drives: A work in progress.
Would 18x9.5 +38 wheels with 245/40/18 tires work on stock struts and Eibach Pro kit springs.
I know it'll poke a bit, but would the tires this size cause any rubbing on the spring perch or anything? Want to make sure before I make the purchase.
Johnny. is offline   Reply With Quote
Old 07-21-2015, 09:51 AM   #2806
Butz
Drives: 09' 335i / Soon to be FRS Owner
About to pull the trigger on some CCW Lm20's for my street set-up and would like some solid information from the experts on here. I'm lowered about 1.5" on ST Coils and thinking about going with 18x9.5 square set-up running 255/35/18. What offset will I want to get? I don't want to dial in a large amount of camber and have it look ridiculous. Should I be looking at a different size wheel or can this be done and look clean? I haven't seen many people with the CCW set-up.
Thanks.
Butz is offline   Reply With Quote
Old 07-26-2015, 07:23 PM   #2807
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
On stock suspension, how will 245/35/18 look on 18x9.5+40 ?
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 07-26-2015, 10:03 PM   #2808
FRZ-BRS
Hi, I just recently bought wheels (MB Battles).
Size: 18 X 8, 30 offset. 5 X 114.3 lug pattern
I have conversion adapters 15mm to make them fit my 5 X 100.
so that would cancel it out to 15 offset.
I'm lowered 3 inches on BC Racing coilovers that have front adjustable camber plates. & I also have PBM rear lower control arms.
Front camber: -2.5 (Stock Wheel Setup)
Rear camber: -2.0 (Stock Wheel Setup)
I plan to either get tire sizes of: 225/35 or 235/35
I was wondering if I would have to add more camber to make these fit or possibly pull the fenders for more clearance? Also debating on raising the car 1" all around if it doesn't fit.
PICTURES FOR REFERENCE:
FRZ-BRS is offline   Reply With Quote
Old 07-27-2015, 05:49 PM   #2809
Ghost_86
Ghost_86's Avatar
Drives: GT-86
I need help with my tire set up on for the LRS 1.0. I want these rims and know they will fit but am not sure if the front will rub against the stock TRD suspension which is 1 inch lower than the stock FR-S. They are ADVID 1 - 18x9.5+38 offset. I want to buy 235/40/18 tires for it but am uncertain if I will run into problems with the TRD stock setup up front. Anyone have these wheels already installed? Or a wheel with the same dimensions? I don't want to resort to adding wheel spacers up front just to clear the suspension. I really need some one with the TRD springs installed to answer this question I guess.
2015 FR-S 1.0 RS - TRD # 297
Ghost_86 is offline   Reply With Quote
Old 07-28-2015, 01:49 PM   #2810
jshadeck
jshadeck's Avatar
Originally Posted by BRZBYE View Post
So what you are saying is it has more to do with the way the lip on the inside of the wheel is, correct? If so it sounds like I need to dry fit my wheels when they are delivered, and I think you are also saying that if the wheel clears the spring perch, then the tire most likely will clear as well, correct?
If you have eibach springs and stock otherwise, and are going to 18x9.5 +38 you dont need to dry fit, that is exactly what i and others have run, it fits w no rubbing. The issues are they poke outside the fenders and they are close on the inside so you cannot really camber at all.
jshadeck is offline   Reply With Quote
Old 07-28-2015, 01:49 PM   #2811
jshadeck
jshadeck's Avatar
See my other recent replies on this exact setup
Old 08-01-2015, 05:17 PM   #2812
blockii
Drives: frs
You guys think I'll run into any issues running 18x8.5 +33 with 245 40?
blockii is offline   Reply With Quote
Old 08-11-2015, 01:33 AM   #2813
Machfleury29
Drives: Lava scion Fr-S
I was planning on putting new wheels and tires on soon.
i was looking at Avant Garde M310's 18X9 +30, TSW NURBURGRING 17X8 +35MM, or ENKEI RAIJIN 18X8 +48MM. I wanted to go with a 235/45 would there be any rubbing issues with these?? really wanted to make sure before i buy. i also plan on lowering 1inch.
Thanks
Machfleury29 is offline   Reply With Quote
Old 08-14-2015, 01:17 AM   #2814
Pegasus_86
Drives: Toyota 86
Appreciate thoughts on:
Front: 18x7 et35 with 225/40/18
Rear: 18x7.5 et35 with 235/40/18
TRD wheels with either Michelin PS2 or Pirelli P-Zero Rosso with stock suspension. Can't run the TRD recommended 215/40 up front due to local load rating compliance rules.
Pegasus_86 is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
