Old 06-30-2015, 02:19 PM   #1
FrostedFlakes
Drives: 2013 Raven FRS
Open flash header and catless front pipe and unresonated exhaust review
I just installed my OFH combo with P&L over pipe, P&L catless front pipe and unresonated perrin 2.5" exhaust.
My original intent was to reduce the torque dip with the stage 2 open flash tablet. The gains and improvement is incredible. The only drawback for this set up is the extreme drone and rasp. I don't mind the loud exhaust drone but the metallic rasp is gets annoying at high rpm over 3500. I realized that for a daily city driver it may not be ideal both for the rasp and raw exhaust smell.
I am now contemplating on getting a high flow catted front pipe.
It gets embarrassing driving a 200hp car that sounds like a loud Honda fart can.
I don't think there is a huge loss of torque and hp going to a catted front pipe. I tried looking up and did not see many discussion.
Thoughts?
FrostedFlakes is offline   Reply With Quote
Old 06-30-2015, 02:22 PM   #2
RobertPaulson
Hisnamewasrobertpaulson
RobertPaulson's Avatar
Drives: 2017 Golf R
get a resonated mid pipe for the perrin, (or have one welded in) and get a resonated or catted front pipe. (or again have one welded in)
I ran a fully catless set up with a resonated front pipe (Helmholtz) and resonated perrin and i had 0 rasp.
This is your life and it's ending one minute at a time.
RobertPaulson is offline   Reply With Quote
Old 06-30-2015, 02:44 PM   #3
s30series
Drives: 2015 BRZ Series.Blue
How many times can this question possibly be asked?
If you are going to run a catless exhaust system, you MUST use at least two resonators.....HKS dual resonated front pipe and cat-back resonated will eliminate drone.
s30series is offline   Reply With Quote
Old 06-30-2015, 03:09 PM   #4
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Go back to stock catback. Try it. Should be a simple swap out.
JimmyMac is offline   Reply With Quote
Old 06-30-2015, 03:22 PM   #5
FrostedFlakes
Thanks for the feedback guys. Didn't mean to beat this topic to death.
As mentioned I don't mind the drone. I just didn't anticipate the rasp to be that bad. I will definitely look into a high flow catted front pipe in the near future.
Old 06-30-2015, 04:53 PM   #6
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
As mentioned a resonator wil help with the rasp. A 200 count HFC won't help much, but it will a bit.
I cant get over the fact that people are shocked that these cars get raspy when opened up. The more retarded the timing, the more retarded the exhaust cam gets, and the higher compression the engine, the louder, higher pitched, and raspier the exhaust note gets. That's just how the car was designed. It's like complaining about a diesel engine that knocks... Our cars sound like a Honda because the FA20 basically a flat K20... with poorly designed heads, so it makes less power.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 06-30-2015, 08:11 PM   #7
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
When going cat-less, resonators are your friend!
Shiv@Openflash is offline   Reply With Quote
Old 06-30-2015, 08:38 PM   #8
D_Thissen
D_Thissen's Avatar
@Shiv@Openflash
What about tossing the OEM front pipe back in? Would that make a difference? Is the stock front pipe, in your experience, too restrictive for car with just bolt ons?
Old 06-30-2015, 09:04 PM   #9
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
Originally Posted by D_Thissen View Post
@Shiv@Openflash
Just want to throw this out, I ran a Open flash header with stock OP, FP and catback and dyno'd 205whp on E85.
Nearly nothing past the header is restrictive if you're Naturally Aspirated. Honestly, maybe 2-4hp gain if you change from stock.
In addition, whenever you pair a header with ANY catback it will sound different and way louder than the catback with stock header (where most designers test)
My .02
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
Old 07-01-2015, 02:28 PM   #10
RobertPaulson
Drives: 2017 Golf R
@Shiv@Openflash
you might lose a bit of hp and gain some torque. that's about it. what i have seen posted is some people get a weird resonance in cabin from the stock front pipe (and everything else aftermarket). could be because of the resonator it has, but i'm not sure.
Old 07-05-2015, 02:05 AM   #11
FrostedFlakes
Just curious. Would getting just a Perrin resonated mid pipe still would not be sufficient to cut the rasp?
From everyone's comments I am starting to reconsider looking towards getting a proper resonator instead of the catted front pipe.
Just wondering if one Perrin resonated mid pipe would be enough or would the HKS dual resonated front pipe be the better option?
From what I think... The Perrin should have a longer resonator on the mid pipe as opposed to HKS two smaller resonators?
Old 07-06-2015, 02:59 PM   #12
RobertPaulson
Drives: 2017 Golf R
i mean, going either option will do a lot to cut out the rasp, but i'm unsure if one or the other will be sufficient or if you'll truly want both. It might be most cost effective to just have a muffler shop add the long resonator to your mid pipe and drive that around for a bit and see how you like it. if its still too raspy then go a-head and add a resonator to your front pipe
Old 07-06-2015, 04:12 PM   #13
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
It's going to cut out a lot of the rasp, but not all of it. I added a vibrant resonator to my HFC Berk Front-pipe, I have a HUGE Magnaflow resonator, and there is still some rasp. I have zero drone, and zero rasp at light throttle and just regular driving, but once you get into it, it's raspy, but I like it. It sounds like any other modern NA engine. The Jaguar F-Type and 911 GT3 have some rasp at the top of their rev range.
Old 07-06-2015, 04:36 PM   #14
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Not an OFH, but the stock resonator on the mid-pipe does a pretty good job at cutting rasp. No cats or other resonators in my system.
[ame="https://www.youtube.com/watch?v=eNiwGXRrQC8"]Scion FR-S Tomei UEL - YouTube[/ame]
Decay107 is offline   Reply With Quote
P&L Catless/Unresonated Front Pipe WRKHARD Engine, Exhaust, Bolt-Ons 2 04-21-2015 12:53 PM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
Open Flash Header Catless Clip Vmax911 Engine, Exhaust, Transmission 25 03-08-2014 06:51 AM
EVS Tuning SSP Exhaust + Catless Front pipe - Review 8686 Engine, Exhaust, Transmission 9 01-21-2014 06:50 PM
Catless header... o2 bungs before/after front pipe cat? Thorpedo Engine, Exhaust, Transmission 5 11-18-2013 11:59 AM
