Old 07-09-2015, 03:45 AM   #15
Jolt182
Jolt182's Avatar
Drives: Asphalt FRS
The key to making the ride look good will be lowering it. Stock height on that size will look funky. It sucks because the stock wheels look meh but I lowered the car down then ordered my Volks. In the end it was the right move.
Jolt182 is offline   Reply With Quote
The Following User Says Thank You to Jolt182 For This Useful Post:
Bakchoii (07-09-2015)
Old 07-09-2015, 03:49 AM   #16
Bakchoii
Choii
Bakchoii's Avatar
Drives: 2014 Firestorm Red Scion FR-S
I'll keep that in mind �� one step at a time
Bakchoii is offline   Reply With Quote
Old 07-09-2015, 09:44 AM   #17
SubaruLifer
Drives: 2015 ISM BRZ Premium
With 9.5" wide wheels and a +43 offset, you're going to get some pretty significant poke front and rear on the stock suspension. It'll get a little better if you just do lowering springs, but you're really going to need to either go to coilovers or camber plates to get the negative camber needed up front for a flush look.
SubaruLifer is offline   Reply With Quote
Old 07-09-2015, 11:44 AM   #18
Bakchoii
Choii
Bakchoii's Avatar
I'm probably going to go for a 18x8.5 +42 Im still looking into other setups.
Old 07-11-2015, 10:08 PM   #19
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
Originally Posted by Bakchoii View Post
So around November I will be upgrade my stock wheels to something different. I was looking at the Enkei RS05 RR 18x9.5. I was wondering if I need any other part to put those on (I'm keeping the car stock height). If any, other suggestions would be most appreciated.
Also, if anyone could recommend me great brands for UEL Headers planned for next year. I am a fan of the known WRX/STI Boxer rumble.
Thanks in advance!
I have those wheels in 18x9.5 +43. you will need aftermarket coilovers to clear on the inside.I have KWV3s installed on mine. I had to raise my fronts a bit as I was rubbing on the fenders on full lock, so I'm about 1.5" lowered now. They will also rub on the inside tire well a bit, but it's not problematic at all. I have 265/35r18 tires on these wheels, but if you go down to a 255, you'll have a bit more clearance while still having more than enough grip.
Here's some pics of mine if you're curious what it'll look like. The fitment is pretty good at this offset.
2013 Asphalt Scion FR-S | Jackson Racing Supercharger | KW V3 | Enkei RS05RR 18x9.5
campy is offline   Reply With Quote
Old 07-16-2015, 03:28 PM   #20
Jolt182
Jolt182's Avatar
Drives: Asphalt FRS
Here's my current setup. No rubbing yet either. 18x9.5 +40 all around with 255/35/18 tires. In order to make it work i had to get coilovers though. Regardless you'll want them to finish the look of your car and give you the clearance you need for wider wheels and tires.
I Need Advice About An Fr-s! DViper0020 Issues | Warranty | Recalls / TSB 13 05-09-2014 11:15 AM
need advice Blue14inTracy Engine, Exhaust, Transmission 13 03-27-2014 09:39 PM
Need advice!! Black_Pearl Scion FR-S / Toyota 86 GT86 General Forum 5 12-10-2013 01:14 PM
Advice EDCOVEY FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 12-10-2012 09:16 AM
Need advice FRSMAK86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-06-2012 06:39 PM
